Old 05-28-2012, 04:50 PM   #1
apkarian100
Member#: 207053
2013 XV Crosstrek
Default Morimoto xB Angel Eyes on a GR Subaru WRX (Pics)
I installed a set of Morimoto LED angel eyes today on a 2011 WRX. As far as angel eyes go, these are by far my favorite. Very even light, turn on instantly, and brighter than standard CCFL angel eyes. I also painted the headlight shrouds and added HID kits to both the low beams (5000k) and fog lights (3000k). Keep in mind, pics of these angel eyes are taken in broad daylight.
Before:
After:
apkarian100 is offline   Reply With Quote
Old 05-28-2012, 04:51 PM   #2
apkarian100
Member#: 207053
2013 XV Crosstrek
Old 05-28-2012, 04:51 PM   #3
20g07wrx254
Member#: 306217
2007 wrx
white
I like those bro. What did they run you?
20g07wrx254 is offline   Reply With Quote
Old 05-28-2012, 04:54 PM   #4
apkarian100
Member#: 207053
2013 XV Crosstrek
They are $65 a pair on TRS's site.
Old 05-28-2012, 05:03 PM   #5
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
looks really nice and classy~
what lighting options do you have with the angel eyes?> do they have a switch of their own or do they engage as DRLs?
if the latter... would love to know how you wired it.
welldone!
burkart is offline   Reply With Quote
Old 05-28-2012, 05:30 PM   #6
apkarian100
Member#: 207053
2013 XV Crosstrek
I tapped into the parking lights, so they turn on only when the parking lights are on. I suppose you can wire them any way you'd like, but I thought this was the best setup.
welldone!
Old 07-02-2012, 06:57 PM   #7
ScubiSTIle
Member#: 314092
2012 STI 5dr
ISM
What size rings did you use? Looks like you got them big enough to mount further back on the shroud. How would they look if they were right on the rim? (smaller ring, further forward)
ScubiSTIle is offline   Reply With Quote
Old 07-04-2012, 04:15 PM   #8
apkarian100
Member#: 207053
2013 XV Crosstrek
100mm
Old 10-02-2012, 01:25 AM   #9
ScubiSTIle
Member#: 314092
2012 STI 5dr
ISM
So I did this a while ago and I'm just now getting around to posting up my pics. I didn't like the look of the yellow xB's so I picked up some silver tail light tint from Autozone and sprayed them until I could just barely see the yellow. I had to repaint one of them because I used tape to hold them to the shroud while I was gluing them on and the tape pulled the paint up.
Before:
After:
Enjoy! I hear a lot of people complaining about the new chrome headlight shrouds on the '12s and '13's and wanting to swap for the "more aggressive" black ones or painting them, but I wanted to see what all silver and chrome would look like. Kinda reminds of of Silver Surfer or something. So far I haven't seen anyone else doing it, maybe it will catch on
Old 10-02-2012, 12:33 PM   #10
apkarian100
Member#: 207053
2013 XV Crosstrek
Have a link to the spray paint you used?
Old 10-08-2012, 05:30 PM   #11
ScubiSTIle
Member#: 314092
2012 STI 5dr
ISM
Old 10-08-2012, 07:57 PM   #12
apkarian100
Member#: 207053
2013 XV Crosstrek
Thanks man. I'm going to get some and try it out.
Here it is on Amazon.
Rust-Oleum Automotive 260860 10-Ounce Lens Tint Spray,Silver Cast - Amazon.com
I found it at AutoZone in the store, can't seem to find it on their website.
Old 10-08-2012, 08:45 PM   #13
rob1n1
Member#: 276425
2013 335is
Alpine White
Those actually look pretty good. I usually write angel eyes off as ricey but I like these.
Do they look yellowish when they're off or is that just the photo?
rob1n1 is online now   Reply With Quote
Old 10-08-2012, 10:25 PM   #14
apkarian100
Member#: 207053
2013 XV Crosstrek
They are yellowish when off. That's the only draw back. Take a look at a white LED at some point and you'll see a little yellow phosphor coating. These angel eyes have the coating over all of it.
Old 10-10-2012, 09:28 AM   #15
starlightluvsu
Member#: 238682
07 BBLGUN STI
EJ207 V9 swapped
The ones that you can purchase from Lightwerkz doesn't look yellow when they're off, but they seem to only last a year. :/
starlightluvsu is offline   Reply With Quote
Old 02-26-2013, 10:33 PM   #16
apkarian100
Member#: 207053
2013 XV Crosstrek
Well those are CCFL angel eyes. These are LED angel eyes.
Old 02-26-2013, 10:46 PM   #17
FerdSimao
Member#: 280691
2012 WRX Ice Silver Sedan
After:
how easy was to remove the amber reflector from the turn signal? thats exactly what i want to do. and what buld are you using for your turn signal now?
FerdSimao is offline   Reply With Quote
Old 03-01-2013, 10:22 AM   #18
apkarian100
Member#: 207053
2013 XV Crosstrek
2 Screws and the reflector comes out
Old 03-01-2013, 12:18 PM   #19
QueensEng
Member#: 208469
So I did this a while ago and I'm just now getting around to posting up my pics. I didn't like the look of the yellow xB's...
You asked OP what diameter he used then showed your own install, what size did you opt for?
Also what method did you choose for the wiring?
QueensEng is offline   Reply With Quote
Old 03-14-2013, 01:48 PM   #20
ScubiSTIle
Member#: 314092
2012 STI 5dr
ISM
90mm. xB morimotos from the retrofit source. I wired them up as DRLs. Basically I unpluged the OEM DRLs from the resistor and used some wire splices to tap into the signal being sent to the DRLs. Since the resistor is on the passenger side, I had to run a separate wire across to the driver side. It was easy with the front bumper off.
Halos are on with the car running e-brake off and headlights "off" or in "parking light" mode. Halos are off when low beams are on and off when high beams are on.
Old 03-14-2013, 01:51 PM   #21
ScubiSTIle
Member#: 314092
2012 STI 5dr
ISM
Oh and I forgot to mention the ground wiring is to the black wire on the parking bulb on each side. Make sure you splice into the right wire on the DRLs (whichever one is NOT black).
Old 03-30-2013, 11:43 PM   #22
SealTeamPi
Member#: 326857
How did you get the Headlight housing apart? Did you have to bake it?
SealTeamPi is offline   Reply With Quote
Old 03-31-2013, 08:35 AM   #23
S1CkWrx
Member#: 325249
2012 wrx
dgm
yes you bake it in a oven or use a heat gun and you gently take it apart.
S1CkWrx is offline   Reply With Quote
Old 03-31-2013, 08:19 PM   #24
apkarian100
Member#: 207053
2013 XV Crosstrek
Some more pics I had taken from the other day. I've done about 5 sets of LED angel eyes for people now:
Old 04-02-2013, 12:39 AM   #25
jon102034050
Member#: 223895
2010 WRX
looks sick. How are the LED high beams?
jon102034050 is offline   Reply With Quote
Angel Eyes on 2006 WRX paulrus New England Impreza Club Forum -- NESIC 6 12-08-2008 07:47 PM
angel eyes on 07 obp wrx Lamb155716 Member's Car Gallery 24 03-19-2008 08:03 AM
Angel eyes on 06 WRX ( STI ) MoMoZzz Vancouver Impreza Club Forum -- VIC 15 07-13-2006 10:05 PM
angel eyes on a scooby? CRex Interior & Exterior Modification 5 04-05-2002 11:11 PM
Wanna-be angel eyes on a WRX.... FoRCeFeDWRX Bay Area Impreza Club Forum -- BAIC 7 02-13-2002 07:43 PM
