Old 03-07-2013, 11:17 AM   #1
SubbieNoob
Member#: 305546
2016 WRX
Default Do I need new valves?
Hello I recently got into an accident, and my cam gear cracked due to my front mount piping. It didnt hit it straight on, but stalled out the engine. It cracked from the side, but the belt seems to be intact.
SubbieNoob is offline   Reply With Quote
Old 03-07-2013, 11:20 AM   #2
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
If the cam gear didnt actually break apart and the belt didnt snap then most likely you should be ok. No way to know 100% until its replaced and you start the motor.
boosted25 is offline   Reply With Quote
Old 03-07-2013, 11:22 AM   #3
SubbieNoob
Member#: 305546
2016 WRX
Thank you, I have pictures of it, it will be posted when I get a chance.
Old 03-07-2013, 12:06 PM   #4
CrashTestRacer
Member#: 66394
2004 WRX Wagon
Did you try to start the car afterwards? Don't until you figure out what state the timing is in.
Even with everything still relatively intact, you could have skipped teeth on the belt. Check the timing marks if you can.
CrashTestRacer is offline   Reply With Quote
Old 03-07-2013, 12:51 PM   #5
paulpat
Member#: 237145
02 WRX
12 FXT
Yeah I wouldn't want to start the car either. I guess the only way to know is crank it by hand with a breaker bar and see if you get any resistance. Remember to remove the spark plugs.
paulpat is offline   Reply With Quote
Old 03-07-2013, 01:39 PM   #6
SubbieNoob
Member#: 305546
2016 WRX
I never tried to start it. The gear just seemed to crack on impact, not staright on but towards the right edge of the pulley.
Old 03-07-2013, 10:15 PM   #7
dictoresno
Member#: 139816
2002 WRX, VF34 swap
i would suggest the same as others have. dont start it, but when you can hand crank gently to see if you come across resistance. i highly doubt theres any need for new valves, as the problem is most likely just the cracked pulley. i would unplug the battery to prevent anyone from mistakenly trying to turn it over.
dictoresno is offline   Reply With Quote
