Old 03-07-2013, 02:00 PM   #351
SeeeeeYa
Member#: 129681
2016 WRX EyeSight
LBP
Originally Posted by Rescuer View Post
is it OK to drill the hole on the back side?
Someone needs to rescue you from doing this.
Read the thread. You don't know what's happening and are going to ruin something until you know how this works.
SeeeeeYa is offline   Reply With Quote
Old 03-07-2013, 02:41 PM   #352
Rescuer
Member#: 176692
i read it once before, but still learning so there is confusion factor.
read whole thread a 2nd time, am feeling more confident about it. will do this mod and drill the hole where it should go along that spine part.
thanks
i've also checked out your bullet TMIC mod which seems very very interesting.
Rescuer is offline   Reply With Quote
Old 03-07-2013, 04:03 PM   #353
SeeeeeYa
Member#: 129681
2016 WRX EyeSight
LBP
thanks
It's good you took that the right way, more than one have ruined theirs by drilling in the wrong place, or by drilling too far into that "spine," as you call it. What is to be drilled through is an internal tube... and the hole is to be drilled carefully just far enough to enter the outside wall of that tube. That inner tube is an air channel between the bottom of the valve and the top of the diaphragm. After the plug is installed into the end at the bottom of the valve, the little hole that's drilled reopens that tube to atmospheric. The little felt piece over it lets it breathe but protects against entry of foreign matter.
And in response to the question earlier asked about why it wasn't done this way in the first place... It is, in a JDM model, but with a slightly softer spring. The ideal option for an STi is, arguably, the JDM part, if cost is no object. Personally, I think it becomes perfect after this mod.
Thanks for the comment about the BP Mod. You can find more info here.
Old 03-08-2013, 03:15 PM   #354
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
I just did this mod today for $0.00 at work, before heading home. Right away I noticed a better response and enjoyed the lack of hypersensitivity of the bpv from subtle throttle changes. Seems nicer, in the brief driving I have done with it, but it REALLY changed the sounds more than I was anticipating. Also, is it normal to sound so fluttery at lower boost shifts? Its sounds mean at full boost, but is a short stutter sound at mid boost shifts, and super fluttery at lower boost. This is on my 08 wrx, with a Cobb SF intake and a OTS stage one map.
I did this mod in hopes of alleviating a subtle off throttle deceleration boost leak I have been noticing. I don't hear it when I put the stock airbox back on. It is illustrated quite well here:
http://forums.nasioc.com/forums/show...6&postcount=61
A few folks with this sound fixed it by buying an aftermarket bpv or bov. I was hoping this would fix my problem, but I am still hearing it, though now at a higher rpm.
Thoughts?
isotopesope is offline   Reply With Quote
Old 03-09-2013, 10:58 AM   #355
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
so after rereading this thread yet again, i have noticed others describing a fluttering. is this the surge folks are talking about? i am only hearing it during shifts or letting up on the throttle. it is not happening while under boost.
also, what is the consensus on the drilled vent hole? i used a 1/16" (.0625) jobbers drill, and glued a piece of felt like material over it... though others are saying they used a 3mm (.118") and other are saying they used the drill that came with their 1/4-20 tap, which is probably a #7 drill (.201") that is a huge variance in sizes! would using a difference size vent hole essentially "tune" this mod to work differently?
Old 03-09-2013, 11:32 AM   #356
SeeeeeYa
Member#: 129681
2016 WRX EyeSight
LBP
That's my theory, and it works for me. YMMV
http://forums.nasioc.com/forums/show...&postcount=256
Old 03-09-2013, 12:12 PM   #357
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
cool, we'll i am going to stick with the 1/16 hole.
so is that fluttering i am getting the "mini-surge" you think is beneficial? and thus a symptom of why it does "feel" better to drive? the drastic change in noises was unexpected.
i appreciate your theories and experience on this mod, and also am going to make your bulletproof mod myself, whenever i get some time and a turbo blanket and install this DP i've had laying around for way too long.
Old 03-09-2013, 12:26 PM   #358
SeeeeeYa
Member#: 129681
2016 WRX EyeSight
LBP
I wouldn't call it beneficial, it just isn't detrimental. It is, however, as you say, an accompaniment of the change that feels good to drive. I don't hear it myself, my AEM CAI is down in a sealed fenderwell. The reason you hear it is because your intake magnifies ALL intake sounds. I only hear my BPV vent during higher-boost shifts, and it's not all that loud even then.
Your car will like the mods you mention. You will have more power, less heatsoak, and a far more reliable vehicle.
Old 03-11-2013, 05:52 AM   #359
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
there is no appreciable airflow through this hole, only a reference pressure.
so, no.
Old 03-11-2013, 02:03 PM   #360
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
so, no.
cool, thanks. after re-re-re-re-reading this thread, i did come across some references to that. i honestly am finally beginning to grasp the how's and why's of how this mod works. this is my first turbo car and i have a pretty sophomoric understanding how the turbo system works in general.
this fluttery business still weirds me out and is pretty bad at low to mid boost shifts or throttle lifts. i noticed seeeeya's comment:
http://forums.nasioc.com/forums/show...&postcount=191
Originally Posted by SeeeeeYa View Post
Now that I've gotten my WGDC tables to account for the modded BPV I have quicker spool and more power, all from the same 22.5psi I've always chosen. I may change that now .
The light compressor surge I initially got with a quick throttle lift has largely disappeared after tuning my WGDC, AND learning to drive without snapping the throttle shut.
while i still have yet to log anything since the mod, i feel too green to dare start tweaking with my tune myself, but i also think my driving habits are also coming into play too, in terms of trying to not "snap the throttle shut." though sometimes even rolling off the throttle is giving me flutter.
AND i still have that weird squeaky noise, which was the entire reason i did this mod. others with my same noise said the stock bpv was the culprit and went away with an aftermarket one. i just want to get these issues resolved before installing my DP and etc.
Old 03-11-2013, 02:11 PM   #361
gordon75
Member#: 349825
02 wrx
white
I have see people crush the cap but does not always work
gordon75 is offline   Reply With Quote
Old 03-24-2013, 11:02 AM   #362
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
I did this yesterday just for the heck of it. I'm running a Td04 @ 18PSI so i'll likely revert back until i have i have reason to believe the BPV can no longer hold my boost pressure (getting EBCS + retune next week), as the surge is loud and consistent at any boost level.
I spent 30 minutes driving around town giggling like a school girl.
http://youtu.be/g5WvHL-nTRM
mechatricity is offline   Reply With Quote
Old 03-28-2013, 10:45 AM   #363
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
well, my faithful DIY'ers, i've caved in for the bling. C.R.E.A.M. the fluttering was too disconcerting for me, so i reverted my bpv. i then recently bought a forge recirculating one. i installed it last night; it seems to be the happy medium between less hypersensitivity and MUCH less fluttering. i get a tiny bit running the yellow spring, but it's very slight and not often at all. it also cured that annoying squeak i was getting, which is the "hole" reason i tried this mod in the first place.
as a side note, i drilled out my .062" vent hole with a #7 drill, tapped it, then installed a super short 1/4-20 set screw to plug it... i also took a second super short set screw and drilled a .062" hole through it, so i could swap back and forth between stock and modded functionality easily, and also allowing me to experiment with various vent hole sizes, depending on my set screws. i installed a DP, tried the modded function again, but still was not into it, and went back to stock.
cliffs notes: blah blah blah blah blah
Old 03-29-2013, 09:43 AM   #364
SeeeeeYa
Member#: 129681
2016 WRX EyeSight
LBP
I think some of the differing experiences of people who do this mod is the direct result of their driving... and a lack of understanding of how the characteristics of the modded BPV map onto that driving experience.
For example; knowing that their system will now maintain a boost level once developed (say 6-8ish psi), instead of always operating from square one, HOW one manipulates requested torque (mashes the pedal) changes relative to the same car without the mod. Drive without making boost and not much changes. But drive at a more moderate level that involves making a little boost and your pedal use and shifting changes. With the mod, you can make use of that resident boost by shifting smoothly and keeping torque requirements evenly flowing to provide a more muscular, but moderate, acceleration experience.
But ask for torque that involves the same boost, and all you wanted was that one moment of pedal experience so you drop back to where you should have been in the first place... and you get "flutter." It's telling you you didn't work the machine right. Like sticking a sharp stick in its ribs makes it grunt, instead of tapping it on the flank to let it know you want more forward motion.
If you drive to HEAR the BPV vent, you are likely abusing the car by driving amateurishly, and on a graph your requested torque inputs would be a sawtooth. The throttle is your voice, commanding action. Not a request for audience participation.
If you don't consider the changed machine the modded BPV enables, and ask for torque in an incorrect gear, you will push your turbo past its surge line, and get flutter. Again, uneducated pedal use. Get an automatic transmissioned car, it will do your thinking for you.
When driven right you may never even hear your modded BPV vent... until it VENTS! appropriately... like at the shift point of a WOT run. That vent will be distinct, and almost surprising in quality.
But row your poor abused machine like a girl being taught how to drive a manual and your world will be a frustrating mix of clutch stink, jerky bobbing uneven progress, and weird noises from the sadly reined stallion under the hood.
My STi, in example, should flow forward. Authoratatively smooth and powerful, or elegantly regal and with grace. Until the time comes to unsheath its sword, and all hell breaks loose. An STi is not for amateurs. Those with lesser machines in imitation provide comic relief.
Old 03-29-2013, 10:16 AM   #365
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
hmmm, interesting analogies. perhaps i am driving it inappropriately, or rather not adequately adjusted enough to suit the mod, or turbos in general? granted, this my 7th manual vehicle in 20 years, but it is my first turbocharged car. i have only driven n/a prior. it has taken a lot of getting used to the nature of this new beast, in many ways. i must say, personally, i don't often shift past 3k, and typically maintain moderate acceleration levels... even still, i found it hard to avoid that flutter. maybe i do drive it like crap and i am naive.
your earlier comment about not "snapping the throttle shut" had an impact on me, because i definitely have found myself doing that.
i must say though, that weird squeak is what was so unnerving, and i noticed it most often when not even getting into boost and driving super conservatively, without hearing it vent. the forge piece solved that noise, which i am grateful for.
Old 03-29-2013, 10:23 AM   #366
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
You have quite the imagination.
Old 03-29-2013, 11:11 AM   #367
henria86
Member#: 303849
2004 Forester Xt
Silver stg2
I love this mod so much better response time
henria86 is offline   Reply With Quote
Old 03-29-2013, 11:27 AM   #368
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
what's wrong with flutter and surge?
been driving with that soundtrack for 100k miles at silly boost.
Old 03-29-2013, 09:20 PM   #369
greenplates
Member#: 239162
An STi is not for amateurs ^
greenplates is offline   Reply With Quote
Old 09-17-2014, 04:56 PM   #370
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Considering the amount of useful information in this thread, the title is pretty misleading - took me a while to find this.
After translating an old document Tomei released for the S14 (SR20DET), keeping the external vent hole small (1/16", or 1.5 mm) is recommended. I've stumbled across a few other Japanese resources that seem to indicate that this is to prevent water ingress. The Tomei document shows the S14 OEM valve is VERY similar to ours in function.
The Tomei document also seems to indicate the original method (boost reference) is used as a safety device by OEMs to help mitigate over-boosting. You'd still spin up the turbo, but the engine would have a small layer of protection.
Interestingly, I've found that the later GDB models in Japan used the USDM STi by-pass valve. There are a number of Japanese threads that show people retrofitting the USDM-style STi valve to older (Type A through D/E) cars. I'm not sure if the boost-referenced valve was introduced in the Type E model along with the 5x114.3 hubs or later with the hawkeye body change (Type F).
The people in Japan retrofitting the boost-referenced valve claim better low-end response. I would have to test this to believe it...
Even more interesting is the following post showing a later model (boost-referenced) valve being modified for higher boost, just as this thread describes:
http://minkara.carview.co.jp/en/user...6175/note.aspx
So negating aftermarket options and crushing to increase internal spring pre-load, it looks like there's the following three options:
early JDM valve (weak spring, atmospheric-referenced) -
middle-of-the-road boost limit, unconfirmed to be ~30-35 PSI, could be higher
shouldn't surge due to weak internal spring
USDM STi/late-model JDM valve (strong spring, boost-referenced) -
lowest boost limit (~22-24 PSI)
unconfirmed claims of better low-end response on Japanese forums
note - Prodrive N12 (Group N) cars ran this valve and had a boost target of 23.5 PSI @ 3500 RPM; I believe Group N rules would have prohibited modification of the valve itself
Modified USDM STi/late-model JDM valve (strong spring, atmospheric-referenced) -
highest boost limit, untested but should exceed the limit of the JDM valve
audible compressor surge, not good, but likely not a damaging level
Supporting that last comment about surge, drive a 2nd-gen MR2 Turbo with a correctly-functioning air by-pass system if you want to hear how loud compressor surge *can* be direct from the factory. I owned one for years and it chattered like crazy lifting off throttle. The only time it didn't chatter was when one of the external components failed and I was waiting for parts from the dealer. Eventually I'll pick up a second STi valve to modify and compare... I really want to see how bad the surge is to see what everyone is whining about.
mrsaturn7085 is offline   Reply With Quote
Old 09-17-2014, 05:02 PM   #371
JoshP
Member#: 94350
If anyone cares I crushed mine and I'm running it VTA on speed density with no issues.
JoshP is offline   Reply With Quote
Old 09-19-2014, 01:13 PM   #372
mrsaturn7085
Member#: 375462
WR Blue
The company Coto Sports used to sell modified early JDM valves in the Japanese aftermarket. These valves appear to be atmospheric-vented valves with a heavier spring. If you want an example of the surge you'll hear with a modified USDM STi valve (and an aftermarket intake), here you go:
The guy in the video has an HKS intake, but the bypass valve is still recirculated properly.
Old 04-16-2015, 10:15 AM   #373
cmbezln
Member#: 372000
Just wanted to revive this post to see how people with 08+ wrx and plastic BPVs have done with this mod. Still looking through the thread to see how exactly this is reversible.
cmbezln is offline   Reply With Quote
Old 04-16-2015, 10:58 AM   #374
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
how is it reversible?
you take the set screw out of the IC tank end and you put it into the hole you drilled.
Old 04-16-2015, 11:55 AM   #375
cmbezln
Member#: 372000
Ah gotcha, makes sense.
