Old 03-13-2013, 10:40 PM   #1
EchoFourBravo
Member#: 262582
Default This is what will eventually go wrong when you power shift.
http://www.youtube.com/embed/Uf9NzVRWySE
By all means, power shift away! If you mess up though, this is what will eventually happen. The bill for this will be ~$2,000.
EchoFourBravo is offline   Reply With Quote
Old 03-15-2013, 01:20 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
That, sir, is not only a GREAT video to make the point, but also a good overview of the guts of the tranny and how things work.
My hat is off to you!
Old 03-15-2013, 12:21 PM   #3
EchoFourBravo
Member#: 262582
Maybe I can get a discount next time I order parts?
Old 03-15-2013, 01:52 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Yes that was a very educational video.
Seeing those splines completely distorted and misshaped... wow. Lots of force in there.
Old 03-15-2013, 02:11 PM   #5
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Wow, that was a great video! It looks like the burrs created by forcing the transmission into gear were interfering with proper operation. Were the synchro cones completely worn out on this tranny? Or is it possible to force it into gear (before synchronization) even with a working synchro? I understood that it would be more or less "locked out" until it all came up to speed (assuming the synchro is working properly).
Another note is that the 2nd gear dog teeth are not symmetrical like the 1st gear teeth. I don't have a photo of each gear seperately, but here's a photo of my blown up gearset. I believe you can see the symmetrical dog teeth on 4th (like 1st in your video), and non symmetrical teeth on 2nd and 3rd. Any insight on why they are different?
Old 03-15-2013, 02:54 PM   #6
EchoFourBravo
Member#: 262582
They're probably different because they're engaged at more speed than than 1st is (which is usually with the car stopped). For the rest, I don't know. The synchros were fine though.
Old 03-15-2013, 10:10 PM   #7
97cv
Member#: 151048
2003 Baja
Black/ Silver
Is there a marked photo I can see ?
I'm very interested in how the 5mt works and this thread is all I've come across with any explanation.
97cv is offline   Reply With Quote
Old 03-16-2013, 02:39 PM   #8
EchoFourBravo
Member#: 262582
I guess I'll make a video of how a 5mt works, it's seemed pretty popular so far. I just replaced mine with a PPG one and think mine had a bearing go out. I won't promise a time, but look forward to it
Old 03-16-2013, 03:44 PM   #9
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
This should a sticky thread in this and all "noob" forums.
PSolbergfan is offline   Reply With Quote
Old 03-16-2013, 05:38 PM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The 1-2 would have been better if Subaru gave us a shorter 2nd gear like a 2.062 ratio, or ran the same gear set they had since the Ver5 GC8. The big gap in gear spacing makes the synchro work harder when shifting fast. you could reduce the wear by running a lighter clutch disc.
