#26 | |
Member#: 72829
W. Canada
Vehicle:2006 HTA68'd wagon Powered by RomRaider |
#27 |
Member#: 245156
Vehicle:2005 STI Silver |
yes i could see that being an issue also which is why i might try to bypass that. But if the stumbling is due to pulsation or noise and in my case see more noise with dampers. There are others that have seen success with no dampers so I cant see it being an issue.
#28 | |
Member#: 72829
W. Canada
#29 |
Member#: 245156
Yes but wouldn't you see any side affects in the learning view
#30 |
Member#: 124282
Vehicle:04 WRX Wagon PSM 13 STI Sedan SWP |
Oops.
#31 |
Member#: 124282
#32 |
Member#: 245156
#33 |
Member#: 124282
#34 |
Member#: 72829
W. Canada
#35 |
Member#: 124282
#36 |
Member#: 245156
I ended up totally fixing the problem. My comps are all zeroed out and no stumble.
No dampers with an after market FPR. Runs better than ever. |
#37 |
Member#: 203327
Vehicle:2002 WRX Silver |
The rails with larger injectors + tuning gave me ZERO stumble. Its phenomenal to drive a car that feels normal again
#38 |
Member#: 245156
#39 |
Member#: 203327
#40 |
Member#: 53565
Vehicle:2008 OBP STi SQC 278 |
Guys, when you zero the comp tables? Does your ecu still able to make fuel correction? I'm on Cobb race tuner and both my correction and learning wont budge from zero after zeroing out the load comp tables. Any ideas?
#41 |
Member#: 11205
RMIC
Vehicle:2009 WRX Dom3-e85-ewg |
Zeroing out that table does not effect fuel correction. Sometimes randomly after a reflash the o2 sensor takes a while to warm up. Restart the car and it should come back.
#42 |
Member#: 53565
Thanks for the quick response. I might have zeroed out the wrong tables since I'm using race tuner. Its under the close loop target load compensation a&b tables. Is it the right one?
#43 |
Member#: 11205
RMIC
Wrong table.
No its in the sensor calibrations tab. Load Compensation (Manifold Pressure)(Accel) Load Compensation (Manifold Pressure)(Cruise) |
#44 |
Member#: 53565
Thank you!
| Thread Tools | |
| Display Modes | |
| Did you pass OBD-II test with Accessport stage 2 and upipe resistor fix? | MO REX | Engine Management & Tuning | 4 | 11-24-2004 07:12 PM |
| Are fixes required with AccessPORT | REX Tuner | Engine Management & Tuning | 5 | 04-06-2004 09:14 AM |
| Stumbling with ECUtek Part 2 | wRxbeater11 | Engine Management & Tuning | 1 | 03-27-2003 05:25 PM |
| Stumbling with ECUtek | wRxbeater11 | Engine Management & Tuning | 16 | 03-23-2003 03:17 AM |
| Anyone with Borla header and CEL, did the ECU recall fix the CEL? | Suba_Roo | Normally Aspirated Powertrain | 14 | 01-25-2003 12:53 AM |
