Old 03-09-2013, 10:16 PM   #51
blkbugeye
Member#: 287821
2005 WRX STi PSM
*sold* 2002 WRX Sedan MBP
Originally Posted by jaxscuby View Post
Tim,
my dd has 242k and 287 whp @ 16 psi on a vf 30 with supporting mods.
second factory clutch @ 132k. my 2.0 wrx.
its doable goal at less than 3k..
reliable comes down to who drives the car and how.
but some of the factory tunes were/are to lean.
they are still cracking ringland..hpyeruratic cast pistons on stock boost.
spun rod bearings due to oil break down.
I never liked buying someone's problem. well except the ones where i know
the previous owner.
Ben, I never anticipated buying a problem vehicle( should have bought that white one from you!!) But anyways, Ill probably have some work for you when I get back.
blkbugeye is offline   Reply With Quote
Old 03-09-2013, 10:48 PM   #52
C3hutson
Member#: 347969
04 STi
JBP
I'm not twisting ****... A bolt on is just that: a mod that bolts on to the car with little other requirement. Where I come from a bolt on includes any intake mod. You need to use the correct terminology.
C3hutson is offline   Reply With Quote
Old 03-12-2013, 10:34 AM   #53
myblusti
Member#: 337871
2010 5-door STI
blue/gold
yea, my advice is just buy the sti. we'll workon it as we feel the need. who got busted doing 140+ it wasnt the guy in the 350 was it? anyways.
or if you can, buy a used sti with a **** block. dump 4000 on a fresh built block by ams, or one of the others and call it a day. if my rings go again it will be a built block under the hood.
myblusti is offline   Reply With Quote
Old 03-12-2013, 07:05 PM   #54
VinceCarter
Member#: 284694
2006 WRX 6 Speed
277/323 @ EFI Logics
Originally Posted by blkbugeye View Post
Its going to be a DD primarily, with maybe some occasional track use. I would like alittle more than 300 whp.
You can't be looking for that much reliability with these conditions. It's basically luck of the draw though too when it comes to modding. Some people break stuff with way less than the next guy.
VinceCarter is offline   Reply With Quote
Old 03-12-2013, 11:42 PM   #55
TyrannosaurusWRX_
Member#: 349996
I think it has been said before, but staying stock and maintaining your car is the best path for reliability.
If you must mod, then you should consider a built block is in your future.
TyrannosaurusWRX_ is offline   Reply With Quote
Old 03-13-2013, 01:59 AM   #56
blkbugeye
Member#: 287821
2005 WRX STi PSM
No it wasnt the guy with the 350z
But If I cant find a good stock STi, I may look for one with a low mileage built block.
