Old 03-08-2013, 08:07 AM   #26
CrashTestRacer
Member#: 66394
2004 WRX Wagon
^ you're funny. You can't look at these engines for less than 2k.
I did pretty much what you said, parts alone were around 2.5k. Don't forget the oil cooler and oil pump, too, in addition to the other things that you WILL find you need to replace while you're there.
CrashTestRacer is offline   Reply With Quote
Old 03-08-2013, 10:21 AM   #27
matt824
Member#: 348181
2005 WRX
How much should I sell my block for that has the spun rod bearing?
matt824 is offline   Reply With Quote
Old 03-08-2013, 12:06 PM   #28
danger1138
Member#: 279525
04 rex luger!
Is it a built block? Pardon, didnt read the thread.
danger1138 is offline   Reply With Quote
Old 03-08-2013, 02:11 PM   #29
matt824
Member#: 348181
2005 WRX
Stock block with spun rod bearing
Old 03-10-2013, 08:53 PM   #30
ex2si
Member#: 321977
Default :)
sounds what happen to [email protected] so i just slapped on my old head onto a new complete block 1,920$ timing belt kit water pump 260$ oil pump 150$ Gasket Kit 250$ and lots of time. reuse the the head bolts clean the treading with a metal brush and brake cleaner. clean out the oil pan i used purple power to clean the oil and metal shavings use a gasket maker sealant on the pan and slap it back on caution there is a small o ring on the inside corner of the pan dont loose it good luck and have fun...
ex2si is offline   Reply With Quote
