Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 02-24-2010, 09:01 PM   #26
JBet
Member#: 239174
Let me know how much you get, I'm about to do the same with mine. Same issues you're having.
JBet is offline   Reply With Quote
Old 02-25-2010, 12:27 PM   #27
JonNM2001
Member#: 238219
Question
Does it misfire all the time or at specific times (i.e. under hard acceleration)?
JonNM2001 is offline   Reply With Quote
Old 02-25-2010, 12:31 PM   #28
JoshP
Member#: 94350
timing belt jumped? intake manifold gaskets? its really hard to tell over the internet
JoshP is offline   Reply With Quote
Old 05-23-2010, 10:20 AM   #29
d3v0
Member#: 225692
2015 WRX
I've got a misfire on all cylinders code and the previous owner has changed everything but some ignition part and the coilpack.
Going to be putting a new coilpack on today, i hope I don't run into the problems you're having, OP
d3v0 is offline   Reply With Quote
Old 03-10-2013, 01:23 PM   #30
killerz99
Member#: 349541
94 impreza
red
Im having the same prob its frustrating as hell the guy I bought it from replaced crank coolant and cam sens. I replaced coil wires and plugs and cleaned the egr all seemed to help but it does it only after its warm any thoughts?
killerz99 is offline   Reply With Quote
Old 03-11-2013, 08:47 PM   #31
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
I had this problem.. it was the boot that goes over the spark plug. There was a pinhole that was almost invisible.
Ordered the coilpack boot, ... fixed.
edit: though the "no codes" thing really bothers me. Even the ecu knows when you misfire..... soo to get this straight... you're misfiring with no misfire codes. So weird.
DHRDAN is offline   Reply With Quote
Still Misfiring on all cylinders?! crazycanasian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 08-16-2009 03:33 AM
cylinder 3 and 4 still misfire joshua olean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-24-2008 07:24 AM
Cobb STG 2 Misfire, bad plugs (pics) mvitic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-16-2006 09:05 PM
help, still misfiring **merged threads** snowmachine Normally Aspirated Powertrain 15 08-25-2005 06:21 PM
Still misfiring...HELP! Mr. Bungle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 08-05-2005 12:01 PM
