Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 03-10-2013, 07:38 PM   #276
leed
Member#: 336303
2009 OBS
Blue/Silver
Originally Posted by veener79 View Post
Very good deal! I might pick up another set just as a backup at that price!
leed is offline   Reply With Quote
Old 03-12-2013, 03:23 PM   #277
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Just did this wonderful mod. I used regular OSRAM Sylvania H9 bulbs. Pure white in person
Slow Scoobie is online now   Reply With Quote
Old 03-12-2013, 08:32 PM   #278
.HaVoK.
Member#: 229726
'09 2.Slow
I know the plastic in the socket needs to be grinded down but doesn't one of the metal tabs around the outside need to be cut/trimmed as well? Or, will it work without the trimming?
.HaVoK. is offline   Reply With Quote
Old 03-12-2013, 09:26 PM   #279
jcwrx
Member#: 25989
2009 WRX Stage 2+
Lightning Red Hatchback
No trimming of the bezel needed, only the body of the light. Just make sure you know which side to cut. There is a thread on this somewhere. A Google search should find it.
jcwrx is offline   Reply With Quote
Old 03-12-2013, 09:42 PM   #280
.HaVoK.
Member#: 229726
'09 2.Slow
Sorry. I meant is this part necessary:
http://i118.photobucket.com/albums/o.../H9toH11_3.jpg
Seems as though the OP only grinded down the socket tab and not this part.
Old 03-12-2013, 10:43 PM   #281
veener79
Member#: 204304
2008 WRX 4D Stage 2
I did not have to trim down that metal tab.
veener79 is offline   Reply With Quote
Old 03-12-2013, 11:34 PM   #282
jcwrx
Member#: 25989
2009 WRX Stage 2+
I did not have to trim the metal piece of the H9 light bulbs either.
Old 03-12-2013, 11:41 PM   #283
DirknJirkn13
Member#: 249696
2010 Outback Sport
Just ordered Philips H9 bulbs from Amazon for under $15 to do this. Thanks!
DirknJirkn13 is offline   Reply With Quote
Old 03-13-2013, 08:58 AM   #284
.HaVoK.
Member#: 229726
'09 2.Slow
Thanks veener79 and jcwrx!
I've ordered 4 of the Philips H9 as well from Amazon lol. I'm excited to do this mod.
Old 03-13-2013, 07:22 PM   #285
DirknJirkn13
Member#: 249696
2010 Outback Sport
Why 4? Are you putting them in the high beams as well?
Also, anyone have a recommendation for a fog light bulb that will match these well? I'm looking for white and not yellow output.
Old 03-13-2013, 08:08 PM   #286
.HaVoK.
Member#: 229726
'09 2.Slow
Nope. Just didn't want to pay for shipping. It only cost a bit more.
I'll either just keep them stored or sell them to someone in my local subie group.
Old 03-13-2013, 08:47 PM   #287
WilR
Member#: 343078
2013 WRX Hatchback
Does the tab have to be remove completely all the way to the bottom of the connector?
WilR is offline   Reply With Quote
Old 03-14-2013, 12:45 AM   #288
jcwrx
Member#: 25989
2009 WRX Stage 2+
I think the bulb will fit best if the tab if removed fully. I ended up using a box knife with a fresh blade to finish off the job, and mine fit great.
Old 03-14-2013, 04:05 PM   #289
.HaVoK.
Member#: 229726
'09 2.Slow
Made the removals in all the bulbs with a box cutter with ease and finally have them in the low beams. I can't wait to see the difference at night.
Old 03-14-2013, 04:15 PM   #290
WilR
Member#: 343078
2013 WRX Hatchback
With the box cutter where you able to get the tab off completely? I can't get the last 1/8" taken off with the box cutter.
Old 03-14-2013, 04:45 PM   #291
jcwrx
Member#: 25989
2009 WRX Stage 2+
I used a finger nail file to finish the last little bit.
Old 03-14-2013, 04:50 PM   #292
.HaVoK.
Member#: 229726
'09 2.Slow
Well I used a Utility Knife. Regardless, keep scraping away at the last bit of it. It really only took me a minute for each bulb.
Old 03-14-2013, 05:04 PM   #293
DirknJirkn13
Member#: 249696
2010 Outback Sport
One of my bulbs came out of the packaging...I expected more from Amazon.
Old 03-14-2013, 05:13 PM   #294
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
So what's the high bean upgrade other than hir bulbs? Just the regular 9011?
ColeBerkenbile is offline   Reply With Quote
Old 03-15-2013, 12:19 AM   #295
jcwrx
Member#: 25989
2009 WRX Stage 2+
Phillips 9011= DRL/Highbeam
Phillps 9012 = OEM fog lights
The 9011 high beams made a significant difference in total light out put. The 9012 fog light is a cleaner light with more light width on the periphery.
The H9/9011/9012 light modification gives for as much better night time driving experience.
Old 03-15-2013, 12:23 AM   #296
WilR
Member#: 343078
2013 WRX Hatchback
Gotta say, I just completed the install and tested them out. I'm not that impressed. I used the phillips H9 & HIR in the high beams and can't really tell a difference. Even when I only installed 1 side and shined it on the house, couldn't notice a major difference. The HIRs I could tell were a little brighter when I looked directly into the lights but I don't know if its worth possibly burning something up.
I think I will switch back to the bulbs that came with the car.
Old 03-15-2013, 08:00 AM   #297
.HaVoK.
Member#: 229726
'09 2.Slow
I'm starting to realize that the '08-'10 show differences in light output but '11-'13 aren't....
Old 03-15-2013, 10:47 AM   #298
P.Rico
Member#: 239452
2010 Impreza WRX
1991 Prelude Si 4WS
They're the same headlight with the same projector inside.
P.Rico is offline   Reply With Quote
Old 03-15-2013, 11:04 AM   #299
.HaVoK.
Member#: 229726
'09 2.Slow
I know but if you go through the thread isn't weird that a lot of the '12-'13 guys don't really see a difference? I dunno maybe its just me.
Old 03-15-2013, 11:42 AM   #300
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
I never realized that but it's true. People who complain about not seeing much difference in light output are almost all in the newer model car. On my 10 the difference was very noticeable going to the h9 in the lowbeam
need to fix a DIY r134a A/C conversion Niku-Sama Service & Maintenance 4 06-12-2009 09:50 PM
cant seem to find a diy thread on how to 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-06-2007 09:47 AM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-01-2003 07:44 PM
auto to manual conversion with big torque expectations kaneda3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-21-2001 02:01 AM
