Old 03-01-2013, 04:05 PM   #1
Helpmyrex
Member#: 346614
03 wrx
Default Car acting weird, Any input
Recently switched ecus since mine crashed. Running stage 2 with stock intake.
With this ecu my car idles at 900... used to sit at 500 with not problems on old ecu.
If i accelerate quickly entering a superior gear, it lags, until i let off and slowly accelerate. If i slowly accelerate and then floor it at high rpm then it will pull like normal. If i step on it at low rpms it lags!!
Recently went stage 2, could I have forgettin to plug a hose or accidently pulled a hose off or something when I installed the turbo back?
Also when idling the oem boost gauge keeps moving from -.7 to -.05
Any input please?
Did check engine light is on, i will get it checked asap and post it up
Helpmyrex is offline   Reply With Quote
Old 03-01-2013, 04:15 PM   #2
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
the issue is probably whatever the CEL is on for, my guess is some sort of vacuum/boost leak.
Did this start happening right after you switched intakes? Or right after you got tuned for stage 2?
jayman4312 is offline   Reply With Quote
Old 03-01-2013, 04:16 PM   #3
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
On Turbo Dodge cars like yours, this is all pretty standard. (Read, we have no idea what car you're driving. Please fill in your profile the rest of the way.)
What ECU are you using, a factory one? What Stage 2 map are you using? Stock intake... Full TBE, which one?
Idle on my old turbo'd car used to sit between 500-900, depending on engine and outside temperature. so that sounds normal to me.
Stepping on the throttle at low rpms and lagging is the definition of a turbo'd car. It's what they do.
Boost moving from -0.7 to -0.05, I'm assuming this is in Bar? so that's -10 to ~-1 psi at idle. If memory serves, your boost will be idle when under vacuum (idle), though probably shouldn't be fluctuating that much. Unless you meant -0.5, in which case, I wouldn't worry about it.
You shouldn't have touched any hoses when doing a TBE.
Find out what the CEL is.
Old 03-01-2013, 04:16 PM   #4
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
Can you post a datalog?
findurpath is offline   Reply With Quote
Old 03-03-2013, 05:35 PM   #5
Helpmyrex
Member#: 346614
03 wrx
sorry guys its a 03 wrx with cobb stage 2 map.
catless turboback/uppipe on stock intake
I also have noticed that if i start it more then once in a day it wont start... just keeps turning over and over and over. I can start it once it the am, but if i turn it off and try again it wont start.. unless i let it sit for like 5-6 hours then it may start again. This is really weird, i have let it sit all day so i can drive it to auto parts and have the check engine light checked. I will be back with an update as to why the check engine light is on.
Old 03-03-2013, 05:36 PM   #6
Helpmyrex
Member#: 346614
03 wrx
I never switched intakes. My old ecu blew so i bought one off another user here, he said it had stage 2 map on it. Car ran good for like 2 weeks then this happened.
Old 03-03-2013, 10:41 PM   #7
Helpmyrex
Member#: 346614
03 wrx
so it was the hose that runs from the inlet hose to a sensor. Its the thinnest one, looks like the previous owner ripped it and taped it together lol. I must have it hit and caused it to split again. I retaped it for now, is there a adapter or something I could buy to reattach it somehow ? Does anyone know the size this hose is?
Or is it best to replace the whole hose itself, it will be a pita trying to get the hose off the adapters.
Old 03-04-2013, 10:59 AM   #8
Helpmyrex
Member#: 346614
03 wrx
any input?
Old 03-04-2013, 11:03 AM   #9
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
i would not run any hose of any kind with tape on it to fix a leak or tear. i would replace the hose with a full functional (no leaks) one ASAP.
07VTRex is offline   Reply With Quote
Old 03-07-2013, 05:30 PM   #10
Helpmyrex
Member#: 346614
03 wrx
well i replaced the hose with a new one.. I'm still having the same issues. Car not starting, rpm jumps up and down if it does start. Recently it hasnt started it all since last time i drove it. SOmeone PLEASE HELP
Old 03-07-2013, 07:37 PM   #11
DZXN
Member#: 306186
2002 Subaru WRX
So you bought an ecu with a map on it, dude who sold it says there is a stage 2 cobb map on it? Where did he live, what fuel was it tuned for (91, 93 oct, or???), what year ecu, and what intake was mapped? If stuff started changing after swapping ecu's, best bet would be in the map.
Buy an AP, or get it tuned for your stuff. With out knowing what that particular ecu has mapped on it you are driving a crap shoot. If it was a buddy that sold you something, that's one thing, some dude on the Internet is a whole different ball game.
DZXN is offline   Reply With Quote
Old 03-07-2013, 10:41 PM   #12
Helpmyrex
Member#: 346614
03 wrx
Goood ****
Old 03-07-2013, 10:48 PM   #13
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Wow. Is the "new" ECU even for an 03 WRX?
Stop driving your car.
Get an AP and load a stage 2 map for the fuel that you use. If you still have problems then take your car to a professional.
Curiousity is killing me. How did the original ECU crash?
jebjkey is offline   Reply With Quote
Old 03-07-2013, 11:11 PM   #14
Helpmyrex
Member#: 346614
03 wrx
Yes the new ecu is off a 02. Original ecu crashed when i was reverting it to stock. I walk away for the first time while its flashing and it says low voltage when I came back. Car didn't respond after that when I tried to start it.
Old 03-07-2013, 11:15 PM   #15
Helpmyrex
Member#: 346614
03 wrx
Yes he said its a cobb stage 2 map, on a 02 ecu. He said he only had turbo back.
Old 03-07-2013, 11:51 PM   #16
jebjkey
Member#: 73884
16 HyperBlue STi
I do not know if 02 and 03 ECU's are compatable. You should have sent your ECU to Cobb to see if they could fix it. If you still have it, maybe Cobb can help you get it back working.
Did you flash your 03 WRX stage 2 map to the ECU or not?
If not, do not drive your car until you flash an 03 WRX stage 2 map to the ECU. If you have a v2 AP (has the color screen) then you do not need to do anything different to flash over whatever map is already in the ECU. If you have a v1 AP (non-color screen big black brick) then you will need Cobb's help.
Old 03-07-2013, 11:53 PM   #17
jebjkey
Member#: 73884
16 HyperBlue STi
Reading your posts and letting curiosity take over again.
What did you do after you returned to the car and saw low voltage?
Old 03-08-2013, 07:20 AM   #18
Helpmyrex
Member#: 346614
03 wrx
I retried the "Revert to stock" flash & let it complete but no good results in the end.
Well after looking around alot online I came to the conclusion that 02 03 ecu's are the same for bugeyes and can be used on each model.
The new ecu i got already had a stage 2 map on it
Old 03-08-2013, 08:28 AM   #19
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
The ECU you got has what you are told has a Stage 2 map on it. You dont know for sure though, do you.
Old 03-08-2013, 08:39 AM   #20
jebjkey
Member#: 73884
16 HyperBlue STi
Dude, just flash your stage 2 map to the ECU and see what happens. It certainly cannot be any worse.
Old 03-08-2013, 12:19 PM   #21
Helpmyrex
Member#: 346614
03 wrx
I ordered a stock ecu, won't drive car until it arrives
Old 03-08-2013, 03:19 PM   #22
Scanyland
Member#: 282593
1996 Subaru Legacy
why are you ordering a stock ECU now. Have you tried to tune the current ECU to your car?
Scanyland is offline   Reply With Quote
Old 03-08-2013, 09:34 PM   #23
jebjkey
Member#: 73884
16 HyperBlue STi
THIS.
Old 03-08-2013, 10:18 PM   #24
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
So when you brought your car to a local tuner to have the tune checked, he said what?
For one to just check doesn't cost much and they'll be able to give you a good idea if you'll be ok or not.
Old 03-11-2013, 08:03 AM   #25
Helpmyrex
Member#: 346614
03 wrx
THIS.
Sorry for the late reply, but the 2nd ecu I purchased came with a v1 accessport married to it. Unfortunately no matter what I tried the AP just kept saying cannot communicate with ECU. I purchased it off here and the seller claimed the ecu had stage 2 on it alraedy.. It ran for a week until the car stopped starting. Last night I noticed when I turn the car to "ON" the fuel pump WONT STOP priming.. So this ecu is bricked too right?
Anyways, i purchased yet ANOTHER ecu of a user on here who claims his is STOCK. Can anyone tell me correct procedure to change ecu? Should I disconnect the battery? I don't wanna mess this up. If this ecu fails I will surely be sending my original to COBB.
