Old 03-09-2013, 11:50 AM   #1
thatsilverwrx
Member#: 307725
Now 2015 WRX
Default So whats going on here? (datalog inside)
https://docs.google.com/spreadsheet/...EE&usp=sharing
My car was tuned back in October and has been great ever since
Tsudo Catless DP
K&N SRI
Invidia N1 Street TBE
GS EBCS
Cobb AP
Tuned on 93
Now I'm getting ready for another round of mods and getting tuned for E85, the only change I made so far was installed my GS Upipe/Tial 44mm EWG. When my car was tuned, my tuner also made me a low boost map, which I flashed to after installing my EWG. Haven't been retuned yet, im waiting on my injectors and an intercooler. Do you think the EWG is causing it to run like this? I'm careful with the car since installing it, and barely ever get into boost. Is something wrong with the car?
thatsilverwrx is offline   Reply With Quote
Old 03-09-2013, 11:57 AM   #2
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
Nice IDC's. Your DAM is also dropping. You need a tune for the EWG. I would not do any further pulls until you get it sorted.
findurpath is offline   Reply With Quote
Old 03-09-2013, 12:22 PM   #3
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
You cannot run an EWG on a map tuned for a stock IWG. There is a SIGNIFICANT difference between the two - hence your significant problems.
Your best bet is to disconnect the EWG, reconnect the IWG, and reset the ECU until you get tuned for the EWG.
Seriously..., you are lucky you did not blow up your engine.
jebjkey is offline   Reply With Quote
Old 03-09-2013, 12:35 PM   #4
jebjkey
Member#: 73884
16 HyperBlue STi
So I actually looked at TD Boost Error compared to the boost column and your target boost for the entire RPM range is 21.25# How is that a low boost map?
Old 03-09-2013, 01:06 PM   #5
thatsilverwrx
Member#: 307725
Now 2015 WRX
Yeah the car was only tuned for 18psi. and 16psi for the low boost map but it's been overboosting that's why I don't get into boost. I'm getting tuned in probably two weeks as soon as I get an intercooler and my injectors in. But I just wanted to make sure all the problems are because of the ewg and not being tuned for it.
Old 03-09-2013, 04:50 PM   #6
Heedlessone
Member#: 254130
1993 LS1 RX7
It's over boosting because your WGDC are way higher for an IWG than an EWG. Get a tune, now, or put the stock up pipe back on.
You're causing damage to the engine.
Heedlessone is offline   Reply With Quote
