Old 04-06-2011, 02:23 AM   #26
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Originally Posted by makopolo View Post
Great it wasn't autoX or I was going to say u were doing it all wrong. BTW nice ride.
Thanks a lot man.
breaksOFTEN is offline   Reply With Quote
Old 04-07-2011, 02:17 AM   #27
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Just learned how to do this. I'm digging the way it works with the flag and wheels.
Old 04-07-2011, 04:14 AM   #28
The Database
Member#: 225192
2008 BMW E92 M3
Bat Mobile Black
^^^^Can we make it a NASIOC rule to not allow vortex generators on wingless cars? Rest of the car looks great tho
The Database is offline   Reply With Quote
Old 04-19-2011, 02:16 PM   #29
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
320awhp 360awtq. I'll post the graphs if I can figure out how to use my scanner haha.
Old 11-07-2011, 01:41 AM   #30
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Now pushing 409awhp 406awtq, a bit laggy but holds power to redline
Old 11-07-2011, 02:35 AM   #31
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Shots from Subiefest autoX, by SkimSTI
Old 05-07-2012, 02:45 AM   #32
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Status update:
I've been extremely busy with school and work so the car has not had much tlc lately, and I've got a small pile of parts waiting to be installed.
Recently I noticed the APS turbo was leaking oil constantly, so I sent it in to be checked out. It was the oil drain line gasket 0_o
I reinstalled the turbo late on a Saturday night in a hurry to AutoX the next morning and carelessly lost a turbo stud down the up/pipe. I didn't have all my tools with me and I was in a hurry so I came to the conclusion that the bolt dropped to the ground and I just could not find it. Well a quick drive down the street proved that theory wrong The bolt fell down into the exhaust manifolds and got sucked up into the turbine wheel.
Sooo now the turbo is back being repaired/upgraded with a gtx center cartridge and a mild PnP.
When the turbo goes back in I will also be installing a MSD fuel pump booster to try and squeeze a bit more power out of the e85 set-up. Should see mid 400's
Old wheel, new color
Old 08-06-2012, 08:33 PM   #33
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Center cartridge upgraded to the gtx
25psi tune on E85, and 20psi on 91
Old 01-27-2013, 10:53 PM   #34
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Well 450whp was fun while it lasted... ~5k miles.
Failed head gasket or improper torquing on the heads caused coolant to get into cylinder #4, then with the piston coming up it hydro locked and the top of the block broke and blew out. Also the rod in cylinder #1 was bent too (Manley H beam).
So back to a stock block and stock turbo while the broken block is sleeved and built up to handle 30+ lbs of boost.
Old 03-07-2013, 10:39 PM   #35
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
I got too lazy to go dig my stock turbo up out of storage so I threw the gtx30r back in. I have a tune appointment set for Wednesday and I'm just going to shoot for 20-22lbs on E85
Old 04-03-2013, 06:13 PM   #36
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Road tuned ~20 lbs of boost, probably making about 430 whp. Tuner added a lot of timing early to get the turbo to spool up real fast. Car feels great again.
Old 04-07-2013, 04:58 PM   #37
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
Old 11-26-2013, 02:18 AM   #38
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
APR GT3 mirrors purchased and installed.
Bought them used for $40 and had the bases sand blasted and powder coated, then swapped out the lenses. Just have to spray the mirrors with some new clear coat.
Old 07-30-2015, 05:55 PM   #39
breaksOFTEN
Member#: 260549
'69 Camaro '76XS750
'77CB750
^^^ broke that block too. Cracked a ring land and learned why using very thick oil is not a good thing for a car that does a lot of sitting around. trashed the bearings and got rod knock.
Engine is fully built again.
Mahle pistons
Manley rods
New STI crank
ACL race bearings
Fully balanced internals, flywheel, and pressure plate
ID1300 injectors
I fully assembled the engine this time around, I had a machine shop do the work and take the measurements for me, but I did all the install work.
I am also doing the tuning.
The car is back on e85 but on the stock turbo and stock TMIC and stock intake. basically just a turbo back and large injectors for the e85
I'm making about 350whp and 445wtq right now on 24lbs of boost, but I have yet to adjust the timing to take full advantage of the higher octane. So we'll see how much I can squeeze out of it.
on 91 I stopped at 295whp and 340wtq, but those are just virtual dyno numbers. who knows how accurate they are
Fun snowball fight game (WT1999, but still as fun as always) - link and video inside Kaiser Off-Topic 53 02-07-2012 12:34 PM
P1133 CEL, replaced o2 but still has CEL? jmgtp Normally Aspirated Powertrain 1 07-31-2006 11:51 PM
sold my car but still have 5 weeks on autotrader azimiut Off-Topic 2 07-23-2006 02:22 AM
OLD, but still has teh funnAy... Spheris Off-Topic 3 03-15-2005 03:00 PM
Whoo Hoo!! (not a car but still a picture) NWWagon Member's Car Gallery 26 10-11-2004 09:38 PM
