Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 02-20-2013, 10:58 PM   #1
orest100
Member#: 329931
2004 wrx
Default intake/turbo flutter!
Need some help, 04 wrx with really bad flutter when i let of the gas in any gear or throttle! this is what it sounds like
im running a front mount with a bov and 16g turbo
Ive tried different blow off valves and adjusting them and it still flutters. could i have a bad vacuum for the bov?
orest100 is offline   Reply With Quote
Old 02-21-2013, 01:43 AM   #2
StMstr03X
Member#: 345936
Mine did the same thing could be tgv's goin bad?
StMstr03X is offline   Reply With Quote
Old 03-15-2013, 06:41 PM   #3
orest100
Member#: 329931
2004 wrx
Fixed it, installed the stock bpv and flutter went away
Old 03-15-2013, 06:46 PM   #4
liltoua
Member#: 206802
1998 2.5rs
yea that's what we call a compression surge in the turbo world
liltoua is offline   Reply With Quote
Old 03-15-2013, 06:48 PM   #5
25rsti
Member#: 166324
02 V8 Spec C 03
V9 Limited 2013 Legacy
#1, you RHD?
#2, you have a built motor?
#3, if no to #2 do you have a ticking sound from your motor?
25rsti is offline   Reply With Quote
Old 03-19-2013, 11:32 AM   #6
orest100
Member#: 329931
2004 wrx
Yea i do have a ticking sound
Old 03-19-2013, 04:50 PM   #7
danger1138
Member#: 279525
04 rex luger!
What kinda oil u running?
danger1138 is online now   Reply With Quote
Old 03-19-2013, 08:27 PM   #8
orest100
Member#: 329931
2004 wrx
Was running castrol gtx 5w30 but literally switch to rotella t6 5w40 an hour ago
Old 03-19-2013, 10:04 PM   #9
danger1138
Member#: 279525
04 rex luger!
Yes! MAybe thicker oil might cease the ticking.
Old 03-20-2013, 07:21 AM   #10
orest100
Member#: 329931
2004 wrx
Oh the video isn't my car, the valve ticking is bad in that video.
Old 03-20-2013, 07:32 AM   #11
Turd Nugget
Member#: 346017
Good you got it fixed, its really not good for the turbo. It should have been obvious this was the BOV not opening, you could have just adjusted it correctly or like you did probably for the better put the stock one back on.
Turd Nugget is offline   Reply With Quote
Old 03-20-2013, 10:07 AM   #12
Gamble_WRX
Member#: 234783
2003 WRX Wagon
Compressor surge is completely safe and normal, and not bad for the turbo in any way shape or form. i read an article a few years back written by the engineer that pretty much designed the turbo, and compressor surge is normal with any turbo setup, its just ussually very faint. he also said that compressor surge is by no means harmful, and i have yet to ever read a "i had compressor surge and my turbo blew" thread.
as for the BOV, it needs to be correctly adjusted to do away with with the surge, running the Stock BPV is fine, but if you want your blowoff back, you just need to adjust it so it acctually blows off correctly.
Gamble_WRX is offline   Reply With Quote
Old 03-20-2013, 01:56 PM   #13
orest100
Member#: 329931
2004 wrx
The surging killed my 20g after only 3000 miles it
Old 03-20-2013, 01:59 PM   #14
orest100
Member#: 329931
2004 wrx
I tryed adjusting the BOV many times with different springs, even if I had it set really soft it would still surge or open at idle. I might have just bought a ****ty blow off valve plus I think it hAs something to do with running a front mount all that extra space and the way the air is running through.
Old 03-20-2013, 02:02 PM   #15
orest100
Member#: 329931
2004 wrx
If you still want the BOV sound, you can just eliminate the return hose from the bpv and plug the inlet hole. I don't see anything wrong with doing that, no flutter and still have the sound
Old 03-20-2013, 05:41 PM   #16
GhostSenshi
Member#: 279449
2004 Perrin Stg2+WRX
Platinum Silver
As much as I love the surge sound... yea it's best to run that bpv instead lol.
GhostSenshi is offline   Reply With Quote
Old 03-20-2013, 09:23 PM   #17
bluemk3
Member#: 263694
World Rally Blue
Let me guess. A God speed turbo???? A little surge won't hurt anything. Besides, the sound everyone refers to as surge isn't really surge.....
bluemk3 is offline   Reply With Quote
Old 03-20-2013, 10:37 PM   #18
orest100
Member#: 329931
2004 wrx
Yea, but first time it died was because bov was seized and didn't open and I had just got the car not know much About it
Old 03-20-2013, 10:39 PM   #19
orest100
Member#: 329931
2004 wrx
Isn't it compressor stall? As you let throttle off all the air rushes straight back to the turbo
Old 04-05-2013, 07:14 AM   #20
Gamble_WRX
Member#: 234783
2003 WRX Wagon
No, compressor stall refers to Turbine Engines. compressor surge is the politically correct term. Basically, the mechanics are, when the throttle plate closes, the turbo is still spinning and generating pressure, being that the air has nowhere to escape, it flows back onto the compressor wheel. this causes the compressor wheel to essentially lose grip on the air its trying to throw in, and some of the air escapes past the compressor. In that instant, the pressure in the intercooler piping drops momentarily, and the compressor gets a hold of the air, throws it back in, and the process repeats. which is why its a repeated "chuffing" sound. Hopefully this dispells some myths. the sound of compressor surge is simply, the sound of the air on the fins. in a strange process of escaping the pressurized area. The turbo, Does not spin backwards, nor does it stop momentarily. hope this helped!
And as for the godspeed turbo, you spent 300$ on a turbo, and thought it would last?
Cost, Reliability, performance. <pick two. you cannot have all three.
Old 04-05-2013, 07:25 AM   #21
Gamble_WRX
Member#: 234783
2003 WRX Wagon
Did you know, at one point, turboed vehicles didnt use any sort of blow off, or bypass valve? and compressor surge was how it came from the factory?
Message Board Statistics All times are GMT -4. The time now is 01:00 PM.
