Old 03-07-2013, 02:16 PM   #1
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
Default Occasionally doesn't start unless accelerator held down
I'm sure this has been discussed somewhere but I haven't been able to find it yet. Can you point me in the direction of a helpful link?
Just recently my 05 wrx had a long crank to start, and then finally sputtered and caught after 3 or 4 tries. Drove 40 miles back home and it ran perfectly the entire way. Next morning it wouldn't start so I gave up after several tries cranking it and drove my truck to work. The next couple days it only started with the gas pedal held half way down and it took a few seconds but sputtered and started up and then ran perfectly. Thought at first I might have had some bad fuel but I filled it up (different station) and its still doing it.
My best guesses are:
-fuel pump going? (unlikely...?)
-clogged fuel filter (90k miles on it)
-bad fuel pressure regulator
-leaking fuel injectors (had happen on an 1990 Ford Bronco II)
-sticking idle air control valve? (this suggested by a friend)
130k miles, Cobb stg 1, I put in a new battery, sparkplugs, and airfilter less than 2000 miles ago
I have a new fuel pump and filter waiting for me at a dealership since I get OEM parts at dealer cost through a friend anyways
Any productive comments are much appreciated.
Barnt is offline   Reply With Quote
Old 03-07-2013, 09:23 PM   #2
clogged fuel filter??
change that first....
bad tank of fuel??
happen after a fill up??
Old 03-08-2013, 05:34 PM   #3
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
No, it was happening on about a quarter tank. I thought at first it may have been bad fuel so I filled up and it did not solve the issue. I'm changing the filter tomorrow. Hope that's it.
Old 03-09-2013, 01:41 AM   #4
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I fixed one that did that because of leaky injectors. I don't know if that is your problem but it fixed this customers car.
Old 03-12-2013, 02:25 AM   #5
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
Changed filter and pump. Problem persists...
Old 03-12-2013, 04:20 PM   #6
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
you changed the filter under the hood? or just the "sock" or "filter" that's on the pump.
jayman4312 is offline   Reply With Quote
Old 03-12-2013, 04:41 PM   #7
ogboot
Member#: 170906
psm
Can you hear the fuel pump prime when you insert the key and turn it on on (but do not start)?
ogboot is offline   Reply With Quote
Old 03-12-2013, 04:49 PM   #8
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
I've had this happen before. Very intermittently (sp) maybe once every 2-3 months.
No other symptoms. Even after FP is primed, which I do at every start up.
Brock31 is offline   Reply With Quote
Old 03-13-2013, 05:26 PM   #9
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
fuel pump is brand new. primes just fine.
and i was unaware of any underhood-filter for the wrx after 2004
Old 03-13-2013, 09:31 PM   #10
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
check the elbow behind the maf to the inlet, or the inlet to the turbo.
If any of the track is disconnected or have a large enough rip, you can have starting problems that you described.
Old 03-13-2013, 09:38 PM   #11
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Having the accelerator pedal pushed to the floor used to engage "clear flood mode," I'm not sure when that stopped. It's possible you have a failing or stuck open injector that's pouring fuel and preventing it from running properly. If you have access to a stethoscope or long screw driver, place it on each injector while someone cranks it and see if you can hear them clicking.
Old 03-14-2013, 01:55 PM   #12
Barnt
Member#: 161824
15 WRX. Pro-tuned
Way too blue...
^^thanks I'll check on both of these this weekend. much appreciated.
Old 03-14-2013, 10:01 PM   #13
Haelan
Member#: 151045
2013 Subaru STI
CBP
Pull the plugs and visually inspect if a cylinder is running rich (possible stuck injector). If holding the accelerator down helps to start then not enough air is getting passed the throttle plate, which could be the IACV--it acts as a throttle plate bypass.
Haelan is offline   Reply With Quote
