Old 03-11-2013, 04:04 PM   #1
chip4761
Member#: 55867
2005 Saabaru
AS
Default AWD broken
Saab 9-2x. Manual Transmission.
Symptoms: When accelerating from a stop, there will be a heavy clunk from the rear end and slight jump in the RPM. I think the AWD is somehow disengaging.
Question: How do I test this on jackstands/lift/etc.? I think it requires the rear wheels to have some manner of resistance to disengage, so how do make that happen without getting killed? I need to see if it's the center or rear diff, or maybe just an axle/hub. Any ideas?
chip4761 is offline   Reply With Quote
Old 03-12-2013, 01:18 PM   #2
Gamble_WRX
Member#: 234783
2004 STi
when you do any sort of launching on a 5 speed, even rough clutch engagement, will cause a clunk in the rear diff. you dont need resistance on it nor does it have to be running to test the theory of the AWD breaking. put it on a lift, or jackstands, with the car in gear. turn one of the tires, and look under the car, you should see the Driveshaft rotating. if it doesnt, try the other side. subarus arent acctually AWD... they are, but they arent. the diffs are not LSDs from the factory (unless you own an STi) so only one front, and one rear tire constantly drive. when your cornering, the center diff distributes power to the tires that need it. same thing when you slip in the snow. one tire slips, the other engages. We tested all of this in a parking lot in the snow when i had my old WRX right before the swap.
Gamble_WRX is offline   Reply With Quote
Old 03-12-2013, 06:52 PM   #3
chip4761
Member#: 55867
2005 Saabaru
AS
Err, I think you misunderstand my question. I'm POSITIVE the AWD is broken, but how do I test it when it only disengages under load?
Old 03-12-2013, 07:46 PM   #4
garudatwo
Member#: 322385
Does your parking brake stop the front wheels or the rear wheels?
garudatwo is offline   Reply With Quote
Old 03-13-2013, 09:34 AM   #5
chip4761
Member#: 55867
2005 Saabaru
AS
Unfortunately, my parking brake doesn't do much of anything at the moment. This is what happens when you buy a used car, I guess.
Old 03-13-2013, 10:39 AM   #6
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Get someone you don't care for to hold one axle?
Counterfit is offline   Reply With Quote
Old 03-14-2013, 08:26 AM   #7
mphwang
Member#: 242297
2001 Getter of
Groceries
Sounds like a clutch and a bad mount somewhere.
mphwang is offline   Reply With Quote
Old 03-14-2013, 10:11 AM   #8
chip4761
Member#: 55867
2005 Saabaru
AS
I've tested in on ice after it "disengages." Neither of the rear wheels are getting anything. I'm thinking it has to be the middle or rear diff. I'm picking a rear up from a guy on here, and I guess reselling it or mine if that's not the problem.
I don't mean to sound like a butt-hat, but how would a bad clutch make the rear wheels not drive? My clutch is bad also (I have long weekend ahead of me.)
Old 03-14-2013, 10:14 AM   #9
poly_poly-man
Member#: 262988
2005 Baja Turbo
Regal Blue Pearl
Lift all four wheels off the ground safely, start car, put in first, clutch out.
If all four spin, things are "normal", at least in some regard. You'll probably notice that one of your rears isn't spinning - check the retaining clip on the inner end of the rear axle shaft (or, I'm pretty sure what this is saying is, shove the axle in harder until it works :P)
poly_poly-man is offline   Reply With Quote
Old 03-14-2013, 10:24 AM   #10
chip4761
Member#: 55867
2005 Saabaru
AS
Interesting. I'll give that a try.
