Old 02-05-2013, 03:40 PM   #251
mfmunh
Member#: 307040
Originally Posted by ChesterWRX View Post
well, the issue is the lumens (sp) that they put out.
the H9 put out almost double what the H11's put out. so they shine better down the road.
it's hard to explain with pictures posted online. i came into my WRX from a Legacy, i instantly noticed that the low beam lights were "Bla" for my taste.
-i only went with the hyper whites because of personal preference. i could have put a plain ol' H9 in there for about $10/ bucks per bulb. instead, i ordered the ones i got. i am very happy with the outcome.
no more "Bla" H11's
-consider me a poser if you wish. although i've yet to see a WRX Limited or STi in person, so I'm not sure how good those OEM HID's look.
i like the clean look of my car at night now way better.
So when you order the lights from head lightbulbs, did you get the H11? Or went with the H9 and modified the tab to fit?
mfmunh is offline   Reply With Quote
Old 02-08-2013, 06:49 PM   #252
QAboy
Member#: 21711
2012 2.0i Premium
Ice Silver Metallic
So after emailing Daniel Stern about this for some clarification, he indicated that "The H9 swap is not safe to do in the reflector-type headlamps." Thoughts?
QAboy is offline   Reply With Quote
Old 02-08-2013, 07:22 PM   #253
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
The reflector type halogen usually have a less controlled beam with more light leakeage above "cutoff" (there is not that much of a defined cutoff). My guess is the increase in light with these type of headlights result in too much light above cutoff causing excessive glare.
Projectors have better beam control and can probably manage more light while still keeping somewhat normal squirrel finder illumination. I think what he is trying to say (without saying it) is its fine on projectors even if it is still illegal, like almost every lighting mod.
frederik is offline   Reply With Quote
Old 02-09-2013, 10:44 AM   #254
QAboy
Member#: 21711
2012 2.0i Premium
Ice Silver Metallic
Ok thanks that makes sense. Anyone with reflector lamps with this mod that can weigh in with opinions/thoughts/pictures off the beam pattern?
Old 02-12-2013, 12:57 AM   #255
sketcheroo
Member#: 339856
2013 WRX Premium
Did this over the weekend but didn't have a chance to try them out until tonight. I noticed the light to be brighter and whiter which was nice.
sketcheroo is offline   Reply With Quote
Old 02-12-2013, 09:23 PM   #256
deez11550
Member#: 327237
2008 subaru impreza
dark grey
wat brand did u use ? ur opinions ? do u suggest it to others ?
deez11550 is offline   Reply With Quote
Old 02-13-2013, 01:58 AM   #257
sketcheroo
Member#: 339856
2013 WRX Premium
Bought the Philips H9 off Amazon:
Philips H9 Standard Headlight Bulb, Pack of 1 : Amazon.com : AutomotivePhilips H9 Standard Headlight Bulb, Pack of 1 : Amazon.com : Automotive
It took me about 5 minutes to grind the tab off with a utility knife, but about 2 1 hour to get the bumper back on since it was my first time -_-
Cheap way to get some more lumens, but I don't feel like the H11s were all that bad in the first place.
Old 02-13-2013, 08:11 AM   #258
Scooby207
Member#: 255687
11 WRX DGM
I didn't have to remove the bumper... am I missing something?
Scooby207 is offline   Reply With Quote
Old 02-13-2013, 10:11 AM   #259
P.Rico
Member#: 239452
2010 Impreza WRX
1991 Prelude Si 4WS
Originally Posted by sketcheroo View Post
Bought the Philips H9 off Amazon: Philips H9 Standard Headlight Bulb, Pack of 1 : Amazon.com : Automotive
All you had to do was take the air intake out of the left side and move the washer reservoir hose out of the way on the right side.
Did you really take the bumper off just to replace lowbeam bulbs?!
P.Rico is offline   Reply With Quote
Old 02-13-2013, 04:03 PM   #260
lj8915
Member#: 329252
2012 Subaru WRX
Lol..
lj8915 is offline   Reply With Quote
Old 02-13-2013, 08:09 PM   #261
sketcheroo
Member#: 339856
2013 WRX Premium
Oh well, at least now I know how to remove the bumper lol
Old 02-13-2013, 08:53 PM   #262
J.biz
Member#: 191825
2009 WRX Hatch
Wow man!!! Hey at least you learned a couple new thing about your car!!!
J.biz is offline   Reply With Quote
Old 02-13-2013, 09:11 PM   #263
veener79
Member#: 204304
2008 WRX 4D Stage 2
Now when you put Hella Horns in you will be set.
veener79 is offline   Reply With Quote
Old 02-24-2013, 04:51 PM   #264
deez11550
Member#: 327237
2008 subaru impreza
dark grey
ok so i just did the H9 conversion and i would think i would get a whiter look. nope still that stock yellow look ? ! i used the H9 SYLVANIA ones . anyone have any suggestions or ideas ?
Old 02-24-2013, 11:36 PM   #265
Scooby207
Member#: 255687
11 WRX DGM
If I understand correctly, this conversion improves light output but that doesn't mean they will give you a whiter look.
There are some bulbs you can buy that imitate the look of HID's to give a whiter look but it is just for looks and if I'm not mistaken have to possibility of diminishing light output due to the coating that is put on the bulb to give it that white look.
I'm not a lighting expert so please chime in if I'm completely wrong
Old 02-25-2013, 01:56 PM   #266
Angelus911
Member#: 89967
2012 Impreza Sport
Yup, this will increase light output, but the bulb itself defines the color output.
Something like these would probably give a much less yellow light, as they have no coating on the lens:
Old 02-25-2013, 03:10 PM   #267
SomeGoalie
Member#: 342696
2013 WRX Sedan
Video Link: http://www.amazon.com/Philips-Standard-Headlight-Bulb-Pack/dp/B00480KOP4/ref=sr_1_1?ie=UTF8&qid=1361818544&sr=8-1&keywords=h9
Those are the bulbs I used. They seem less yellow than the stock ones. Either way the light output is better!
SomeGoalie is offline   Reply With Quote
Old 02-25-2013, 05:15 PM   #268
luan87us
Member#: 335013
2013 Premium WRX 5dr
"Xenon, LED, and filament-bulb lamps are three completely different technologies. They produce light using wholly different means, and therefore they look different. They're supposed to look different. Trying to match the color of a Xenon or LED lamp with a halogen bulb is pointless and counterproductive. It'll never look the way you want it to, and in the meantime all you're doing is wasting money, reducing your seeing ability, creating glare, and in many cases destroying the safety performance and legal compliance of your car's lighting system. "Color temperature" / "Kelvin rating" (correct terminology: CCT) is a real
phenomenon, but its use in the advertisement of automotive lighting
products is almost entirely fraudulent. Higher-CCT light, contrary to
misinformed and disinformed advertising hype, is not "closer to natural
daylight" and does _not_ help you see better in any way, and it produces
significantly worse seeing performance in any kind of bad weather. All
higher-CCT light does is change the appearance of the operating headlamp
and, outside of a very small range created by different surface luminance
characteristics of different legitimate bulb designs, increase glare and
reduce total and usable light output." Daniel Stern Lighting
I got the Phillips H9 bulbs as well and did expect a whiter look. However I'm very happy with the less yellow look compared to the OEM ones. I bought a $9 dremel tool from Harbor Freight which made the the trimming so much easier coupled with small wire cutter. Cut most of the tab off then grind the rest off with a grinding tip. Also according to Daniel Stern the Phillips H9 bulbs are VERY good bulbs. Cheap fix to the OEM lights. Now I can see so much better at night and in snow storms.
Old 02-25-2013, 06:35 PM   #269
deez11550
Member#: 327237
2008 subaru impreza
dark grey
thanks for the advise ... yea i see a big difference in light output , a lot brighter
Old 02-28-2013, 09:42 PM   #270
leed
Member#: 336303
2009 OBS
Blue/Silver
So another light comparison... This is all things constant [White Balance (though incorrect ), Shutter Speed, f-stop, ISO, ambient lighting (lights off in my garage)] I was a little disappointed in the engine off differences, so when I put in the 9011 in the high-beams, I will re-test the OEM low-beams with the engine running as well. Also, sorry for the crooked pictures, I wanted to keep a reasonably consistent location on my dash.
OEM Bulbs [after 45k miles], Engine Off
Phillips H9 Bulbs, Engine Off
Phillips H9 Bulbs, Engine On
Phillips H9 Bulbs, Engine On, High Beams [OEM] On
leed is offline   Reply With Quote
Old 03-01-2013, 02:24 PM   #271
Dachef3212
Member#: 347747
2015 STI LE
WRC
Just picked up my hatch wrx rally blue last week as
Dachef3212 is offline   Reply With Quote
Old 03-01-2013, 02:26 PM   #272
Dachef3212
Member#: 347747
2015 STI LE
WRC
Sorry stupid fat thumbs. As I was saying just put these H9s in and so far looks good in the daytime.
This is my first Subie and so excited to see wear this for will lead me too!
Old 03-02-2013, 08:28 AM   #273
ecapox
Member#: 276346
2011 Impreza WRX
Red
Reflector? Isnt this about projectors?
ecapox is offline   Reply With Quote
Old 03-06-2013, 03:59 PM   #274
MatthewB10
Member#: 320973
Ice Silver Metallic
I believe they're not acceptable because in a reflector housing, you can visually see the bulb. In something like a silverado, where they use a 9006, there is a coating on the tip. The H9's do not have this coating, meaning you can see the filament... Blinding EVERYONE. Just my opinion to Daniel sterns response.
MatthewB10 is offline   Reply With Quote
Old 03-07-2013, 09:05 PM   #275
veener79
Member#: 204304
2008 WRX 4D Stage 2
need to fix a DIY r134a A/C conversion Niku-Sama Service & Maintenance 4 06-12-2009 08:50 PM
cant seem to find a diy thread on how to 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-06-2007 08:47 AM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-01-2003 06:44 PM
auto to manual conversion with big torque expectations kaneda3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-21-2001 01:01 AM
