Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Old 05-14-2003, 10:44 PM   #1
mpj_becks
Member#: 6265
Default Converting FWD L to AWD
Does anyone know if this is doable? If so what is required to do this.
Thanks for any help any of you can give.
mpj_becks is offline   Reply With Quote
Old 05-15-2003, 12:54 AM   #2
fellfrosch7
Member#: 2389
'98 Impreza L Wagon
'90 Talon TSi AWD
It is doable. You need the rear AWD suspension, axles, differential, crossmember, and the AWD gas tank. There may be more parts that I'm forgetting as well...
fellfrosch7 is offline   Reply With Quote
Old 05-15-2003, 07:36 AM   #3
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
its a real PITA , im undergoin this now actually. However my difference in my project : Im swapping in parts to accept AWD components before i go all the way to AWD , meaning im not swapping in the tranny , diff, or drive shafts yet. off the top of my head you need :
AWD gas TAnk (sending unit and pump as well )
Lateral Links,
Trailing Arms, (correct name ? )
AWD Hubs
AWD knuckles
the rear subframe ( might be the crossmember not sure )
then of course rear brakes , you can get AWD drums or DIsk,
cindergarden is offline   Reply With Quote
Old 05-15-2003, 11:52 AM   #4
EJ25
Member#: 10768
I did the whole thing. 95' 2WD L to a '98 STi. Used a 99 wiring harness and dash, 2000 front end, STI IV driveline.
www.innovativelogic.com/car/index.html
EJ25 is offline   Reply With Quote
Old 05-15-2003, 12:11 PM   #5
Aspen
Member#: 145
Banned to
Housework for Summer
I hope you are planning on using some sort of modified axles to hold the hub/wheel bearings together. If you don't use anything, your bearings will fall out on a hard turn which will equal major suck.
Aspen is offline   Reply With Quote
Old 05-18-2003, 09:43 AM   #6
RSimport
Member#: 24718
05 impreza RS
white
I have a friend that is turbocharging his 93 impreza. Him and I both know that when he does this his tranny will go. He thinks that he can take an AWD tranny of a newer impreza out put it in and still keep the front wheel drive. Am I correct to assume that when you take an AWD tranny out you have to convert everything to AWD?
RSimport is offline   Reply With Quote
Old 05-18-2003, 09:04 PM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
im the friend
i know the tranny will hold the power, its just the clutch im worried about. what he is talking about with a replacement tranny is an AWD tranny with no driveshaft or anything, just front axles. im not looking for info cause im not worried about anything yet and its still really early, i just thought i would clear some things up.
Brent
scoobyimprza is offline   Reply With Quote
Old 05-19-2003, 04:00 PM   #8
serious
Member#: 22879
Find either a wrecked 91-94 awd legacy (perferably a turbo model) or a 93-01 impreza and get it for parts. There are a lot of little things that if you miss will cost you an arm and a leg.
If you are seriously considering this swap i have the rear end out of a 93 turbo sedan for sale including everything but the tranny and rear diff. The brakes would be from a 96 legacy and not the 93 turbo ones.
Brent
serious is offline   Reply With Quote
Old 05-19-2003, 05:26 PM   #9
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
what can u use from a legacy for an AWD swap?
scobaru is offline   Reply With Quote
Old 05-20-2003, 12:16 PM   #10
serious
Member#: 22879
Pretty much everything. The two cars are built on the same unibody so they share the same parts. The only thing you can't use is the sway bar as it's a little different due to the larger spare wheel well.
Brent
Old 05-20-2003, 10:55 PM   #11
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
so if I can use legacy AWD that include drive shalf and everything?!?! does that also mean when I buy suspenstion stuff I can still use impreza springs and what nots? also can I still use the rear brakes from a legacy to do the converison? oh and one more thing would an exhaust system made for an AWD work for a FWD as far as clearing everything or do I need the AWD
Old 05-21-2003, 05:16 PM   #12
serious
Member#: 22879
Yeah, i'm pretty sure the driveshaft and all that is the right length. I know for sure the splines line up on the transmission out and the differential 4 bolt pattren is pretty standard.
My stuff won't come with a differential or the driveshaft as i might be needing them for my conversion. I might be able to get a 3.9 open diff if you could use it. But most of this stuff is pretty much available in any junk yard for a good price.
Brent
Old 05-21-2003, 05:20 PM   #13
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
with the converison as far as everyting bolts up your also talking about the front suspenstion for the AWD working too right?
Old 05-22-2003, 01:04 AM   #14
serious
Member#: 22879
Good question and one i never really thought too much about. I know most people add a set of springs and struts when doing this but that's manly just because they are there.
I would think most of it would be the same. Maybe different spring rates/strut valve proportioning but i would think the suspension layout is the same.
Brent
Need some help on GA emissions testing- FWD VIN to AWD test mpaone South East Region Forum 21 10-09-2008 05:56 PM
93 Imp L FWD - Converion to AWD 04.STI Subaru Conversions 1 10-01-2006 01:44 PM
fwd tranny to awd tranny? STi-Nismo Dood Transmission (AT/MT) & Driveline 5 07-21-2003 03:32 PM
'94 FWD Legacy to AWD IronMonkeyL255 Subaru Conversions 10 06-25-2003 01:20 PM
Need some advice ASAP re: converting FWD to AWD Digital_Boy Technical Forum Archive 2 10-08-2000 04:49 PM
