Old 03-15-2013, 02:22 AM   #1
horizonsky
Member#: 326561
Default Dash Clock
Hello, i took apart my dash clock from a 2002 wrx and i see that the resistor r510 has completely fell of the motherboard...ide like to fix it but i dont know where to buy this resistor and what kind i should get, help would be appreciated thanks.
horizonsky is offline   Reply With Quote
Old 03-15-2013, 03:00 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Hopefully you can just clean up the solder where it mounts on the PC board and just resolder the resistor back in place. If the ends of the resistor are damged and can't be redone then I think the resistor is a 51 ohm @ 1 watt. You should be able to get one from Digikey. You could also use a carbon film resistor instead, which are easier to get.
Cougar4 is offline   Reply With Quote
