Old 03-15-2013, 04:13 PM   #1
Miggs11c
Member#: 350147
2003 Impreza wrx
Platinum
Default 03 wrxnHigh beam won't turn on.
So my 03 wrx high beam and side marker lights on my passenger side won't turn on. I looked under the hood and found a white plug with green and black wires attached to it. On the drivers side I can't see where it's attached to. But it's a plug that has wires connected it to with the turn signal plug. I'm sorry if I'm using the wrong terms I just really need some help.
Miggs11c is offline   Reply With Quote
Old 03-15-2013, 04:27 PM   #2
Miggs11c
Member#: 350147
2003 Impreza wrx
Platinum
Old 03-15-2013, 04:27 PM   #3
Miggs11c
Member#: 350147
2003 Impreza wrx
Platinum
Old 03-15-2013, 04:28 PM   #4
Miggs11c
Member#: 350147
2003 Impreza wrx
Platinum
That's the wire... I need some help...
Old 03-15-2013, 04:43 PM   #5
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Are you sure that's a bulb socket for the sidemarkers (i.e. the orange trapezoid on the front fenders)? It looks more like the parking/city light that goes to the main headlight cluster. The socket itself is not visible unless you take the headlight out.
The high beams not working probably has nothing to do with that. Also check the fuse box inside, below the steering column, to the left where the coin tray is.
satrya is online now   Reply With Quote
Old 03-15-2013, 05:17 PM   #6
Miggs11c
Member#: 350147
2003 Impreza wrx
Platinum
Where's the fuse box? Can't seem to locate it.
Old 03-16-2013, 12:02 AM   #7
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The Main Fuse panel under the hood has a flat rectangular cover over it and should be about a foot away from the battery. There is a dash fuse panel also.
Cougar4 is online now   Reply With Quote
