Old 03-07-2013, 07:26 PM   #5826
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
Originally Posted by 561wrx View Post
oh yea im getting ecu, and ok i understand what u r saying too. so it will be better get and just get it tuned one after swap is done.
Right next tune something that isn't even setup as a base for what you'll be running. It's harder and more expensive. Furthermore. The AVCS mapping isn't on the 03 WRX ROM. furthermore, It also doesn't deal with all the emissions BS. So CELs and such as much of a problem. Buy engine and ECU. get AVCS harness from IAP install. Once the engine gets here you'll need to remove the old and install the new along with the correct ECU.
iNfEk is offline   Reply With Quote
Old 03-07-2013, 07:42 PM   #5827
561wrx
Member#: 166427
03 wrx
thanks
561wrx is offline   Reply With Quote
Old 03-07-2013, 08:53 PM   #5828
Modollenroc
Member#: 243499
What spark plugs do you guys use?
And part no. If possible
Modollenroc is offline   Reply With Quote
Old 03-07-2013, 10:10 PM   #5829
Krang
Member#: 134272
2007 Sti, DGM
Rotated EFR 6758
Top Right of the page, link called "Search This Thread"
It's been covered 100's of times, what oil to use 100's of times.
Krang is offline   Reply With Quote
Old 03-08-2013, 01:16 AM   #5830
Modollenroc
Member#: 243499
Sorry if I use the app instead of the browser version.
Old 03-08-2013, 01:49 AM   #5831
stlnation
Member#: 321805
2002 Jdm v9 STI
Agreed. The app could def use that feature.
stlnation is offline   Reply With Quote
Old 03-08-2013, 03:15 AM   #5832
dundunskeert
Member#: 184151
2000 STI RA Limited
Originally Posted by dundunskeert View Post
I recently spun a bearing in my v6 207 and bought a v7 207 to replace it. I am hoping to swap in non avcs cams in order to reuse the majority of my v6 harness and to continue the use my Power FC.
Right now I am looking at ordering non-avcs BC cams and reusing my v6 cam gears. After some research it looks like I will need to obtain non AVCS cam seals and a new cam angle sensor bracket seen here http://www.importimageracing.com/cos...et-subaru.html
Am I missing anything or is this all I will need?
Thanks a ton in advance to anyone that can help!!!
Aaron
Anyone else care to give there input? Surely somebody had done this.
dundunskeert is offline   Reply With Quote
Old 03-08-2013, 07:21 AM   #5833
Krang
Member#: 134272
2007 Sti, DGM
Rotated EFR 6758
Ahh yes, I do like the app though for browsing on the go, but can't beat the browsers functionality!
Here ya go dude man.
Originally Posted by Zaider View Post
I know that BKR7EIX is the spark plug to use for the EJ207... but im upgrading my turbo to the Dom 1.5XTR.
Is that spark plug still the one I should be using?
Old 03-08-2013, 07:23 AM   #5834
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
My opinion is that you would do well for yourself to keep the avcs, run the engine with it's matching ECU and modify the harness.
Romraider support for your turbo and the V7 is not a problem.
You could ask Steve at IAP for the wiring manual of the V7 engine, and get the wiring manual of your chassis, if you don't have it already.
Then buy USDM WRX wiring harness components as needed and get this done.
There is a lot of knowledge and help available in this thread.
Old 03-10-2013, 11:40 AM   #5835
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
My UOA came back from Blackstone for the first regular oil change (I did change it once before... 500 miles into the swap). Pleasantly surprised to see that they actually had the ej207 in their database! Car hardly burns any oil at all, compared to the old 130k+ ej205. I guess I can now rest easy having kept Rotella T6 & Purolator PL14460 as my combo of choice
This is after four winter months, 6k+ miles of mixed driving, w/ few hard pulls here and there for tuning and "testing" purposes
Torquey is offline   Reply With Quote
Old 03-10-2013, 02:50 PM   #5836
Whoracle
Member#: 301075
2003 Impreza WRX
Well, my 205 had low compression which was diagnosed as a worn rod bearing and warped valves. $4500 to rebuild >.<. Decided to go with a 207, which should hopefully be done around April. This is right after it was just at the bodyshop for 2 months getting 6k worth of work done thanks to a truck reversing into my tail light in a parking lot.
Whoracle is offline   Reply With Quote
Old 03-10-2013, 07:48 PM   #5837
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
let me know if you need an avcs harness. got more pins in and making two up tonight for two other guys.
WhiteBgeye02 is offline   Reply With Quote
Old 03-10-2013, 08:14 PM   #5838
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
You rock , like the support for ej207 owners
666stars is offline   Reply With Quote
Old 03-10-2013, 09:53 PM   #5839
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
just trying to help everyone save some dough instead of paying the big business prices.
Old 03-10-2013, 10:13 PM   #5840
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
So if you were to rebuild a 207 with a spun rod bearing what would you do ?
I am budgeting a build for a 2.12 liter stroker kit on a 207 which could make for a very fun motor.
Anyone do something like this ?
Gigs90 is offline   Reply With Quote
Old 03-11-2013, 08:00 AM   #5841
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
The 2.12 Stroker is quite common across the pond. They have had lot's of great success with stroking the 207. Check out www.scoobynet.com
kayen is offline   Reply With Quote
Old 03-11-2013, 08:39 AM   #5842
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I would do a hybrid with a GRB 207 shortblock, to me that is a new direction. Not to mention, getting out of the 2002-2007 timeline and moving finally into the 2008-2013 timeline.
Have a JDM GRB EJ207 2010 shortblock with low miles in your engine ....
Old 03-11-2013, 12:25 PM   #5843
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I'm planning on it, but I'm going to run on the base 207 for a little while to build up my $$$ cushion again.
The 2.1 stroked EJ207 is (in my opinion) the best EJ street motor. AVCS and the stroke give it plenty of torque down low, not as much as a 2.5, but having the lightest pistons makes up for it with a WIDE powerband and better fuel economy. I think that makes it the best "commute all week, have fun on the weekends" EJ motor.
Old 03-11-2013, 01:41 PM   #5844
Whoracle
Member#: 301075
2003 Impreza WRX
I appreciate it, but as i had already taken it to a shop to diagnose the misfire on my old engine, it is only costing me slightly more to have the shop install and hook up everything than it would to do it myself.
Old 03-11-2013, 02:31 PM   #5845
2JZ
Member#: 291949
Just got my v9 swapped 92x and I have a 02 wrx ecu for emissions but its throwing cels. Where or how do I get the ecu to not throw any cels and can I drive it on a wrx ecu on a stock tune?
2JZ is offline   Reply With Quote
Old 03-11-2013, 02:33 PM   #5846
25rsti
Member#: 166324
You need a map for that usdm ecu stat! Whoever does your tune and puts a map on your ecu can take care of the codes.
25rsti is offline   Reply With Quote
Old 03-11-2013, 05:26 PM   #5847
jchafee
Member#: 238453
05 05 WRX
I'm working on something similar now. Only difference is I'm using an ej205 for budget purposes. However, it will be fitted with v9 heads and a v7 ecu. Should be one hell of an engine.
jchafee is offline   Reply With Quote
Old 03-11-2013, 06:51 PM   #5848
2JZ
Member#: 291949
My jdm ecu already has a 91 octane tune, I bought the car swapped but had to buy a wrx ecu because an emission is required here
Old 03-11-2013, 07:02 PM   #5849
25rsti
Member#: 166324
You say 91 octane. Are you in Cali? Try filling out your profile to help some of us know where you're located and what you drive.
Back to the emissions and inspection, my statement remains the same. You need a new map/tune for the usdm ecu because you want to pass emissions/inspection.
Old 03-11-2013, 07:44 PM   #5850
2JZ
Member#: 291949
filled it out. It's in Toronto and I plan on doing a 94 octane tune in the future once I get used to the 91 octane power. In Ontario, Canada emissions laws are now using OBD II and not tailpipe. JDM ecu won't connect and I need a WRX ECU (which I now have). If i can avoid paying $500 for a tune and flat bedding the car to a tuner that would be good.. is there anyway to just use the existing tune on the JDM ecu and put that on the WRX ecu?
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
