Old 09-03-2012, 02:54 AM   #1
ehawthorne521
Member#: 149686
2002 My name is Evan
and I am an Autoholic
Default My Silver 2002 Impreza WRX 27,000 miles to 105,000 miles and beyond
|2002 SUBARU IMPREZA WRX SEDAN|PLATINUM SILVER METALLIC|
|DAILY DRIVEN|SELF-WRENCHED|
I've had my car since February of 2007 and I thought it was time to post a thread of its progression and updates for future modifications and changes.
How my car sits right now
298 Horse Power at 6,550 RPM|260 ft lbs of Torque at 4,800 RPM
Average Horse Power 192.2hp|Average Torque 207.1ft lbs
Graph is HERE
Modification list
Engine/Drivetrain Performance
JDM Spec-C One Piece Intake Manifold
APS Cold Air Intake 65mm
APS Turbo Inlet Pipe
APS SR375 Top Mount Intercooler
APS 3 inch Cat Back Exhaust
APS Racing Fuel System w/ Spec-C Manifold adapter plates made by orwrx
APS High Volume Dual Vent Blow Off Valve
HKS Down Pipe
Borla Header
Grimmspeed Uppipe with Tial MVS 38mm External Wastegate and Screamer Pipe
Walbro 255 Fuel Pump
Subaru 565cc Blue Injectors
SPT Air intake Heat shield
HOA (Prodrive) 3 Port Electronic Boost Solenoid
Subaru IHI VF39 Turbocharger
Rebuilt 5-speed (nothing special... I regret not just getting a 6-speed )
Cusco Engine and Transmission Mounts
SPEC Stage 2 Clutch
Kartboy Short Shifter
Beatrush Alternator/Accesory belt cover
Koyo Racing Radiator
Suspension, Chassis, and Brakes
BC Inverted Racing Coilover
STi 21mm Sway bar Front and Rear
STi Aluminum Front Lower Control Arms
GT Spec Roll Center Adjust Kit
Kartboy Endlinks Front and Rear
Kartboy Front Endlink Spacers
Kartboy Rear Subframe Lockdown Bolts
MSI Lateral Links
MSI Trailing Arms, 2 inch correction
TiC Fender Cowl Brace
TiC Lateral Link Bushings
TiC Trailing Arm Bushings
Carbing Rear Strut Tower Bar
DBA Rotors
Hawk HP+ Pads
Exterior and Wheels
JDM STi Hood Scoop
JDM Headlights
JDM STi Grill
Prodrive Replica Front Lip
Cusco Rear brace with Diffuser Mounts
STi Rear Diffuser
Beatrush Undertray
17x8 Rota Torques with 245/40 Bridgestone Potenza RE760 Sports
Interior
Recaro SRD Drivers Seat
Black Suede Headliner
Black Suede Door Cards
Cusco Sports Shift Knob
STi Limited Red Hazard Button
Pioneer AVIC D3 Stock Headunit
I got my car when I was 17 as a graduation present/Reward for my hard effort to raise my grades in high school and graduating with a 4.0
When I first got it with 27,000 miles
Starting in 2009 I started modding the WRX and spent less time working on my other project car.
First thing I did was bought springs and shortly after got my wheels.
After that I didn't do much for a while except a JDM scoop and Rear Ground Effects and APS Cat Back (bought used)
I got my STi pink sway bars after that and did some autocrossing, I found out that this can get expensive with tires and what not so I haven't done very much recently.
After this I really got an itch to add some more power so I started doing some research and accumulating most of the parts for my engine modifications.
I picked up some parts and then proceeded to install them all at once.
ehawthorne521 is offline   Reply With Quote
Old 09-03-2012, 02:54 AM   #2
ehawthorne521
Member#: 149686
Turbo and intake manifold off
New parts going back on.
and all done
Off to the tuner
So I actually had to have my car tuned twice because I had a boost creep issue and had buy my uppipe and external wastegate and install it.
If you haven't noticed I really like APS products but since they arent made any more they are getting harder to come by so when a Racing Fuel system made by APS came up for sale brand new in box I snapped it up fast.
I had to get an adapter plate to make it work with my Intake Maniold.
After that I havent done too much except acquire my JDM exterior parts like the headlights and grill, I bought a real one after getting rid of a replica I had for a while.
More recently I got my front lower control arms, roll-center kit, and coilovers along with Kartboy endlinks.
I will update as I get more parts, a Cusco header should be my next modification and then probably moving on to update the rear suspension after that.
Hope all enjoy my
-Evan
Old 09-15-2012, 12:33 PM   #3
ehawthorne521
Member#: 149686
Got a Borla header and some DEI titanium wrap. Had to go with Borla since I couldn't find many other brands that offered two bolt up pipe flanges.
Old 09-23-2012, 03:59 AM   #4
ehawthorne521
Member#: 149686
Just got the header on tonight and it might have been one of the easiest installs that I have ever done. I bought wrap with it but decided not to use it after reading some things about it get oil soaked by accident and burning the car to the ground.
The tone has changed a little but over all I'm very pleased. The quality and fit was good and price was great.
Old 09-30-2012, 09:27 PM   #5
ehawthorne521
Member#: 149686
I never really get to hear my car except when I'm driving it! So I made this to see what it sounds like outside the car.
Old 09-30-2012, 09:41 PM   #6
gsmith304
Member#: 302159
Sonic Yellow
I really like the how the lettering sticks out on your tires! Nice bug man!
gsmith304 is offline   Reply With Quote
Old 10-01-2012, 04:21 PM   #7
ehawthorne521
Member#: 149686
The UPS guy brought me a present this morning so I got right to work. Beatrush makes some nice stuff!
So I got right to work! It went on super easy! Oil changes aren't going to be as quick though.
I'm hoping not only will this add some protection but also reduce under car turbulence.
Old 12-13-2012, 12:58 AM   #8
ehawthorne521
Member#: 149686
Just finished doing a suede headliner, came out good.
Wish the weather was still nice like this
Happy 12/12/12
Old 12-13-2012, 03:53 AM   #9
a-thomp
Member#: 285774
2003 vf39'd WRX
VERY clean!!! really like your build man! exactly how i'd build a car too, top of the line brands and nothing to extreme, just making everything work better!! love it!!!!
a-thomp is offline   Reply With Quote
Old 01-10-2013, 02:19 AM   #10
ehawthorne521
Member#: 149686
Thanks for the comments
My girlfriend got me a little present, it looks very nice. Beatrush makes some very nice stuff and I'd like to get the radiator diversion plate now too. Any how here is what we are all here for the pics!
Thanks for looking.
Old 02-11-2013, 08:54 PM   #11
ehawthorne521
Member#: 149686
Made my own shift lever. I think it came out nice, especially since the total cost was about
$25
Here is how I did it!
http://forums.nasioc.com/forums/show....php?t=2466830
Old 03-07-2013, 09:32 PM   #12
ehawthorne521
Member#: 149686
Finally took some pictures with a decent camera today.
Got some parts on the way from Turn in Concepts too, once I get them should be posting some more pictures. I am really excited! I haven't done a good parts install weekend in a while.
Old 03-10-2013, 12:52 AM   #13
ehawthorne521
Member#: 149686
More Pictures
Hope you enjoy!
Old 03-10-2013, 04:29 AM   #14
AnthonyT
Member#: 297881
2002 Subaru Wrx
Me gusta!!
AnthonyT is offline   Reply With Quote
Old 03-10-2013, 10:56 AM   #15
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
asi es la vaina
Old 03-11-2013, 12:22 AM   #16
admiral snackbar
Member#: 272810
2007 WRX Wagon
Car looks great! You have one of my favorite sedans. It's just clean and tasteful.
admiral snackbar is offline   Reply With Quote
Old 03-11-2013, 02:02 AM   #17
socal_subie
Member#: 341316
Love it man looks nice!!
socal_subie is offline   Reply With Quote
Old 03-11-2013, 02:13 AM   #18
ehawthorne521
Member#: 149686
Thanks I appreciate it!
Admiral Snackbar, your username makes me laugh everytime! Very creative, and thank you for the comments!
Old 03-18-2013, 03:31 AM   #19
ehawthorne521
Member#: 149686
My finals are done on Monday and some new parts are arriving Tuesday... Perfect timing! Ill post some pictures when I get them and install the new parts.
Old 03-20-2013, 05:43 AM   #20
ehawthorne521
Member#: 149686
Got my Carbing Rear Strut Tower Bar and Turn In Concepts Fender Cowl Brace today and installed them both. RallySport Direct always comes through with fast shipping.
I also got the Kartboy Rear Subframe Lockdown bolts too, those will go on once I get some more goodies from TiC later this week.
Here are some pictures
I had to cut the package tray to get the bar to fit, luckily you can't see it when the seat is in. I tried to keep it as neat as possible.
Done... almost
Seats back in, it tucks really close to it.
Little comparison of the braces. Very nice parts, I can not wait to get my other parts from Turn in Concepts.
Installed, this was much easier than I thought and actually took less time than the strut tower bar.
I'm happy so far, the weather has been too crappy to see if there is a handling difference but my car seems to have less rattles which is very nice.
More to come soon!!
Old 03-20-2013, 08:30 AM   #21
blue sedan
Member#: 311622
2010 WRX
Very, very nice build.Good job!
blue sedan is offline   Reply With Quote
Old 03-20-2013, 01:14 PM   #22
ehawthorne521
Member#: 149686
Thanks! I appreciate it!
Old 03-20-2013, 01:33 PM   #23
liltoua
Member#: 206802
1998 2.5rs
Clean Bugeye! That's an interested rear strut bar...never seen one that comes uptop
liltoua is offline   Reply With Quote
Old 03-20-2013, 01:56 PM   #24
1VIPWRX
Member#: 107554
yellow
love the car and mods.. keep it up
1VIPWRX is offline   Reply With Quote
Old 03-20-2013, 01:58 PM   #25
chrisbolton
Member#: 216597
I'm loving this build so far man, looks great!
chrisbolton is offline   Reply With Quote
