Old 03-07-2013, 01:12 PM   #51
nystateofmind308
Member#: 332064
2008 WRX Automatic
Originally Posted by the suicidal eggroll View Post
I don't even know what kind of car you have, you should fill out your profile.
You can always download RomRaider and the factory tune from your car and see for yourself what the cranking IPW vs throttle position table looks like, but I doubt it's any different than the MT version.
I have an AUTO WRX 2008 Sedan. As for RomRaider, I'm a bit scared to ef with my ECU. I know the stock map is sitting on my AP but have no idea how to extract it. Plus, it seems like a bit of overkill over one fuse?
nystateofmind308 is offline   Reply With Quote
Old 03-07-2013, 01:27 PM   #52
Member#: 51961
2005 STi
You're not touching your ECU at all, just opening up a stock map on the computer to see what it looks like. Since you're running an AP though you can do the same thing with ATR.
Either way, here's your cranking IPW acc compensation from the 2008 WRX Auto:
It's the same as all the other DBWs, anything over 90% throttle cuts all fuel during cranking.
Old 03-07-2013, 01:44 PM   #53
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
Originally Posted by nystateofmind308 View Post
But i have an automatic...will it work
Flooring it will indeed work to cut fuel. Antitheft mode will work as well. Fuel pump relay is driver's side under the hood.
Automatic or standard, it is the same.
Hoon Goon is offline   Reply With Quote
Old 03-07-2013, 02:21 PM   #54
nystateofmind308
Member#: 332064
2008 WRX Automatic
wow. awesome. Thanks man!
Old 03-07-2013, 02:22 PM   #55
nystateofmind308
Member#: 332064
2008 WRX Automatic
i shall attempt all of these as well
Old 03-07-2013, 08:40 PM   #56
oh jesus h ****ing christ
Old 03-07-2013, 08:44 PM   #57
10x easier method is to just floor the throttle while you're cranking (assuming it's a DBW model). Anything over around 80% throttle (forget the exact number) turns off the injectors during cranking. Pulling fuses is a complete waste of time, so is flashing any new map.
pulling the fuse is a 100% sure way to disable starting
idiots can forget to hold the pedal to the floor....because they ARE idiots
LOTS of idiots around.....proof is in this thread
NEVER underestimate an idiot
if the fuse is out, car can NOT start.....and the rest???
yeah...
Old 03-07-2013, 09:51 PM   #58
Member#: 51961
2005 STi
Truer words were never spoken...
Old 03-07-2013, 09:55 PM   #59
nystateofmind308
Member#: 332064
2008 WRX Automatic
yeah...
Uncle, I will be trusting your method. Unfortunately, there is no ING fuse in my box. But there is the Fuel Pump Relay under the hood. Apparently, that will do it. 08+ doesn't have and ignition cut off....
Old 03-08-2013, 12:02 AM   #60
well ****....just another thing to hate about the gr
easiest way to prime turbo 2wickedWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 04-22-2008 10:50 PM
change my oil before prime turbo? simprezl25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-07-2007 02:32 PM
trying to prime turbo, engine not cranking JDM 3SGTE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-15-2006 10:47 AM
priming turbo bradze Service & Maintenance 7 02-28-2006 02:08 AM
in the process of priming turbo. do i need to unplug all 4 coil pack? VajraTLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-30-2005 09:05 PM
