Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 01-09-2013, 10:26 PM   #201
Frankh21
Member#: 295776
2005 SAAB 9-2x Aero
Originally Posted by Masher View Post
Thanks but I've had enough of used parts and messing with the steering on my car and potentially damaging the rack. I'm going to check with dealers and if the pump is under $300, I'm buying one.
Goodluck finding one at the dealer for less than that. I just bought a brand new one for close to $500 but it gives me peace of mind since the other rebuilt stuff is pretty much crap.
Frankh21 is offline   Reply With Quote
Old 01-14-2013, 01:28 AM   #202
Sky92x
Member#: 101862
2005 92-x Aero
Arctic Silver
I want to replace just the o-rings and not the bearing/seal.
As long as I don't touch the bearing/seal i should be OK right? Doesnt' seem like everyone here is replacing them.
Sky92x is offline   Reply With Quote
Old 01-19-2013, 03:42 PM   #203
NutBucket
Member#: 90804
'15 SJ, '05 GG
QUACK!!
A new one should be a little over $400 online. Sucks but at least its the only expensive thing that's needed replacing aside from tires. Can't complain too much
And yes, you can just replace the rear o-ring if you like.
NutBucket is offline   Reply With Quote
Old 01-21-2013, 01:36 PM   #204
boricuajdm
Member#: 338704
Ive done everything mentioned in this thread except for the bearing. Im getting no air in the resovoir but the power steering wont work when Im idling, but once I get going the power steering kicks in and it feels great. Can anybody help?
boricuajdm is offline   Reply With Quote
Old 01-22-2013, 07:42 AM   #205
WRXFanDave
Member#: 151245
2006 WRX Wagon
A couple longshot guesses... Is the belt tight enough? Is your fluid fresh (enough)?
WRXFanDave is offline   Reply With Quote
Old 01-22-2013, 03:55 PM   #206
boricuajdm
Member#: 338704
I checked the belt and it seems tight enough.I also changed the fluid when I changed the orings on the power steering pump.
Old 01-22-2013, 04:06 PM   #207
Subarukenny d
Member#: 319145
2001 Legacy
Wintergreen
Default Power steering pump prob on my 01' Legacy
As its getting colder out when I go to start my car in the morning the power steering pump whines like a bad ass out of hell. I flushed the fluids once already and the levels are where they should be, anyone know what I could do to fix my problem?
Subarukenny d is offline   Reply With Quote
Old 01-22-2013, 04:36 PM   #208
f4phantomii
Member#: 58504
2004 STi w/o wing
Aspen White / Silver
I just rolled over 90k on my '04 STi and in the last couple of months have noticed some intermittent steering issues.
Once or twice I've heard the belts squeal just a smidge and it goes away quickly.
I've also noted on startup a few times the power steering is a tad sluggish to respond. It lasts only a fraction of a second and then it's fine.
Fluid level is good and I don't detect any leaking fluids.
I'm hopeful I just need the belts replaced. I ordered them last night along with a belt tensiometer. But now I'm thinking I really ought to do the timing belt too.
f4phantomii is online now   Reply With Quote
Old 01-22-2013, 06:15 PM   #209
Subarukenny d
Member#: 319145
2001 Legacy
Wintergreen
Alright thanks, I really hope that I can get it figured out. Instead of going to the dealer and getting a new 440.00$ pump I will get one from a junkyard and rebuild it myself for cheap.it will take some troubleshooting but I think I can solve it! Thanks, I will keep ya posted.
Old 01-22-2013, 10:14 PM   #210
04furesterXT
Member#: 73223
2009 STI
Probably doesn't help but i've had the rack and pump replaced after numerous leaks, o-ring and fluid changes and it it still makes noises at full lock.
Poor engineering plain and simple.
04furesterXT is offline   Reply With Quote
Old 01-23-2013, 06:44 AM   #211
hoffmanEstates
Member#: 122043
04 wagonier
psm
At full lock aren't they built to relief the.psi so **** don't go kaboom?
hoffmanEstates is offline   Reply With Quote
Old 01-23-2013, 07:44 AM   #212
adecan
Member#: 277425
02 WRX
Great thread.
adecan is offline   Reply With Quote
Old 01-23-2013, 09:58 AM   #213
Subarukenny d
Member#: 319145
2001 Legacy
Wintergreen
Yea I think the filter could be bad too... If I do the flush and the rebuilt pump miles as well do the filter as well. I don't know Exactaly where it is located tho. If someone could help me out. Usually they're the same on most 2000 Subarus.
Old 01-27-2013, 06:08 PM   #214
berge56
Member#: 56754
2004 Hybrid 2.5XTR
RIP Chris@EFI
Ordered parts for my 04 WRX. Thanks for all the info guys!
berge56 is offline   Reply With Quote
Old 01-28-2013, 08:01 PM   #215
Subarukenny d
Member#: 319145
2001 Legacy
Wintergreen
RockAuto is looking like the best option now. They have a really low price and I'm really tired of all the probs that the stock one has been giving me. Thanks for the help guys! I will post some stuff afterwards.
Old 01-30-2013, 04:37 PM   #216
vnikulin
Member#: 134247
2012 STI
has anyone rebuilt 08+ power steering pump ? any master lists for parts needed? thanks!!
vnikulin is offline   Reply With Quote
Old 02-09-2013, 03:42 PM   #217
06wrx420
Member#: 226524
2006 WRX
For the record my o ring below the banjo bolt was leaking and I could not find a replacement at any auto store. It is a -014. All I could find was a 014 I must think that the dash means something. And that one does not work. Any way I ended up finding a -014 at a cat store for heavy equipment. They had a ton of o rings for anyone trying to find just one or two. I didnt ask for all the sizes for a complete rebuild but after seeing their o ring selection they probly have all of them. Just wanted to make it easier for some one else to find what they need.
06wrx420 is offline   Reply With Quote
Old 02-16-2013, 10:09 AM   #218
WRXFanDave
Member#: 151245
2006 WRX Wagon
Can you post pics of the top, front, sides, and rear? Then maybe we can give some input based on other model years.
Old 02-24-2013, 04:27 PM   #219
Drk93TT
Member#: 291274
2004 Impreza WRX STi
I just ordered from McMastercarr:
1x MS28775-015 - FEP Encapsulated
1x MS28775-017 - FEP Encapsulated
1x MS28775-021 - FEP Encapsulated
1x MS28775-037 - FEP Encapsulated
1x MS28775-136 - FEP Encapsulated
3x MS28775-014 - FEP Encapsulated
100x MS28775-013 -Buna N per post #9 (couldn't find a single so got 100 for like 2.37 lol)
My pump is leaking all over the place.. and this after I replaced my RH valve cover gasket which was leaking onto exhaust.. now the pumps leaking on the exhaust/down front of timing cover a bit 3 months later !
Drk93TT is offline   Reply With Quote
Old 02-28-2013, 06:30 PM   #220
TheArtOf_Fast
Member#: 347271
07 Impreza STI
Default correct o-ring sizes
Well I had a long drawn out reply to this thread with pictures and all. but it's been about 3 weeks now and still hasn't been "approved" by the moderators. so here is my shortened version.
the o-ring all the way in the center of the pump is wrong. OP has dash 21 listed as the size, but that o-ring (especially in FEP) is way too thin as other have posted. I used a dash 119 FEP ring with EXCELLENT results, plenty of power steering at idle and no noise. The dash 21 O-ring doesn't seal properly with the pump half and as a result you get low to no power steering at idle.
Also the 07 sti like I have has an extra O-ring in the back outer half of the pump. in addition to a dash 15 o-ring there is also another dash 14 ring right next to it.
and finally, for anyone else doing this, I HIGHLY recomend HBNR green o-rings for everything except the 2 O-rings inside the pump. Use FEP for those (dash 119 and dash 136). reason being the HBNR seals better against imperfect surfaces unlike the fep with is a harder O-ring and doesn't seal quite as well (mine leaked for a while)
happy rebuilding and thanks to 68cadillac for doing the original research and being the first guinea pig
TheArtOf_Fast is offline   Reply With Quote
Old 03-02-2013, 05:47 PM   #221
EnderImprezaWRX
Member#: 302116
2005 Impreza WRX
^are you sure it's just not different for your 07? @theartof_fast
EnderImprezaWRX is offline   Reply With Quote
Old 03-03-2013, 06:13 AM   #222
WRXFanDave
Member#: 151245
2006 WRX Wagon
There have been other posts about using thicker rings where he recommends. And I posted a picture of the extra ring on the 06 pump. Makes sense that it would be on the 07 as well. You can actually see the extra plumbing from the outside of the pump to know if you need it. I can't speak to ring material, but I also used FEP for just the two big rings... More due to cost than anything else, but mine is working well too.
Old 03-04-2013, 12:06 PM   #223
TheArtOf_Fast
Member#: 347271
07 Impreza STI
While there is no way for me to be sure of the inner ring size on a lesser year model than mine, I figured I would post my results to doing this as to help others. I saw a few posts from people who were having power steering issues at idle after a rebuild.
While the thinner o-ring certainly works, it makes for a pump with less output than stock. In fact, I had NO power steering at first, I let the car sit over night and magically had some power steering the next morning(o-ring swelled). AS I can tell the only difference between mine and the older pumps is the extra O-ring as every other seal was a correct fit.
And reason for not using an fep ring for the big back half o-ring, is mine would leak for a few days after assembly there AND from one of the plugs on the pump. had to take it back out and use some rtv to get it to seal 100%. probably am going to replace all the FEP rings i put in there except the 2 inner ones that don't seal externally, as these see the most heat. the green hbnr rings seal better for the outside (leak worthy) o-rings. just a thought.
BTW this thread should be stickied somewhere if it s not!
Old 03-06-2013, 02:15 PM   #224
Drk93TT
Member#: 291274
Update to my original post..
I replaced the 2 inside seals, the big one and the small one were the only 2 I replaced INSIDE the pump itself W/ FEP. Not leaking yet. Hopefully it stays that way... I will update if it doesnt. EXTERNALLY- Also did the sensor on the back with a new o-ring, the bolt one with the spring, and the inlet joint o ring with FEP. A total of 5 replaced all FEP... crossing my fingers they hold tight.
Sidenote..
Also rebuilt my alternator with new bearings, they originally swapped the regulator too.. I installed and had battery light,brake light,r diff temp light on+ No charging...
Removed and they put the OEM regulator back on and everythings back to normal on the alternator.
Old 03-09-2013, 02:32 AM   #225
hadi10
Member#: 159208
2007 wrx 2007 Lmtd
grey
a quick question, my PS pump is leaking exactly as shown on pics on this thread.. I have only 3700 miles on my car..!! its a bit weird to have the pump leak with such low miles.!!!
what could be the reason for such a leak ?
hadi10 is offline   Reply With Quote
Power Steering Pump Rebuild??? stumper302 Normally Aspirated Powertrain 4 10-20-2010 04:09 PM
WTB: Power Steering Pump 2004 WRX. mattius Private 'Wanted' Classifieds 2 12-01-2009 12:01 AM
WTB 2004-2007 WRX or STI Power Steering Pump!! TURBOTOD Private 'Wanted' Classifieds 1 03-19-2009 02:32 PM
power steering pump rebuild cbose Service & Maintenance 1 10-21-2003 04:34 AM
