Old 03-02-2013, 05:52 PM   #1
CameronMac
Member#: 268843
2001 Impreza Ej22
Default Is this important? It just fell off.
The other day while playing in the snow, I started to hear a terrible rattle. Pulled over to inspect and found the heat shield that sits above my midpipe was hanging by my O2 sensor wire. I cut it off and am now wondering if it needs to be replaced. Am I now a rolling fire Hazzard or can I rest easy without it?
CameronMac is offline   Reply With Quote
Old 03-02-2013, 06:08 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
While it's cold out, I wouldn't worry too much. If it were me, I WOULD reinstall it though when the weather turns or if you have a garage to work in.
Old 03-02-2013, 10:15 PM   #3
GrundleJuice
Member#: 165749
If that is a cat shield it protects the unibody and passenger compartment from heat and insulated the cat to improve its catalyzing performance. Both are only good things.
Old 03-08-2013, 03:18 PM   #4
08 OutbackSport
Member#: 321935
2008 Outback Sport
Black Obsidian Pearl
All heat shields are a pain especially on subarus when the rattle all the time. Use some heat wrap if you're worried.
08 OutbackSport is offline   Reply With Quote
Old 03-09-2013, 11:14 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Ditch it and forget it.
Jay
Old 03-09-2013, 12:04 PM   #6
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
^^^^I agree.
AliBenn is offline   Reply With Quote
Old 03-12-2013, 02:26 PM   #7
KelConquer
Member#: 321498
1998 Legacy W. EJ25
I haven't run any shields on my exhaust for the past year and have had 0 problems.
KelConquer is offline   Reply With Quote
Old 03-12-2013, 04:47 PM   #8
NIN8185
Member#: 299546
2006 2.5i Impreza Wg
The only thing mechanics say is that if you don't have a heat shield on cat's then don't park in tall grass as the heat from the cat could cause a fire. Besides that you do not need them and they are very annoying when they get loose. Heat wrap will cause your exhaust to rust super-fast because it traps in all the salt and corrodes your car all year long instead of just the winter months
NIN8185 is offline   Reply With Quote
Old 03-14-2013, 05:57 PM   #9
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
I just cranked hose clamps around mine and they haven't rattled since...
But mine hadn't fallen off, either
motohippy is offline   Reply With Quote
Old 03-14-2013, 06:16 PM   #10
PjkFisher
Member#: 338227
1999 Impreza 2.5 rs
Heat shields are a non-issue. I ran slammed with them removed on my old car and never had an issue. I always had to park on the grass (sometimes dry) at my parent's house too. Unless you are in some seriously dry brush, you won't have a problem. And as stated earlier, if you are worried about heat in the cabin, just wrap the cat in heat wrap.
PjkFisher is offline   Reply With Quote
Old 03-14-2013, 10:25 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
I always get a chuckle when people (supposedly intelligent) honestly warn about parking in tall grass with no heat shields. I laugh because the shields are ABOVE the cat......nothing between the cat and the grass straight from the factory.....
Jay
