Old 03-13-2013, 06:40 PM   #5901
stlnation
Member#: 321805
2002 Jdm v9 STI
Originally Posted by 25rsti View Post
I grounded mine.
Lol.
I really don't know why I even asked. Thats what we did just wondering if anybody already had the ground there or did you just throw something together
stlnation is offline   Reply With Quote
Old 03-13-2013, 06:52 PM   #5902
25rsti
Member#: 166324
I made a spade connector for mine but when I got my motor it was unexpected to see that. I posted pictures here and asked, not many people had it. I wonder if it's just a v9 thing. Post a pic if you don't mind, just for comparison reasons.
Old 03-14-2013, 10:17 AM   #5903
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
Originally Posted by stlnation View Post
What did you guys do about the ground that comes of the motor right by the turbo.
Sorry, which ground? Got pictures? I'm curious if I'm missing it.
Computersare8ad is offline   Reply With Quote
Old 03-14-2013, 10:48 AM   #5904
xthecursex
Member#: 224079
Originally Posted by JulianDelphiki View Post
Yeah, lined up for immediate install I have(most are for longevity and reliability)..
Killer B oil pickup
Timing belt/idlers
Walboro fuel
Whitebugeye wiring harness
Turbo Inlet
Custom welded catless DP
K/N Typhoon
E-Tune
Hopefully around 290-300whp is attainable with a conservative tune
300Whp Should be no Issue at all. I made 310 with a 20g and Id 1000s at 19psi and no working avcs. and a super safe tune. we had to cut it short because the avcs wasnt working.
xthecursex is offline   Reply With Quote
Old 03-14-2013, 12:36 PM   #5905
JulianDelphiki
Member#: 307912
1997 OBS V8 Ej207
Stimikey tuned
Sweet.
Heres a video of the cold compression test of my potential motor.
137, 140, 135, 131
The last cylinder is a little low, but nothing to be worried about....Right?
JulianDelphiki is offline   Reply With Quote
Old 03-14-2013, 09:25 PM   #5906
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Only about a 7% difference from min to max so that is not too bad. I know the valves on my motor were pretty dirty when I got it and leaking a bit. Turning it over by hand a bunch got them to seal better and once it was running all the crud came off and they seal nicely.
Old 03-18-2013, 11:46 AM   #5907
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Is anyone running 20-40k miles on a swapped motor ?
I am still debating the long term reliability of a 207 on the stock vf37.
Gigs90 is online now   Reply With Quote
Old 03-18-2013, 12:05 PM   #5908
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
Roughly 32k on my motor when installed and I'm at roughly 72k now. Timing belt needs to be done at 69k(I'm trying to get mine done ASAP) but its been going strong on the stock vf30 with 21psi.
mrxr250rider is offline   Reply With Quote
Old 03-18-2013, 12:10 PM   #5909
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
I've got 100k+ miles on the 207 swap. The first 30-40k was a trial by fire by the previous owner with tons of nitrous with a 30r. The stock vf37 will probably give up its ghost before the motor goes bad if everything else is taken care of and a good tune.
Old 03-18-2013, 12:15 PM   #5910
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
Dear god that motor held up.
Old 03-18-2013, 01:51 PM   #5911
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
a ej25 would have blown a long time ago. just shows the toughness of the ej20 engine and the ej207 specifically. They will take much more abuse than the vf turbo will throw at it. I got 10k miles on my swap since I got it and no problems yet, knock on wood. a tune is everything as stlnation just found out.
Old 03-18-2013, 02:33 PM   #5912
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
The pistons in the V8 kinda worry me but they seem to lack all the problems of the ej257.
I would have my motor tuned by phatbotti tuning.
Old 03-18-2013, 03:29 PM   #5913
maximus88
Member#: 99103
2003 WRX STI ej207
Yellow
I got around 145,000 kilometers on my motor. It Runs strong and has no problems at all just make sure you change the oil and do all the maintenance that is required. Oh and make sure you have a good tune.
maximus88 is offline   Reply With Quote
Old 03-18-2013, 06:41 PM   #5914
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
Ok I brought this up a while ago and already bought the parts... Any tricks I need to know when replacing my valve cover gaskets on my 207? I've never changed one... Even on my 205. Do I NEED to use the Subaru "Three Bond 1207c" P/N: 004403012 as indicated numerous places or can I simply use grey liquid silicone gasket? I usually use the recommended materials but if I don't NEED to buy it I'd rather not since the gaskets rarely get changed AND this PARTICULAR part number is ONLY specified certain places. I DO own the other three bond by Subaru 004403007 which is pink in color. Used on transmission oil pans and stuff.
I'm sure it isn't THAT difficult but any experienced knowledge would be greatly appreciated. I usually see videos and stuff of ONLY the passenger side. The drivers side is a lot tighter spaced than the passenger side. How much more difficult isn't and anything that I need to be careful of? Video?
I like to fully prepare myself so I know what to expect. I did not purchase the half moon pieces as I don't see them as critical replacement pieces that NEED to be changed unless they are specifically broken one leaking.
iNfEk is offline   Reply With Quote
Old 03-18-2013, 06:54 PM   #5915
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
i wouldn't use the pink stuff, grey should work fine. I actually used permatex right stuff black and it worked well. No leaks yet
I can only suggest to have lots of towels on hand to wipe up any oil from mating surfaces if you plan to do them while the motor is in the car.
If you have access to a hoist, you can swing the motor side to side if you really need to make more room. Do NOT over tighten the 10mm valve cover bolts during reassembly, they will snap and make everything a pain in the ass.
Old 03-18-2013, 06:58 PM   #5916
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Good call. What's the torque spec? I'm lazy to look it up. LOL. I understand floating the engine. But for valve covers hat a bit ridiculous since ill have to remove a lot from under the car to get the engine out enough you know?
What about a shimmying sequence. LOL.
Old 03-18-2013, 07:04 PM   #5917
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
Any of you guys using the grimmspeed heatshield? I see it says it's for LHD cars only, so I'm not exactly sure if it will fit our RHD motors in a LHD car... Was hoping to hear if anyone had used one successfully.
Old 03-18-2013, 07:07 PM   #5918
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Well the difference between LHD and RHD for turbo head shields are that the clutch master and brake master are over the turbo so the hear shield may not fit over properly or how it's designed. If the bolts line up I can't see why not. LOL
Old 03-18-2013, 07:14 PM   #5919
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
lol, i wasnt suggesting to remove the engine, but just undo the pitch mount and mount bolts necessary to float the engine from side to side.
from this thread its 4.7ft/lbs (double check the FSM), maybe you can find additional tips here http://forums.nasioc.com/forums/show...9#post38421429
Old 03-18-2013, 07:14 PM   #5920
simon021
Member#: 157532
2002 MY03 EJ207 E85
Thanks a lot. I'll be sure to report back with the fitment.
Old 03-18-2013, 07:17 PM   #5921
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Thanks homie. I was just looking at that thread now. LOL
I'm worried about the JDM AVCS sensors when removing and reinstalling.
Old 03-18-2013, 09:19 PM   #5922
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
I'm using a grimspeed heatsheild on my v7 with no fitment issues
Old 03-19-2013, 12:02 AM   #5923
amroof
Member#: 211224
2005 Saabaru
Who knows
And the track day the next day helped too!
Old 03-19-2013, 12:03 AM   #5924
amroof
Member#: 211224
2005 Saabaru
Who knows
Does anyone have the ecu pin outs for a 581 jdm ecu. Im trying to find the pins for the cam position sensor. The one run off the drivers avcs gear.
Old 03-19-2013, 01:08 PM   #5925
simon021
Member#: 157532
2002 MY03 EJ207 E85
The twin scroll downpipe I have has the 02 sensor bung too close to the flange and the grimmspeed heatshield wont clear.
I was bummed
