Old 02-27-2013, 11:23 PM   #1351
Jdub.csu
Member#: 283784
2013 EVO X GSR
What a beauty!
Old 02-27-2013, 11:28 PM   #1352
themaus
Member#: 321211
Originally Posted by jockeygolfs View Post
Extreme Turbo Systems FMIC. Finally Shipped TODAY!!!!!
BALLER.
themaus is offline   Reply With Quote
Old 02-28-2013, 06:24 PM   #1353
jockeygolfs
Member#: 260868
2011 STI
The welds are ridiculous on this thing. I'll have more pics when I get it and install it of course.
jockeygolfs is offline   Reply With Quote
Old 02-28-2013, 06:48 PM   #1354
Jdub.csu
Member#: 283784
2013 EVO X GSR
Damn you I want one now
Old 02-28-2013, 07:59 PM   #1355
jockeygolfs
Member#: 260868
2011 STI
Go get you one!
Old 02-28-2013, 09:38 PM   #1356
Jdub.csu
Member#: 283784
2013 EVO X GSR
Go get you one!
I have my process west TMIC right now haha. Probably will when I go rotated
Old 03-01-2013, 12:17 AM   #1357
jockeygolfs
Member#: 260868
2011 STI
Fuel lines, rails and FPR go in on Monday. FMIC comes on Wednesday. Everything (FMIC, BOV, IAT, MAP, Walbro 465) will go in sometime by Saturday.
Going to STIMikey for tuning. Since Mikey comes to Florida often and we can dyno tune it made sense to Phatron that I go with STIMikey. Speed Density here we come.
Old 03-05-2013, 02:51 PM   #1358
jockeygolfs
Member#: 260868
2011 STI
Fuel lines, rails and FPR are in.
Old 03-06-2013, 12:20 PM   #1359
Jdub.csu
Member#: 283784
2013 EVO X GSR
Pics!
Old 03-07-2013, 08:23 AM   #1360
jockeygolfs
Member#: 260868
2011 STI
ETS FMIC Finally Here!!!
Old 03-07-2013, 03:32 PM   #1361
Jdub.csu
Member#: 283784
2013 EVO X GSR
Idk what is better the tial or that core.... Yum
Old 03-07-2013, 10:31 PM   #1362
jockeygolfs
Member#: 260868
2011 STI
Fmic is on. Pics to come
Old 03-08-2013, 12:06 AM   #1363
Jdub.csu
Member#: 283784
2013 EVO X GSR
Can't wait. That core is a beauty.
Have you done a pitch stop mount yet?
Edit* just saw you have the group n. that one seems too squishy to me. I love my Perrin one. It helped with shifts immensely.
Old 03-08-2013, 12:17 AM   #1364
jockeygolfs
Member#: 260868
2011 STI
Here is the FMIC mounted with Tial Q 50mm BOV, Omni 4 Bar Sensor, AEM IAT Sensor
Old 03-08-2013, 12:19 AM   #1365
Jdub.csu
Member#: 283784
2013 EVO X GSR
How did the install go?
T-bolt clamps? Good!
Where is your iat sensor location? Right before the throttle body?
Old 03-08-2013, 12:22 AM   #1366
jockeygolfs
Member#: 260868
2011 STI
Install was fine, it was cutting the bumper that was a PITA. I still need to go back and cut a little more. I forced my bumper on and it is pulling out a little on one side. Yes, all T-bolt clamps. THe iat is between the BOV and throttle body but under the pipe so you can't see it. It is about 60* here right now and I'm getting about *65 from the sensor. Tuning has commenced with STIMikey. Just doing cruise logs for now.
Thanks to WRX02FTW for helping with the install.
Old 03-08-2013, 12:29 AM   #1367
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
What are you using for the intercooler sprayer?
kyletakahero is offline   Reply With Quote
Old 03-08-2013, 12:32 AM   #1368
jockeygolfs
Member#: 260868
2011 STI
Well I have an aquamist HSF-3 kit from when I was using meth. But since I'm on E85 now I have converted it into a sprayer. The bar is a NOS bar. I use straight tap water. It begins to spray as I go into the higher RPMs just like how it would spray meth since it is IDC controlled.
Old 03-08-2013, 12:40 AM   #1369
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
Thank you for the info! That's very cool indeed.. I might have to copy that.
Old 03-08-2013, 12:55 AM   #1370
jockeygolfs
Member#: 260868
2011 STI
Yeah I didn't want to pull it all out in case I have to go back to pump and Meth.
Old 03-11-2013, 04:31 PM   #1371
jockeygolfs
Member#: 260868
2011 STI
Stencil had to go. It was a little much for me to handle.
Engine bay has been tidied up a little.
Old 03-12-2013, 10:00 PM   #1372
jockeygolfs
Member#: 260868
2011 STI
DW300 took a dump while on the Turnpike home. After $125 worth of towing and dinner cost for Themaus for helping me shove the Walbro 465 in I am back up and running.
Old 03-13-2013, 12:33 AM   #1373
themaus
Member#: 321211
Can't say Douchewerkz won me over with your pump going out. Here are pics of a Walbro 465 installed in the housing since some posts on NASIOC say its impossible.
Old 03-13-2013, 08:31 AM   #1374
jockeygolfs
Member#: 260868
2011 STI
And yes, we could have skipped the weather pack connector. Hindsight. Either way it is together. And yes we used heat shrink butt end crimp connectors. If the connectors fail ill be sure to post here to warn others.
Old 03-21-2013, 03:23 PM   #1375
jockeygolfs
Member#: 260868
2011 STI
Well I had some fuel pump issues. Bad relay. Then I soldered my connections in the fuel tank but they ended up not being good so I had to redo it. I over torqued one of the studs that holds the fuel pump house frame to the fuel tank. I have had leaks through the gasket. Etc etc etc.
Finally back on the road. My Aeromotive FPR is not getting the pressure I should be at. It is peaking at 80 PSI when it should be up to 95 PSI when my base pressure is set at 55 psi. My idle vacuum pressure is -10 psi when I'm shooting for 25 psi at full boost.
I purchased a Fuelabs 515 to replace/confirm if I have a leak in my fuel system that is keeping me from getting the pressure or if my Aeromotive FPR is faulty.
Fueling has been a real PITA. I'm coming close to giving up and being happy with the power levels I am at.
Will it fit: 2011 STi Sedan exhaust on 2010 WRX Sedan btr22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 41 02-07-2016 10:44 AM
Forged Performance: 2011 STi Sedan MONSTER Build **check back often** Forged Performance NASIOC Project Cars 461 09-10-2015 12:14 PM
Fast Motorsports Prototype 08+ wrx sedan and 2011+ sti sedan catback! first pics! IMPORTIMAGE Vendor Announcements 4 05-02-2011 09:50 PM
Comparing 2011 STi Sedan to 2011 WRX Sedan DasWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-21-2010 07:09 AM
new with a question about 2011 STI sedan vs. previous STI sedans tommygsubie Newbies & FAQs 37 11-02-2010 12:16 PM
