Old 02-21-2013, 03:48 PM   #1751
MSI
Member#: 95419
Originally Posted by boost junkie View Post
Ha yeah not the easiest job anymore, although once the dry sump goes in it'll be a pain anyway since the tank and lines will have to be drained.
Buy a 150$ vacum pump and hook it up to the system when you are ready to drain, saves a lot of time and energy. That or you remove the pulley from the dry sump, and I imagine if you turn that a few times will pull the rest out as well.
Never tried the latter way, but have used a vacum pump before without issues.
-mark
MSI is offline   Reply With Quote
Old 02-21-2013, 03:53 PM   #1752
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car in progress
Good call marky mark, I'll look into that. Lame update (no pics): The wiring harnesses and modified steering wheel with push button switches are here and they look AMAZING. The rest of the electronic components will be here next week and then everything can get mounted in the car and ready for setup and calibration.
Also my brand new Smartycam is for sale, PM me if you want it.
boost junkie is offline   Reply With Quote
Old 02-21-2013, 03:56 PM   #1753
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
brand new meaning the HD version? or the old 480p version?
Old 02-23-2013, 01:34 PM   #1754
boost junkie
Top Scoob 009
Member#: 68273
Someone buy me, need the cash for other parts to get the car up and running!
Old 02-23-2013, 05:55 PM   #1755
biknman
Member#: 47915
2003 GG HC TT
GG-RC 08STI 16OB 96GC2dr
Been wanting one of these for a long time to go with my MXL Pro Dash but just don't have funds sorry.
biknman is offline   Reply With Quote
Old 03-13-2013, 01:39 AM   #1756
Shifter Kart
Member#: 219740
2000 Sti Type R
anyone here? bueller?
hey question: are the front upper strut mounts in the stock position or were they refabricated/moved?
Shifter Kart is offline   Reply With Quote
Old 03-14-2013, 01:45 PM   #1757
boost junkie
Top Scoob 009
Member#: 68273
Still in the stock position, they were just reinforced.
Things are moving along, the wiring harnesses are installed in the car and my new seat and harness are here. All the parts are here for the engine rebuild as well. I'm trying to decide on a clutch and leaning towards an Exedy carbon triple.
Old 03-19-2013, 08:37 AM   #1758
SashaSasha
Member#: 241828
2005 STI
hi! I am trying to make the same exhaust setup as you. My carbon driveshaft just arrived and i find a warning on it that bonds must not exceed 150 degrees Celsius. How are you planning to prevent this? To wrap all the exhaust with a exhaust wrap? Or to make a thermo screen? Or you think the temperature wont exceed 150 degrees?
Thanks in advance!
SashaSasha is offline   Reply With Quote
Old 03-19-2013, 09:29 AM   #1759
climbhigh09
Member#: 254163
2011 WRX 20GXTR
That's 302*F. You shouldn't have to worry, I wouldn't think. Your EGT by the time it approaches your drive-shaft will be less than that. Add the fact that your hottest temps occur while going fast, should be fine.
climbhigh09 is offline   Reply With Quote
Old 03-19-2013, 10:03 PM   #1760
boost junkie
Top Scoob 009
Member#: 68273
We're working on some airflow to cool the tranny and exhaust, and the exhaust will probably be either wrapped or ceramic coated as well.
We have encountered some setbacks with the electronics and I made the last minute decision to switch to a MoTeC M130 ECU. The cabin wiring harness is being modified to suit the new ECU and we should be good to proceed with the setup and getting the car started and moving under its own power.
Old 03-20-2013, 09:53 AM   #1761
RALLYT-WRX
Member#: 9369
F#ck U & Your Stance
BLOD
Simply amazing!
RALLYT-WRX is offline   Reply With Quote
Old 03-20-2013, 02:53 PM   #1762
Visceral
Member#: 16367
2006 Subaru WRX STi
What caused you to make the switch? Who is going to do your tuning? I'm curious who has experience with MoTeC and the Subaru. I have an M800 I may put in my car.
Visceral is offline   Reply With Quote
Old 03-21-2013, 11:00 AM   #1763
boost junkie
Top Scoob 009
Member#: 68273
I'd rather not get into it but I'll just say there were some issues with the Pectel. Not to mention the SQ6, while very capable, is getting a bit long in the tooth. The M1 series ECUs are brand new technology.
Neel from Apex Speed Technology is doing the setup and tuning. He is in SoCal though so I may end up contacting Franz Diebold since he is a very well respected local MoTeC tuner with lots of subaru experience.
Old 03-21-2013, 11:36 AM   #1764
bettner12
Member#: 56179
05 LGT 407hp/372tq
Tuned by [email protected]
Didn't cosworth drop support on the pectal or something like that? I know of another build that dropped that ecu in favor of a motec
bettner12 is offline   Reply With Quote
Old 03-21-2013, 11:50 AM   #1765
boost junkie
Top Scoob 009
Member#: 68273
I don't really know the full story but at this point, I am not really confident in the stability of cosworth electronics in the US. Some things happened that really turned me off to using their product. It is causing a bit of a setback since the main wiring harness was already built for the SQ6 but it's better to do this right the first time. So the harness is headed back to apex to be modified for the M130.
Old 03-24-2013, 08:13 PM   #1766
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Any pics of the carbon undertray?
Old 03-24-2013, 09:06 PM   #1767
boost junkie
Top Scoob 009
Member#: 68273
Probably should see some new pics soon. I know IAG is in the process of doing a bunch of construction on the shop and moving things around so I doubt posting pics is a priority at the moment. The undertray looks amazing though, very cool stuff.
Old 03-24-2013, 09:46 PM   #1768
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Good to hang out Dan
You should have stayed for the rain race...Grace is ridiculous.
I think I see one of those vintage cars in my future.....
Old 03-24-2013, 10:23 PM   #1769
boost junkie
Top Scoob 009
Member#: 68273
Good to see you too Ken. I thought about staying but the sleet/snow wasn't too appealing and drivegear offered me a credit for next month at summit so I took that instead of risking the car in those conditions. Plus I still have summer tires on my car and even leaving at 10am, the first 2 hours of my drive home were white knuckle to say the least. I think I saw at least one accident or car in a ditch every mile.
Not surprised in the least that Robert won again He's hard enough to beat in the dry but he really seems to dominate in the wet.
Old 03-25-2013, 12:20 AM   #1770
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Your build is awesome, and when this is finished it will be very fast on corners. Any plans of putting a dry sump oil system?
berdugo is offline   Reply With Quote
Old 03-25-2013, 10:00 AM   #1771
boost junkie
Top Scoob 009
Member#: 68273
Yes IAG is working on a dry sump system for the car. Most of the components are off the shelf, they just have to design a pan and figure out how to mount the pump.
Old 03-25-2013, 10:12 AM   #1772
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Sounds great, I hope you can post some pics of the setup.
Old 03-25-2013, 10:17 AM   #1773
bettner12
Member#: 56179
05 LGT 407hp/372tq
Why not the ARE 3 stage dry sump? Or is IAG going to be bringing a new product to the table after prototyping on your car?
Having the motor re-configured for dry sump also?
Old 03-25-2013, 10:36 AM   #1774
boost junkie
Top Scoob 009
Member#: 68273
I do believe IAG will have the kit available for sale once it's tested and proven but not 100% sure. They do want to design their own kit though rather than use ARE. Not sure what you mean by reconfigured.
Old 03-25-2013, 10:50 AM   #1775
bettner12
Member#: 56179
05 LGT 407hp/372tq
That's good to hear that we will have more options!
Reconfigured as in using seals designed for high crankcase vacuum pressures. Most oem engine seals are designed to hold fluids in, not keep air out. Sometimes one of the tricks engine builder will do when building a motor for a dry sump system is to install the oem seals backwards. I'm not sure if you have find seals like Peterson fluid systems makes for dry sumped motors for the sizes the ej257 would need.
Do you know how many stages they are planning to use? I would recommend the goodridge 910 Kevlar hose with the convoluted Teflon liner, friend lost a sb1 race motor due to his dry sump pulling enough vacuum to suck shut one of the lines from the oil tank.
Turn in Concepts 2010 Track Car Build Turn in Concepts Press Releases 372 03-21-2012 10:48 PM
My GC Race car build rrsettgast Member's Car Gallery 3 04-27-2010 12:19 PM
Came out to my car... belt on the ground and this (pic). Padge Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-11-2009 10:36 PM
Getting my car closer to the ground BluScopion Vancouver Impreza Club Forum -- VIC 12 02-02-2007 02:30 AM
got car back from the shop, now lights are messed up X2.5RS01X New England Impreza Club Forum -- NESIC 1 02-21-2005 09:41 PM
