Old 03-07-2013, 08:58 PM   #1
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
Default looking for working ej20g ac compressor
I figured I can get more hits here.
I have a 95 sti ra EJ20G. My ac compressor needs to be replaced so let me know if you have one in working condition. I think as long as you have a jdm ac compressor, I should be able to replace mine without any trouble with the lines.
Or let me know if there are other options. I know an option is to use USDM compressor with AC lines, but not too sure about wiring. I was reading that USDM (newer models) have 2 separate electrical plugs but I only have one... maybe rebuilding it? Not sure where I would find the parts.
sizzflair is online now   Reply With Quote
Old 03-08-2013, 12:34 AM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
i might have one from a k around soemwhere
Old 03-08-2013, 12:56 AM   #3
sizzflair
Member#: 94268
2010 Exige S240
okay. I actually was able to jump the compressor so it may just be a refrigerant/leak issue. I got one of those recharge kits with the gauge and it would read 25psi (which is low) the whole time and if I attempted to charge, it would slowly go back down to 25psi.
Probably going to take it to a shop so they can use better tools to service it. If they deem it a compressor issue, def. let me know if you have one
Old 03-08-2013, 06:46 PM   #4
RealDealTarheel
Member#: 142447
06 Outback
If you don't get it sorted shoot me a PM, I have one from a V2 RA.
RealDealTarheel is offline   Reply With Quote
Old 03-11-2013, 02:57 AM   #5
CRX7
Member#: 31639
99 Impreza
With an angle grinder you can make the USDM compressor fit. Just have to massage the bracket.
CRX7 is offline   Reply With Quote
Old 05-11-2014, 12:31 AM   #6
sizzflair
Member#: 94268
2010 Exige S240
Back from the dead. I need one!
Old 05-11-2014, 04:25 AM   #7
HobsonRylan
Member#: 337140
1994 WRX
Red
I have one for sale, give me a PM, I actually have 2 for sale if anyone else is in need!
HobsonRylan is offline   Reply With Quote
Old 05-11-2014, 04:19 PM   #8
sizzflair
Member#: 94268
2010 Exige S240
Pm'd...
Old 05-14-2014, 11:20 PM   #9
sizzflair
Member#: 94268
2010 Exige S240
still looking
Old 06-10-2014, 03:39 AM   #10
CO S13
Member#: 51598
1998 Legacy GT wagon
Sent a pm
CO S13 is offline   Reply With Quote
Old 07-01-2014, 07:24 PM   #11
sizzflair
Member#: 94268
2010 Exige S240
PM'd Thanks.
Old 08-04-2014, 12:58 PM   #12
sizzflair
Member#: 94268
2010 Exige S240
Still looking for the right one. Little differences between ej20g compressors.
Old 08-04-2014, 09:34 PM   #13
CRX7
Member#: 31639
99 Impreza
The ports hook up to USDM Impreza compressors. All you need to do is grind the EJ20g bracket to make the body fit. Took me an hour max. This way you can get a new easily available compressor.
Old 08-04-2014, 11:35 PM   #14
sizzflair
Member#: 94268
2010 Exige S240
Which usdm impreza? Out of a 2.5rs? What about the 3 pronged electrical connection?
The high pressure line on my ej20g (95 sti ra) did not fit a 96 ej20g compressor... and the same case on another ej20g compressor that another member sent me pictures of. I think there's a difference between 93-95 sti and 96+ sti, even though it's ej20g.
I'll take pics of the differences to explain what I mean.
Old 08-06-2014, 11:03 PM   #15
CRX7
Member#: 31639
99 Impreza
99-00 Outback Sport compressor and 99 lines. I was assuming this was an engine swap and you kept the lines from your model year of car.
Old 08-09-2014, 04:30 PM   #16
sizzflair
Member#: 94268
2010 Exige S240
Nope. It's not an engine swap.
Old 08-29-2014, 11:22 PM   #17
flyerpope
Member#: 207024
87 GL-10
I'm putting a 92 JDM EJ20 in my 87 GL-10. I would really like to hook the A/C up. I have the compressor but need the high and low side lines. Can anyone help?
flyerpope is offline   Reply With Quote
Old 11-24-2014, 11:28 AM   #18
USLiberty
Member#: 294466
1993 Legacy SS
white
You can cut/splice AC lines, it takes a sleeve you can get at napa and couple hose clamps. Did it on my 95 jeep grand cherokee. You can cut the crimped couplings to expose barbed sleeves. I have have 2 early ej20g's and might have some connectors, if you need, post a pic of your compressor.
USLiberty is offline   Reply With Quote
