Old 03-04-2013, 10:57 AM   #476
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Originally Posted by jamesonp16 View Post
I found stock STI sway bars (04-07) for a good price and I am wondering if they fit my 2007 2.5. I obviously dont want to buy them if they are not going to fit my car. does anyone know if they will fit? im very interested in these to start my suspension upgrades, any help that anyone can give me would be great!! thank you
They won't fit. This thread answers that question on the first page.
Originally Posted by timbo123 View Post
Anyone know if the 93-01 wrx struts,springs and mounts fit a 2001 RS sedan? I want full coil overs but can't find them for anything but wrx
They will fit. 93-01 is identical for WRX and RS except for front swaybar.
AndyRoo is offline   Reply With Quote
Old 03-10-2013, 10:52 PM   #477
MaD1521
Member#: 319679
2002 Wrx Sedan
Anyone know if 04 sti usdm pinks will fit a 2000 outback sport? Just 04-07 tophats needed? Scoobyspacer? Any input greatly appreciated
MaD1521 is offline   Reply With Quote
Old 03-11-2013, 01:06 AM   #478
caterpill
Member#: 27136
Don't the pinks lift the GC chassis a bit?
They should work though.
It's really hard to find pictures, I had the same question myself. :-*
caterpill is offline   Reply With Quote
Old 03-12-2013, 03:05 PM   #479
Hextro
Member#: 276823
2010 WRX
do these HKS coils fit on a 2010 wrx?
HKS 80140-AF007 Hipermax III Coilover Suspension Kit : Amazon.com : AutomotiveHKS 80140-AF007 Hipermax III Coilover Suspension Kit : Amazon.com : Automotive
i found the link below that says 08-09 but 2010 should work fine too right? Looks like there was not a sport version for the wrx in the GE/GH family.
thoughts?
http://www.hks-power.co.jp/usa/products/Pid=3436.html
80140-AF007 SUBARU Impreza WRX 2008-2009
there are 2010 listings on there for the sti only though
Hextro is offline   Reply With Quote
Old 03-12-2013, 04:06 PM   #480
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Video Link: http://www.amazon.com/HKS-80140-AF007-Hipermax-Coilover-Suspension/dp/B001N21HJM
thoughts?
It says built for (08 and up) Wrx's. I don't see why it wouldn't fit...
Old 03-12-2013, 04:08 PM   #481
Hextro
Member#: 276823
2010 WRX
i question it because that's amazon saying that and not the HKS site. Amazon sells a lot of everything so they might not be as dialed in as needed.
thanks,
Old 03-12-2013, 04:17 PM   #482
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
thanks,
The only difference between the 08-10 and 11+ wrx's (in terms of suspension) is the spring rates as well as the slightly wider track width with the 11+'s. Did you try contacting hks to triple check?
Old 03-12-2013, 04:27 PM   #483
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
08-10 coilovers and shocks for WRX are interchangeable. STI fronts are different.
11+ has the widebody so they aren't exactly the same, but they fit. Putting 08-10 style shocks/coilovers on an 11 will get you a bunch more negative camber (which can be a good thing). Going the other direction you end up with a lot less negative camber.
FWIW you can do better than that for that much cash.
- drew
Old 03-12-2013, 04:33 PM   #484
Hextro
Member#: 276823
2010 WRX
AndyRoo - totally agree, but I might get some lightly used for < $1k and that would be worth it IMO.
I'm also thinking about just doing the koni setup so i don't mess with the setup all the time (which i bet i would be with track day visits etc..). i almost need the cup kit install and forget it setup
Old 03-12-2013, 04:39 PM   #485
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Gotcha, not a bad deal if they're in good condition. A new Koni + RCE set-up from TIC might be around that price new though. Haven't looked in a while.
- drew
Old 03-12-2013, 05:48 PM   #486
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Just do the koni/spring setup. I did koni's with Rce yellows and I don't know why I waited so long to do so. If TIC makes I package I would say go for it, as long as its not too pricey.
Old 03-13-2013, 01:58 AM   #487
happycorey
Member#: 324849
2005 STI
Curious with the issues of a front 02-07 wrx swaybar on a 05 STI? Nothing is mentioned specifically
happycorey is offline   Reply With Quote
Old 04-05-2013, 08:26 AM   #488
newrexowner
Member#: 311952
2005 Subaru WRX
Crystal Grey Metallic
So if I read correctly. 04-07 sti struts, springs, and top hats should fit onto a 05 wrx? Or only 05-07 sti struts, springs, top hats will fit 05-07 wrx's? Am I correct? Looking to upgrade my suspension with sti struts springs and top hats
newrexowner is offline   Reply With Quote
Old 04-05-2013, 08:51 AM   #489
MD04WRX
Member#: 72891
2014 Molten ST
98 2.5GT -2014 XV
No, 04 STi struts and springs will fit 02-07 WRX. 05-07 STi rears will fit but fronts will not.
MD04WRX is offline   Reply With Quote
Old 04-05-2013, 09:15 AM   #490
newrexowner
Member#: 311952
2005 Subaru WRX
Ok so ill get 04 STI struts, springs and tops hats for my 05 wrx.
Old 04-24-2013, 05:36 PM   #491
s00bn00b
Member#: 188956
2006 Impreza Wagon
The "Will it fit?" portion for the MY range that covers my 2006 states that 05+ STI suspension bits will not fit on my car. That said, the post was written in 2007.
I'd just like to confirm that this trend did in fact hold true since the original posting date.
The question at hand is, if I swapped struts, springs, and top hats from an 08 STi to my '06 2.5i wagon, would there be any issues?
s00bn00b is offline   Reply With Quote
Old 04-24-2013, 05:38 PM   #492
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
08+ anything will not fit 02-07 anything.
Old 04-24-2013, 05:40 PM   #493
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
and yes it should be edited to be more clear.
Old 04-25-2013, 10:46 AM   #494
s00bn00b
Member#: 188956
2006 Impreza Wagon
Awesome - thanks!
Old 07-15-2013, 03:43 AM   #495
BeardedShogun
Member#: 354456
will 02 wrx struts fit an 07 wrx?
BeardedShogun is offline   Reply With Quote
Old 08-15-2013, 06:56 PM   #496
Belumoth
Member#: 360076
2004 WRX Wagon
Will 06 wrx sway bars fit my 05 FXT?
Belumoth is offline   Reply With Quote
Old 08-16-2013, 07:59 AM   #497
gutie04
Member#: 219717
05 FXT Dom2.5R
4EAT FTW!!!!
Yes, but not worth it. You have an STI bar on the front.and a wrx size bar in the rear. Go STI bar in rear with upgraded links and mounts.
gutie04 is offline   Reply With Quote
Old 08-16-2013, 08:01 AM   #498
gutie04
Member#: 219717
05 FXT Dom2.5R
4EAT FTW!!!!
Need new 04+ tophats.
Old 08-16-2013, 12:00 PM   #499
Mach V Matt
Member#: 248892
2006 WRX Wagon
Only on the rears. The fronts are all the same.
You'll also want a set of the Scooby921 strut spacers as well.
Matt
Mach V Matt is offline   Reply With Quote
Old 08-16-2013, 12:02 PM   #500
skunkman
Member#: 118141
95 'lifted' legacy
Nice thread Race Comp Engineering!!
Here's a little something I just discovered.
I was able to straight swap the factory 15mm RSB from my 95 legacy into my wife's 03 OBS. I'd removed the SB from the lagacy to up-size it to a gen 1 OB's 18mm RSB.
So it follows that the 13mm RSB from an 02-03 OBS (I assume 00-07 impreza bodies?) can ultimately be replaced a gen 1 OB's (96-99) 18mm RSB.
These are more abundant and possibly cheaper than WRX 20mm bars, so a great and easy improvement if not THE best possible improvement.
I noticed you have specific info regarding sti part fitment etc. and those specifics are out of my experience (I'm an off-road guy with a lifted BD), but I did find something which could be of use regarding RSB on my wife's 03 OBS.
Ciao!
skunkman is offline   Reply With Quote
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
