Welcome to the North American Subaru Impreza Owners Club Saturday July 26, 2014
Old 03-13-2013, 06:46 PM   #2776
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Originally Posted by my99210kw View Post
Anyone know what the max angle would be on the 6258 prior to issues with oil return or oil going through back seal? Got two of these going on forged ez30r. Image of installation via link
https://www.dropbox.com/s/4ua07iqmyn...pg?n=152903952
+/- 20% of vertical for the oil drain line. I also recommend that anyone installing one read the EFR tech brief. All questions are answered there.
Old 03-13-2013, 06:48 PM   #2777
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Originally Posted by GA scooby View Post
Are you done with break in yet man?! Crank up the boost and let's see what that thing makes!
I'm a little scared to turn the boost up on this motor. The build has begun on the bullet proof sleeved 2.34L motor though. That one will take whatever I can throw at it.
Old 03-13-2013, 09:31 PM   #2778
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
very nice! wish i was building a 2.34!! super jelly
Old 03-13-2013, 09:45 PM   #2779
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
whats up with the boost plot on the dyno?
Old 03-13-2013, 10:09 PM   #2780
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Me?
If so his boost pickup was giving him issues and I was told to disregard. Actual boost is 15psi to redline.
Old 03-13-2013, 11:47 PM   #2781
my99210kw
Member#: 180429
99 WRX
Dark green
Only referance to 20 degrees is left or right. My issue is nose up or down for which there is no spec just says should be flat which is not an option in my case. Garrett give a spec on this
https://www.dropbox.com/s/4n0b35w6ckax3z7/m3.jpg
Refer WRC turbo location and angle
my99210kw is offline   Reply With Quote
Old 03-14-2013, 08:43 AM   #2782
Leafy
Member#: 330625
2006 WRX
Call Borg, their tech people will either know, or at least be able to find out.
Old 03-14-2013, 06:31 PM   #2783
guitarsurgeon
Member#: 290509
15 degrees is max angle
guitarsurgeon is offline   Reply With Quote
Old 03-14-2013, 07:31 PM   #2784
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Re-reading the EFR Tech brief they say mount the turbo as level as possible longitudinally and avoid to much nose up or nose down attitude. It sounds like they only tested it in the horizontal position so I guess its up to you to push it on the angle and report back when oil starts getting past the seals.
"The bearing housing oil drain should be pointed straight downward where possible, and at most 20 degrees tilted right or left. When routing the oil drain line, try to keep it running downhill all the time and avoid horizontal spots or sharp bends. The oil should drain to the block or pan in a low pressure region above the level of the oil bath. It is not recommended to install the turbo considerably nose-up or nose-down. It was validation tested to be installed “flat” with respect to the ground." ==> from EFR tech brief
You're aware that the WRC turbo in question that mounts almost vertically cost about as much as a new Subaru if not more. I wouldn't expect to find many other turbos that would like that position.
Old 03-15-2013, 10:12 AM   #2785
climberd
Member#: 183019
05 LGT Stg3 Wgn
That WRC turbo is also replaced after every race, as it is also fed anti-lag. At least that's what a WRC tech told me when looking over the car.
climberd is offline   Reply With Quote
Old 03-16-2013, 04:07 PM   #2786
guitarsurgeon
Member#: 290509
My tuner claims he had one on the dyno, nose up at 20 degrees an it was leaky, the other ones were under 15 degrees and held fine, so from first hand I don't recommend more than 15 degrees
Old 03-21-2013, 04:49 AM   #2787
my99210kw
Member#: 180429
99 WRX
Dark green
Default EFR 6258 v-band and flange
Can any of the vendors supply me with v-band flange and clamp x 2 for my two EFR6258 turbo's. My email is tony.dobnik@gmail.com . Sorry to be off topic but am desperate for the supply of these parts as they are stopping me from having my car up and running. My postage address is 38 Bathurst Rd Orange NSW 2800 Australia. Locally I have had nothing but run around with no results and one US supplier after a week of emailing has told me two week wait as out of stock.
Hope someone can help.
Cheers,
Tony
Old 03-21-2013, 07:20 AM   #2788
Leafy
Member#: 330625
2006 WRX
Cheers,
Tony
Buy from treadstone. They currently sell the best clamp for the EFR v band and have 2 options for flanges. One flange option even lets you run a 3.5" downpipe straight off the turbo.
Old 03-21-2013, 07:25 AM   #2789
my99210kw
Member#: 180429
99 WRX
Dark green
Treadstone apparently are out of stock for 2 weeks
Old 03-21-2013, 07:34 AM   #2790
Leafy
Member#: 330625
2006 WRX
Well that sucks. I guess I would wait for those and just grab the crappy one from Borg Warner which you can buy from full race or any other BW dealer, if you need it now. The one from BW will likely last one or two times taking the turbo off before you turn the threads into mush.
Old 03-21-2013, 03:11 PM   #2791
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Originally Posted by mofoSTI View Post
Thanks guys. I'm going to run the 6258 and try to squeeze the most out of it. Then down the road go bigger when i get use to the power. Keep in mind that stock power is enough to get one in trouble. I will get use to 375 - 400 whp before i go for more. I already had an 04 STi running 355whp and 390 lbft to the ground.
FYI I get ~15 psi at ~3200 RPM with the 6758 ... on a 2 liter (EJ207). It spools very close to a vf39. A 6258 is going to spool very quick on a 2.5L.
Old 03-22-2013, 02:03 PM   #2792
guitarsurgeon
Member#: 290509
Originally Posted by TickTack
Yes, this was with about 30min of tuning on the road, just to get the car broken in and running before winter hit. Tuner thought it might have 570whp in it before I need a bigger turbo. Stock head ports, stock valves, radius valve job, BC valve springs/retainers, GSC S2 cams. Has GrimmSpeed TGV deletes and ported manifold. It's a street car that'll see occasional the drag strip or road course.
Also, this was my first trip around the block with the car, very little throttle and almost no boost. Man are these turbos loud!
Video Link: http://www.youtube.com/watch?v=GXO5S3dRIkQ
Video Link: http://www.youtube.com/watch?v=EL91a8lBSxU
Don't run your throttle body like that. At partial throttle it is gonna mess up flow from cylinders 1/3 and 2/4 due to how the flap works. At idle and wot it would be fine, but not worth the risk IMO
Old 03-22-2013, 02:21 PM   #2793
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.9@142
I run mine 90* like that without issue.
06rexwagon is offline   Reply With Quote
Old 03-22-2013, 02:29 PM   #2794
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
disagree, it works perfectly... been doing this for years
Full-Race Geoff is offline   Reply With Quote
Old 03-22-2013, 02:30 PM   #2795
azn2nr
Member#: 35276
2006 2.5i clone
438/420 whp
2007 STi Limited
Link G4 Extreme Pro ECU
Wiseco 100mm pistons 8.5:1 CR
DPR ported heads, +1mm valves
Cosworth 272 cams
Full Race 7670 TS turbo kit
Greddy EVO exhaust(I think)
Aeromotive custom fuel rail setup
Custom FMIC kit
3" custom CAI
etc, etc, etc...
Currently hitting 15 psi @ 3200 rpm holding to redline.
The car is ridiculously fun to drive and proves to me it was worth the wait every time I start the car up.
how do you like that link ecu? is it the plug and play one? does it retain cruise control and ac functions?
azn2nr is offline   Reply With Quote
Old 03-22-2013, 02:38 PM   #2796
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I love it. It works as advertised and I love the software and capabilities of the unit. Mine is not the replacement board model its a wire in model with an adapter harness that connects my factor harness to it. You get a few extra ins and outs with the wire in model and mine will drive high and low impedance injectors.
I've been told that in a future update they will implement cruise control and currently the inputs are there in the ECU when that becomes functional. The car still has A/C.
Old 03-22-2013, 04:23 PM   #2797
azn2nr
Member#: 35276
2006 2.5i clone
438/420 whp
did you make your own harness connecter or did you buy one? if you bought it where did you get it from?
Old 03-22-2013, 04:30 PM   #2798
kellygnsd
Member#: 32669
LINK G4 hybrid STi
They used to sell an adapter harness but not anymore since they have the PnP replacent board options. Now its either replacement board or full wire-in.
I have some pics of the adapter harness in my build thread if you want to check it out.
Old 09-13-2013, 02:53 PM   #2799
grigory
Member#: 360727
Have anyone good logs or dyno graphs of S200sx 7670 and S200sx 8070?
on 2.5 subaru motor with twinscroll header
would like to go with fast spooling turbo, 7670 need to be purchased with additional (smaller than std. 1.22 A/R) turbine housing so it's kind not so cost effective as 8070, which could be then easily swapped with s300sx 8375 for mooore power and also it fitted with 0.91 A/R housing that should give good response and spool.
so need some more info to make decision
grigory is offline   Reply With Quote
Old 09-13-2013, 04:39 PM   #2800
RexFTW
Member#: 107179
2012 S4 Black
03 WRX S400 Black
My S400SX FMW 1.25 AR T4 build:
Should be turning it up to the 600-700 wheel range in the near future, then I will need to work with the fuel system to squeeze a bit more out of it.
2.6L ej257 (79mm stroke, 4" bore), sleeved, o-ringed, cosworth crank, spinning 8800
v7 ej207 heads, cnc'd, ported, polished, +1mm valves, springs, retainers, Kelford 280s
ARP 625 outer studs, 13mm inner studs
Will be running e85 then switching to e98 or ignite red when turning it up.
RexFTW is offline   Reply With Quote
"Official" Post your suspension setup and settings thread. ScreaminFast Brakes, Steering & Suspension 19 09-14-2011 09:59 AM
Post Your Winter Setup in here. car_cursed Member's Car Gallery 43 10-26-2008 01:12 PM
Post your Exhaust setup. Teh Legacy Legacy Forum 32 06-24-2005 03:44 PM
Post your room setup here. file_id Off-Topic 26 04-15-2004 12:03 AM
Post your SM setup!!! Davenow Motorsports 66 01-10-2004 03:12 PM
