Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 02-18-2013, 08:07 PM   #2751
fl4tpower
Member#: 282664
2011 STi ltd Stage 2
Obsidian Black Pearl
Yea I don't know if I'll hit the max duty cycle on the injectors with. Don't want that at all. Not looking to do any more engine mods soon so I'm debating.
fl4tpower is offline   Reply With Quote
Old 02-18-2013, 08:11 PM   #2752
PearlRex11
Member#: 284420
2011 WRX Sedan
I would think your tuner could tune it like that just fine...... Actually this sounds like a question you should ask him, would net you the best answer for sure.
PearlRex11 is online now   Reply With Quote
Old 02-18-2013, 08:17 PM   #2753
fl4tpower
Member#: 282664
Yea I did. He said its up to me either way. He could tune it with or without the new pump. Just seeing if there was any other benefits to getting it. Thanks
Old 02-18-2013, 08:58 PM   #2754
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
Not until you do more mods
Celery GT-5 is offline   Reply With Quote
Old 02-18-2013, 09:08 PM   #2755
fl4tpower
Member#: 282664
Yea that's not happening any time soon. I'm very happy with the cars performance now. Thanks for the input guys.
Old 02-20-2013, 10:47 AM   #2756
Asharus
Member#: 276300
2015 Ford Mustang GT
Oxford White
Can someone do me a solid and figure out what this piece is? I think it slips onto that bolt in the 2nd pic, right next to the dead pedal, but the thing keeps falling off.
https://www.icloud.com/photostream/#A4GgZLKuJ5UKDg
Asharus is offline   Reply With Quote
Old 02-20-2013, 01:57 PM   #2757
tcoffin014
Member#: 173734
Sexy White Princess
Mine came off a while ago and I lost it haha. Never have replaced it
tcoffin014 is offline   Reply With Quote
Old 02-20-2013, 01:58 PM   #2758
Asharus
Member#: 276300
Oxford White
so am i right to assume that the spot pictured is where its supposed to be?
Old 02-20-2013, 03:35 PM   #2759
tcoffin014
Member#: 173734
Sexy White Princess
That's what it looks like. Mine looked a little different I think but maybe yours is cracked or something
Old 02-20-2013, 03:35 PM   #2760
_davin
Member#: 260501
2003 miata SE
Blurple
Maybe ask subtle solutions if you're really worried about it, since they make a replacement.
_davin is offline   Reply With Quote
Old 02-20-2013, 03:45 PM   #2761
Asharus
Member#: 276300
Oxford White
hmm yeah, its probably broken. i remember my shop had that whole area torn apart when they were installing my gauges.
Old 03-01-2013, 05:58 PM   #2762
Celery GT-5
Member#: 98210
2002 WRX SRP
yay
Old 03-07-2013, 08:34 PM   #2763
Project Z
Member#: 346192
2012 Wrx
Plasma blue
I am very curious about a rear tow hook for my 2012 wrx 5-door and if anyone knows anything about it plz message me back? I'm also new to this website so I'm not sure how to use it yet.
Project Z is offline   Reply With Quote
Old 03-07-2013, 09:09 PM   #2764
SWP is Sexy
Member#: 302389
I'm a stormtrooper pewpew
One came with the car, the little square piece pops out and you screw it in.
Unless youre after an aftermarket version, then hit up teh googles
SWP is Sexy is offline   Reply With Quote
Old 03-07-2013, 09:46 PM   #2765
_davin
Member#: 260501
2003 miata SE
Blurple
Yeah, owner's manual yo...
Old 03-22-2013, 09:08 PM   #2766
Only1Wrx
Member#: 300799
2011 Impreza WRX
Blue Pearl MR
This morning my car would not start when I first turned the key. It revved and wanted to start. The second time I turned the key it started. This just happened again right now and this would be about the 6th time total within 2 years. (Spaced out about every 4 months it happens). Any ideas? Would it be my starter?
Only1Wrx is offline   Reply With Quote
Old 03-22-2013, 09:19 PM   #2767
Celery GT-5
Member#: 98210
2002 WRX SRP
sometimes you need to hold the key longer than other cars..my car sounds unhappy when I start it in the cold.
you should probably check the battery before the starter
Old 03-22-2013, 10:40 PM   #2768
_davin
Member#: 260501
2003 miata SE
Blurple
If it was the battery it wouldn't start at all.
What do you mean by revved and wanted to start? Unless you're saying that you just turn the key and let go of it to start your car, in which case I'm surprised it usually starts at all and like Celery said you have to hold it down for a second.
Old 03-22-2013, 11:17 PM   #2769
Celery GT-5
Member#: 98210
2002 WRX SRP
Batteries die slowly, first it will be hard to start and then eventually it won't start at all. If it's having a charging issue sometimes it will only stay on if you keep the revs up for a while, not that common though. Just check the voltage to start with and go from there.
Old 03-22-2013, 11:21 PM   #2770
_davin
Member#: 260501
2003 miata SE
Blurple
OK you just said revs too, wtf are you talking about. Are you saying while it's running? If the car dies while it's running due an electrical issue it's the alternator.
Old 03-22-2013, 11:26 PM   #2771
Celery GT-5
Member#: 98210
2002 WRX SRP
I had an issue with my Dakota where I left my headlights on to light up a basketball court and after that it wouldn't stay on unless u held the revs up for a few mins. I found out after I got rid of it that it was a just a bad battery. Alternator failure is the opposite, it will start and then die after you drive it for a while because it's running entirely off the battery.
Old 03-23-2013, 12:06 AM   #2772
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Deno if anyone is also having this issue but I noticed it in my 2011 WRX that if I accidentally lug my car a little bit like if I'm in a parking lot and I'm moving around at 1mph trying to find a spot that when I try and start up my car it hesitates before it fully turns over. I've been able to replicate this problem pretty much every time which is starting to make me worry.
If my car starts up funny I can turn it off and when I try and start it up the second time there is no hesitation and it starts right up.
Any ideas on what this might be? I was thinking maybe a dirty MAF sensor?
xabre1200 is offline   Reply With Quote
Old 03-23-2013, 12:16 AM   #2773
Celery GT-5
Member#: 98210
2002 WRX SRP
Have you guys tried giving the fuel pump a few seconds to prime in the on position before cranking?
Old 03-23-2013, 12:26 AM   #2774
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Yeah I thought I was cranking too quickly so I'd let my fuel pump prime for about 5 seconds before cranking but when I feel like I lugged my car a tiny bit before parking it, the car is going to hesitate when starting...
The car cranks and you can hear it start but when you hear the engine strain a little bit before it starts.
Old 03-23-2013, 12:30 AM   #2775
Celery GT-5
Member#: 98210
2002 WRX SRP
one time I launched my car and after I slowed down the idle got all bouncy
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 12:03 PM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 10:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 04:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 08:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 04:00 AM
