Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 03-07-2013, 12:30 AM   #7176
Maxwell Power
Member#: 190729
Originally Posted by Z0rr0 View Post
I never put it back on the dyno, but it wouldn't surprise me if it picked up that much.. it certainly felt much more powerful up top with the extra timing.
I have since converted the car back to pump gas and wastegate pressure.
The wifey is driving it now so it didn't really need all that power.
The five o 1400 top feeds sucked. They were okay, but not great on e85, but wouldn't idle or maintain decent afr corrections on pump gas at all.
Yeah, those injectors are like that...
Old 03-07-2013, 01:04 AM   #7177
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
Originally Posted by 06rexwagon View Post
Idle timing is strange
Important to note that this is a hybrid engine with oem gasket and Cnc head chambers. Not sure of cr.
Just add a few more degrees
GIFSoup
Old 03-07-2013, 08:20 AM   #7178
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Hahahahaha ^ yeah exactly what she needs lol
Old 03-10-2013, 09:45 PM   #7179
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
GIFSoup
Hit 5000 post junior!.
On a side note, is it possible to target 15.5 16 AFR in closed loop with a stock ecu? E85 of course. I'm sure this has been discussed before. Really just curious, I don't mind $tree fiddy per gallon of E here in Cali.
wrxsubiemod is offline   Reply With Quote
Old 03-10-2013, 09:55 PM   #7180
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
No, you can't target higher than 14.7 but you can adjust the o2 sensor scaling table to trick the ECU into running leaner in CL fueling mode.
Old 03-10-2013, 10:40 PM   #7181
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
Originally Posted by stretchedk7 View Post
hmmmm, so you dont like the idea of fuel feed line y'ing into two feed lines feeding the rails from the front. 2 returns y'ing into fpr's return?? mps
Bump for this question... I'm curious too
I have my feed y in back then return in the front to fpr
Old 03-12-2013, 06:20 PM   #7182
Maxwell Power
Member#: 190729
I do not, ever.
Old 03-12-2013, 06:35 PM   #7183
sub666
Member#: 38052
I do not, ever.
Why not?
sub666 is offline   Reply With Quote
Old 03-12-2013, 07:24 PM   #7184
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
yes id like to know as well. i thought that was optimal?? enlighten
Old 03-12-2013, 07:27 PM   #7185
Maxwell Power
Member#: 190729
Originally Posted by sub666 View Post
Why not?
I answer this question weekly on various boards, forums, phone calls, etc. There are threads dedicated to this question.
Not trying to sound like a dick, but I get tired of typing this crap in here so often.
http://forums.nasioc.com/forums/show....php?t=2324217
http://forums.nasioc.com/forums/show....php?t=1784516
http://forums.nasioc.com/forums/show....php?t=1702099
Old 03-12-2013, 07:46 PM   #7186
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
fair enough on all the threads....^ wont the second rail have a slight different (less pressure) from the first rail pulsing fuel (injectors i mean). seems like if u fed 2/4 rail first that 1/3 would have slight delay in pressure upon pressure changes?
Old 03-13-2013, 09:55 AM   #7187
climberd
Member#: 183019
05 LGT Stg3 Wgn
Dom, I read all your comments in all 3 links, thank you. Does it matter in your opinion the plumbing order relative to firing order?
1-3-2-4; Easy to feed them in reverse order, or, just as easy to feed them out of order: 2-4-1-3 to keep opposite-rail pulses a little further from eachother via the bridging hose.
I'm most likely going to switch over to Aeromotive topfeed rails, just want to be sure I do this all correctly. TIA.
Believe it or not, most of what I understand about fueling comes from you and Tony, not from this naive notion of consensus that is so popular everywhere.
climberd is offline   Reply With Quote
Old 03-13-2013, 11:00 AM   #7188
slowgenius
Member#: 48350
0304 0712 WRX/Sti
Originally posted by slowgenius
"This is a fuel question for dom. When running a series fuel rail setup is it fed in a "U" formation across the alternator head to head or a "Z" formation under the intake manifold?"
Z, back to front.
slowgenius is offline   Reply With Quote
Old 03-13-2013, 01:05 PM   #7189
Maxwell Power
Member#: 190729
the oem routing is also back to front btw.
Old 03-14-2013, 02:18 PM   #7190
climberd
Member#: 183019
05 LGT Stg3 Wgn
So like stock, 4-2-3-1. Reverse firing order. I'm just going to assume some fuel system engineer at or contracted by Subaru fed the injectors in that order for a reason other than ease of layout and install.Thank you much Dom and others.
Old 03-14-2013, 02:25 PM   #7191
Maxwell Power
Member#: 190729
In my mind it makes sense. The injectors are firing closer and closer to the fuel source. I would guess that this help keep a consistent flow to the injectors, but I would have to see some sort of analysis to confirm.
Regardless, I've had zero issues with unexplained misfires with our setup in this way.
Old 03-25-2013, 09:24 AM   #7192
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
Here's a quick video of my NF Performance "Stage 1" setup.
On E85, of course. I'll have more info up shortly!
Old 03-25-2013, 09:49 AM   #7193
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
sounds pretty badass man!
Old 03-25-2013, 12:20 PM   #7194
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Yeah Fuji just put that up on his DD thread!! I frickin love it!! It sounds so good the exhaust note and the 6266 spoolin!
Old 03-25-2013, 12:33 PM   #7195
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
love it!
Old 03-25-2013, 02:29 PM   #7196
wgr73
Member#: 232458
2008 STi (OBP)
EFR 7670 (E85)
That's sick. I need to go back and look at his thread!! Sounds sooo good
Old 03-25-2013, 02:31 PM   #7197
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
8k Redline?
340Duster is offline   Reply With Quote
Old 03-25-2013, 04:27 PM   #7198
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
27#s of boost...
Old 03-25-2013, 04:31 PM   #7199
xluben
Member#: 261612
2002 WRX Sedan
10.3s @ 139mph
Originally Posted by 340Duster View Post
8k Redline?
Yeah, I probably don't need to rev it quite that high without cams though.
Originally Posted by maxpowr View Post
27#s of boost...
Yeah, it's more like 29psi on a 4th gear pull. Here's more info:
Updates on my setup. Rotated PTE 6266
Full Details Here:
http://forums.nasioc.com/forums/show....php?t=2484865
Here's a quick speedo video:
Virtual Dyno Plot:
Turbo vs. VF52:
Rotated Turbo Setup:
And a couple more quick photos of the car:
Full Details Here:
Old 03-30-2013, 11:30 AM   #7200
MrSlowbaru
Member#: 129231
2005 wrx
cgm
I need a little bit of insight here, and I thought you it's might be able to help me out. I'm working on a friends car, it is a built 2.0l with a 35r sized turbo, 1100cc injectors, base fuel pressure set at 55psi, hardwired aero 340 pump. Basically I'm maxing out the injectors at 17psi. What is holding me back?
MrSlowbaru is offline   Reply With Quote
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
