Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 01-16-2013, 02:16 PM   #1
eddyj14
Member#: 343412
Default Problem hitting past 4000 rpms
Hey guys,
I just picked up my first subie.. It's got a bunch of parts I barely know about.. But my problem is. Whenever I try and hit first gear even second and third past 4000 Rpms it like sputters like the turbo idk if it needs a tune or if the computer has a 2 step or maybe has something to do with turbo timer... Idk
Last owner just replaced the turbo with a new sti turbo.
Any ideas?
eddyj14 is offline   Reply With Quote
Old 01-16-2013, 02:31 PM   #2
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
Originally Posted by eddyj14 View Post
Hey guys,
Any ideas?
Is the engine managed off the stock ecu or a standalone? Could be a number of things. Is there a check engine light? Could be the tgv's are not open. Meed more info.
fastblueufo is offline   Reply With Quote
Old 01-16-2013, 03:15 PM   #3
liltoua
Member#: 206802
1998 2.5rs
Two things could be going on, your car is in limb mode. Or you car needs a serious tune if you have lots of upgrades with no tune....ex. upgraded injectors.
liltoua is offline   Reply With Quote
Old 01-16-2013, 03:30 PM   #4
eddyj14
Member#: 343412
Yeah there's a check engine light on it...I'm not sure about stock ecu.. It
Might be a stock ecu.. And yeah has new sti turbo pink injectors.. I mean the last owner said it needed a tune to run good it's still drivable but when I try and rev it it sputters so I was just wondering if because of needing a tune or something else... By the way check engine light popped camshaft sensor...knock sensors... And all cylinder misfires... I replaced everything.. It seemed to drive better the spark plugs were bad on it.. But the only thing is reving it hard
Old 01-16-2013, 04:39 PM   #5
liltoua
Member#: 206802
1998 2.5rs
If you are running a stock ECU and upgraded injectors, your car is going to break up when reving high, your ECU doesn't know what to do with all that fuel being dumped. Sounds like you need a tune. What year/model do you have?
Old 01-16-2013, 05:42 PM   #6
eddyj14
Member#: 343412
It's a 2004 wrx... The block says ej25 and the heads not sure i think they regular wrx heads
Old 01-16-2013, 05:42 PM   #7
eddyj14
Member#: 343412
And yeah I think I might need a major tune .. Thanks man hopefully that's what it is
Old 01-17-2013, 01:44 PM   #8
liltoua
Member#: 206802
1998 2.5rs
Yea you need to get that thing tuned right away. You are not going to be able to do anything until it gets tuned.
Old 01-17-2013, 03:30 PM   #9
eddyj14
Member#: 343412
Yeah I am.. I'm gonna take it to sti Mickey up in CT
Old 01-17-2013, 03:31 PM   #10
eddyj14
Member#: 343412
Yeah I am.. I'm gonna take it to sti Mickey up in CT thanks for your help man.. I appreciate it ^^^
Old 02-26-2013, 10:56 PM   #11
droned23
Member#: 330606
2003 wrx
Hi, I just upgraded to stage 2 cams and cam springs on an 03 wrx that has an intake intercooler race radiator exhaust and rebuilt heads. My engine does the same sputter. I am scheduled for 750ccinj and fuel pump install with a tune. will the tune fix this sputter?
droned23 is offline   Reply With Quote
Old 03-08-2013, 10:50 PM   #12
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Did you set the valve lash on the cams? Sounds like the valves may not be closing fully.
06rexwagon is offline   Reply With Quote
Old 03-12-2013, 04:12 AM   #13
droned23
Member#: 330606
2003 wrx
will check but the sputter has stopped for now even under heavier throttle
Old 05-14-2013, 01:50 AM   #14
20BAJA03
Member#: 340463
Check for a vacuum leak... I had a similar problem once and it turned out to be the vacuum hose to the waste gate actuator had become disconnected
20BAJA03 is offline   Reply With Quote
