Old 03-04-2013, 09:12 PM   #1
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
Default 2011 WRX no knock in 3rd but getting knock in 4th
I can't seem to figure out why I'm getting knock in 4th gear and not in 3rd. I have a 2011 wrx with a TP stage 3 tune. The load is the same, every parameter is the same at each rpm of both 3rd and 4th and I'm getting small instances of -1.4 degrees of timing being pulled. Also everytime I reset the map, i wont get knock at all the first time I do a 4th gear pull but every time after that I do. Any ideas?
https://docs.google.com/file/d/0B14A...it?usp=sharing
Mods:
Process West TMIC
Forge BPV
1 step colder NGK spark plugs
DW65C fuel pump
AEM Cold Air Intake
Cobb Downpipe
Grimmspeed EBCS
Grimmspeed AOS
freddy121389 is offline   Reply With Quote
Old 03-05-2013, 12:49 AM   #2
swpshgnwgn
Member#: 150494
11 WRX
SWP Torqued Stg II
Have you talked to Eric? Did he have any ideas?
swpshgnwgn is offline   Reply With Quote
Old 03-05-2013, 06:22 PM   #3
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
He can't figure it out and I've already decided I'm going to go with different means for tuning. Erics a great guy but there lacks a sense of ability to tune a car when he's not actually there with the car while tuning it. He actually revised the map after these logs and the knock got worse, went back to his previous revision and got the same knock so it's not the car it's definitely the tune. At stage 3 I kind of wanted to get "pro tuned" anyway.
Old 03-05-2013, 07:05 PM   #4
swpshgnwgn
Member#: 150494
11 WRX
SWP Torqued Stg II
Absolutely. He does what he does well, but at a point it becomes difficult to tune when the car isn't physically there. Wish I could offer some advice for you. Good luck getting a resolution.
Old 03-07-2013, 03:03 PM   #5
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
I don't believe they do open source, but IAG and MachV would be great places for protunes in your area.
Old 03-07-2013, 10:40 PM   #6
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
IAG is stricktly AP or AEM, Mach V does do Opensource but I'm actually going to go with Element Tuning.
