Old 03-08-2013, 03:15 AM   #1
Nikryj
Member#: 346659
Default First log, very short.
I'm going to be taking a longer more "spirited driving" log tomorrow but I just installed my AP and I have been messing around. From what I have gathered, an AF Learning 1 of 0 and a knock of 0 is great. My AF learning seems to sit at 2.4 when I'm giving it some gas. I'm going to guess it is within acceptable ranges? It's a 2003 WRX stage 2 OTS at 93 octane.
https://docs.google.com/spreadsheet/...lE&output=html
Nikryj is offline   Reply With Quote
Old 03-08-2013, 04:41 AM   #2
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Um...that was rediculous. All that for 3 seconds of almost WOT.
AF Learning between + / - 5% is normal. There are four ranges: A, B, C, and D. AF Learning 1 is a way to log one thing and capture the currently applies AF Learning value regardless of which range it is from. It is a learned parameter so it takes driving time (about a tank) to get accurate readings.
When you take your longer drive, just post one WOT run from about 2000 to redline, prefereably in thrid gear.
jebjkey is offline   Reply With Quote
Old 03-08-2013, 08:35 AM   #3
Cobb Tuning
Member#: 4803
Hi there.
Generally driving doesn't tell you a whole lot. You want to put the car under some extended high load to see how it responds. The best way to do this is a 3rd gear run from around 2500 RPM on up but only if you can do so safely. Check out our data logging video below for details:
Bill
Old 03-08-2013, 12:44 PM   #4
Nikryj
Member#: 346659
Yeah, I figured it wasn't much. It was 3am here when I did it, I couldn't do too much WOT
