Old 03-07-2013, 02:13 PM   #1
02scoob08
Member#: 266119
2002 Wrx
white
Default 04 wrx up pipe gasket
Is an aftermarket catless up pipe gasket the same as the stock gasket?
02scoob08 is offline   Reply With Quote
Old 03-07-2013, 02:35 PM   #2
Cory51191
Member#: 332781
2006 STI
You might need pictures considering some aftermarket companies use different flanges so you "have" to continue your piping project with them or get a new flange welded.
Cory51191 is offline   Reply With Quote
Old 03-07-2013, 02:36 PM   #3
Cory51191
Member#: 332781
2006 STI
Unless you mean "aftermarket" as in a better grade gasket then you should be fine.
Old 03-07-2013, 02:39 PM   #4
Nikryj
Member#: 346659
2003 WRX
The grimmspeed aftermarket gasket is the same as the OEM but much thicker. You just need to compare them
Nikryj is offline   Reply With Quote
Old 03-07-2013, 02:41 PM   #5
02scoob08
Member#: 266119
2002 Wrx
white
i just didnt know if it was larger or smaller and i have no idea where the old gasket went when pulled the motor.
Old 03-07-2013, 02:43 PM   #6
02scoob08
Member#: 266119
2002 Wrx
white
The head gasket set that I got had multiple shape gaskets for the exhaust but they were all too small.
Old 03-07-2013, 03:31 PM   #7
Nikryj
Member#: 346659
2003 WRX
what set did you get?
Old 03-07-2013, 04:15 PM   #8
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Aftermarket parts are 99% never the same as OEM. OEM is OEM, everything else is whatever.
Old 03-07-2013, 11:48 PM   #9
Cory51191
Member#: 332781
2006 STI
Very true but you're getting technical. Don't confuse the man :-P
Old 03-08-2013, 08:32 AM   #10
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Are you looking for a uppipe-turbo gasket or a manifold-uppipe gasket? The first is the same for all stock location turbos. The second is the same as stock as long as you dont have a header/uppipe combo that uses a 3-bolt flange.
