Old 12-24-2012, 01:29 AM   #51
g-Know
Member#: 274470
2009 WRX Wagon
Pearl
Hey guys,
So after fighting with the SOA and going back and forth, they took care of the entire repair, which they said was about $1900. I basically copy and pasted kingsalami's letter to them, waited for a call after a day or two, and they asked me to take the car into my local dealer. At that point, I also informed the dealer of the issue, and they basically went back and forth with SOA. SOA first offered to only cover $1000 worth of repairs, but I didn't back down. After speaking to a few supervisors, they finally agreed to cover the entire repair. For any of you in LA, Subaru of Glendale are the ones that took care of it. The service manager there is great, although I blanked on her name.
Asides from an exhaust and wheels, our WRX is stock. But I can definitely see how it's easy for them to put the blame on you for this issues, if your car looks even remotely close to being "raced."
g-Know is offline   Reply With Quote
Old 12-28-2012, 12:10 PM   #52
d_pieCe
Member#: 294584
2008 WRX STI 5dr
Lightning Red
I'm experiencing the same issue, started with a creak, then a clicking, now the whole firewall flexes. I'm literally sitting at the dealership and they're saying there are no service bulletins or recalls.
I admittedly have an aftermarket clutch in my 08 STi and they're trying to cite that as the cause.
I just got off the phone with SOA and fed them all the info including the fact that I have an aftermarket clutch. And they're supposedly talking to the dealership. Hopefully I don't get entrenched in a bitter protracted affair as I've been reading about. I'll follow up if I have any good news or advice and I plan to use as much info as I can from this thread to fix the issue. Best of luck all...
d_pieCe is offline   Reply With Quote
Old 12-29-2012, 02:38 PM   #53
WRX in WI
Member#: 304333
2009 WRX
Gunmetal
Sorry to press the issue but do you have any updates for us?
WRX in WI is offline   Reply With Quote
Old 01-02-2013, 01:20 PM   #54
BradX978
Member#: 334143
2008 WRX
Vin Diesel.
Fighting with rt 2 hyndai (where I bought the car) SOA, and north end subaru all at once. This sucks.
BradX978 is offline   Reply With Quote
Old 01-07-2013, 07:28 PM   #55
Hwaang
Member#: 169271
2008 wrx
white
I got the same old copy/paste answer with mine Think it's still worth a shot taking it up with my dealer? I have had the clutch pedal assembly replaced under warranty about two years ago for the same problem. This did not fix the problem and it has been getting worse ever since.
"Thank you for taking the time to contact Subaru of America, Inc. and I am sorry that your email was prompted by your dissatisfaction with your 2008 Subaru.
I had the opportunity to review our records for your vehicle and can assure you that there are no recalls and/or service campaigns for your vehicle. Additionally, there is no guarantee or average life expectancy that I could provide to you as to how long components or vehicles will last. Please understand that the longevity of any component/vehicle may be affected by any number of factors such as, but not limited to: repeated short distance driving, road conditions, weather conditions, driving in areas where road treatment materials are used, living in coastal or maritime climates or elevated areas, towing, off-roading, extensive trip driving, and operator driving habits, improper or incomplete maintenance, etc. Additionally, it is very difficult for me to provide you with an accurate diagnosis of your vehicle via email. Therefore, I would recommend that you contact an authorized Subaru dealership to allow them the opportunity to inspect your vehicle and make an accurate diagnosis and repair, if necessary.
Once again, thank you for your email and please let me know should you have any additional questions and/or concerns."
Hwaang is offline   Reply With Quote
Old 01-07-2013, 11:04 PM   #56
young_skywalker
Member#: 290707
2008 WRX Hatch
Yes. That's where I started and never had the need to contact SoA.
young_skywalker is offline   Reply With Quote
Old 01-09-2013, 01:39 AM   #57
Speed Assault
Member#: 289598
2008 impreza wrx
Looks like I am next in this issue.
I thought I would add some lube on the mechanics to solve the creeks/squeeks but as I push the clutch with my hand I can see the clutch lever/brackets assembly all flexing all the way across towards the main mount off the firewall. no flexing on the firewall itself though like you guys mention.
So what is the fix here? sounds like welding on steel braces onto the existing brackets right?
Sounds like fighting with dealer may get you another assembly that will again in time squeek again.
my toyota had a poor design clutch bracket and they actually designed a new one, I bought it at discount and I even added welds to it and it was mint.
I do have a exedy stg 2 clutch but Subaru (the world champs in rally racing) should know better and not use such thin metal for a clutch bracket.
Please point me where to get evidence that Subaru knows this is a problem ?
Can someone inlighten me and tell me what SOA is?
also, is there a term dictionary on this forum to translate all these different terms?
08 impreza wrx 50k
Bridgestone Pilot Sport 225/17- awesome tires
Speed Assault is offline   Reply With Quote
Old 01-09-2013, 06:47 AM   #58
young_skywalker
Member#: 290707
2008 WRX Hatch
Search is your friend
SOA = Subaru of America
Working with your local dealer was successful for me.
Old 01-09-2013, 10:37 AM   #59
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
This is not specifically related to the firewall cracking issue, but it can have similar symptoms. My clutch linkage broke and eventually fell out, which resulted in my clutch pedal going straight to the floor while I was driving, leaving me with no way to actuate the clutch itself. I had my clutch master cylinder replaced by the dealer 2 years ago and I assume there was an assembly error which caused the failure. More info and photos can be found here:
http://forums.nasioc.com/forums/show....php?t=2451989
Just another thing to keep an eye out for if you have any strange noises in the clutch area. I wish I had looked for it before it completely failed while I was driving. My welds still look fine, and my new fix for the linkage should be better than stock. I do hope the welds hold out!
Old 01-09-2013, 02:15 PM   #60
BradX978
Member#: 334143
2008 WRX
Vin Diesel.
http://autoaccessoriesperformance.co...et_p_7513.html
Anyone have any opinions on this? I'd try to get it from perrin directly not this site. I'm at work so I just googled it.
Good experiences? Horror story's? Doesn't do anything?
Old 01-09-2013, 03:50 PM   #61
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That's for the brake master cylinder. GrimmSpeed has been selling this for years:
http://www.grimmspeed.com/catalog/pr...roducts_id=213
It is great to have, but it's not a fix to the clutch/firewall breaking issue.
Old 01-22-2013, 09:36 AM   #62
d_pieCe
Member#: 294584
2008 WRX STI 5dr
Lightning Red
It's now about a month later, I've actually gotten SoA to attempt to put it through on my extended warranty. I'll keep you guys posted and if it does go through I'll put up my claim number, but this will only be relevant to those with the extended warranty. I was fortunate enough to buy mine from the dealership in '11 and they let me renew the 100,000 mile bumper to bumper and extended warranty.
Old 02-04-2013, 10:09 AM   #63
TuningIsLife
Member#: 191380
2014 Jeep Wrangler
Hydro Blue
I am having this issue as well and it drives me nuts. Especially this winter when it has been shifting between 60F one day and 28F the next. My pedal will squeak and click, but not together and I also noticed the brake pedal assembly move when I press and depress the clutch pedal.
I drove it down to a Subaru dealership I want to deal with, but of course it was not making the noise when I did. I was going to pick up the master cylinder brace from Grimmspeed, but if it does not work, then it is not worth the $100.
I swear, I had less problems out of my xB, which had higher milage too.
TuningIsLife is offline   Reply With Quote
Old 02-04-2013, 10:21 AM   #64
Wrxknight8
Member#: 185855
2008 WRX
I just had the same experience! Early last week for three days, it was hovering in the teens and my clutch went from squeak to creak. You can feel the vibrations in the brake pedal as well and I'm thinking it has to be the welds! I stay off my rex for a few days until an appointment with the dealer later that week. Behold - no noise with with exception of a little squeal! They lubed and tightened the assembly - quick bandaid fix. When it gets warmer I'm gonna take at look at the welds. Keeping an eye on this thread...
Wrxknight8 is offline   Reply With Quote
Old 02-04-2013, 10:43 AM   #65
young_skywalker
Member#: 290707
2008 WRX Hatch
The M/c brace will not solve your squeak issue, but it will improve the feel of the brake pedal. It was worth it to me.
Old 02-05-2013, 12:21 PM   #66
tmburke
Member#: 342345
2008 WRX Hatch VF-52
SSM
Just spoke with my dealer and the clutch fix could take up to a week. A week without my baby :-/!
tmburke is offline   Reply With Quote
Old 02-05-2013, 06:41 PM   #67
cheech315
Member#: 228710
2009 WRX
Everyone should make a report to motor vehicle transportation so they force a recall. Fixing my firewall was very costly and its a manufacture defect no matter what subaru says about mods/abuse etc. The firewall is very thin and mad very poorly and they should pay for trying to take shortcuts.
cheech315 is offline   Reply With Quote
Old 02-05-2013, 07:31 PM   #68
eastwoodsn352
Member#: 334442
2008 WRX STI
How do we do this?
eastwoodsn352 is offline   Reply With Quote
Old 02-07-2013, 08:45 AM   #69
d_pieCe
Member#: 294584
2008 WRX STI 5dr
Lightning Red
Subaru has finally agreed to cover my firewall and it's at the body shop getting quoted. Once again, this was done under my extended warranty. Had a loaner for a week now, great gas mileage on the stock imprezza, not much fun to drive though!
Old 03-04-2013, 09:38 AM   #70
Armyofcase
Member#: 281396
2009 WRX Sedan
Here is the video of the weld broken on a 2009 Subaru WRX. I recently fixed this and had it rewelded; reinforced and welded; and also fixed the two points underneath the windshield wiper motor that were also broken. Overall, this is a huge PITA but got it fixed this weekend and everything is back to 100%
Armyofcase is offline   Reply With Quote
Old 03-04-2013, 09:39 AM   #71
Armyofcase
Member#: 281396
2009 WRX Sedan
So on a lighter side, we made this video....No packing peanuts were harmed in the shoot! lol
Old 03-14-2013, 09:15 AM   #72
SubieChick05
Member#: 191561
2014 WRX
This has been happening to me too so I guess I am going to have to call the dealership.. I do have an extended warranty too so I'm hoping that will help if I can't get it covered under Subaru. Anyone have issues with getting this covered because of any mods done to the car? I know sometimes dealerships can be dicks about stuff like that.. and so can extended warranty companies. I only have cat back exhaust and an intake right now which obviously has nothing to do with this concern.
SubieChick05 is offline   Reply With Quote
Old 03-15-2013, 07:33 AM   #73
Armyofcase
Member#: 281396
2009 WRX Sedan
It's a case by case basis. Some dealerships will fix the problem but make sure you point them specifically in this direction. Otherwise they will waste your time going into replacing parts.
Old 03-15-2013, 10:53 PM   #74
SubieChick05
Member#: 191561
2014 WRX
I made an appointment next week to get mine looked at.. Go figure it hasn't been making the noise now :-/
Old 03-20-2013, 04:01 PM   #75
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Finally emailed Subaru about this. Waiting to hear back from them.
ejicon is offline   Reply With Quote
going to vt. straight shot anything to worry about? polarisboy385 General Community 55 01-21-2011 04:22 PM
If you're not doing anything wrong, you don't have anything to worry about. Corn-Picker Political Playground 7 07-24-2008 12:08 AM
'98 RS heagasket anything to worry about? jamesfacts Normally Aspirated Powertrain 11 02-04-2004 06:28 PM
Getting 91 MR2 - anything to worry about? WRXVII Off-Topic 16 10-05-2003 01:50 AM
Anything to worry about...? XROLLER Brakes, Steering & Suspension 4 05-15-2002 12:04 PM
