Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 03-11-2013, 06:58 PM   #1
2fst4you
Member#: 315052
2006 Impreza Wrx
Default air bag light help
Who in my area can help me track down my airbag problem? Passenger air bag always says off and the airbag light on my dash is on.
Im located in white lake Michigan. I am hoping someone has fixed theirs or have a code reader and can help. Thanks
2fst4you is offline   Reply With Quote
Old 03-12-2013, 09:47 PM   #2
FLIPN SCOOBY
Member#: 177911
' 04 T WRX FF
'10 SCHOOL BUS
try disconnecting and reconnecting the connectors under the driver seat.
FLIPN SCOOBY is offline   Reply With Quote
Old 03-13-2013, 12:22 AM   #3
2fst4you
Member#: 315052
2006 Impreza Wrx
That would cause the passenger air bag to always be off?
Old 03-13-2013, 12:41 AM   #4
pezcore
Member#: 178045
06 WRX
Passenger airbag is off even when someone is sitting in the passenger seat?
Do you have the stock seats in there or did you switch them out for something else? (including other subaru seats)
pezcore is offline   Reply With Quote
Old 03-13-2013, 11:32 AM   #5
2fst4you
Member#: 315052
2006 Impreza Wrx
Correct. Stock seats
Old 03-13-2013, 11:15 PM   #6
pezcore
Member#: 178045
06 WRX
Answer first part of question... and check under your seats for unplugged harnesses.
Old 03-14-2013, 12:21 AM   #7
speedracerx9
Member#: 55493
2006 WRX
Also check seat belt buckle. it talks to the Airbag system and confirms that a rider is restrained. its a small switch that gets pressed in when you buckle. sometimes spilled drinks like coffee or pop gums it up. check the seat belt plug as well. also be careful with plugging and unplugging the yellow airbag plugs. there are capacitors in the airbag system cpu that store energy to set off the airbags even as the battery gets destroyed in an accident.
speedracerx9 is offline   Reply With Quote
Old 03-14-2013, 01:23 AM   #8
2fst4you
Member#: 315052
2006 Impreza Wrx
I did just hard to tell. Yes passenger air bag is off even with someone in the seat. I will check them
Old 03-16-2013, 11:38 AM   #9
2fst4you
Member#: 315052
2006 Impreza Wrx
Can anyone help?
Old 02-02-2015, 07:45 AM   #10
jkarcher
Member#: 412368
2011 Impreza
Default Have the Same Problem - Can't Find Connectors Under Seat
New to this site, recently bought a 2011 Impreza. I tried to find the connectors - very limited visibility under the seat, can't see anything yellow- and when feeling around under there can't find anything that appears to be disconnected.
Can someone please provide more detail about the connectors and how to locate them?
Thanks.
jkarcher is offline   Reply With Quote
Old 02-02-2015, 10:51 AM   #11
hoffmanEstates
Member#: 122043
04 wagonier
psm
Dealership
vroom-vroom-- pssshhh!
hoffmanEstates is offline   Reply With Quote
Old 02-02-2015, 05:34 PM   #12
jkarcher
Member#: 412368
2011 Impreza
Default I thought the purpose of the site was to help
Originally Posted by hoffmanEstates View Post
Dealership
This is a very flippant response to the first post of a new Subaru owner asking for help and is unable to afford a dealership.
Old 02-03-2015, 01:29 AM   #13
AWD Freak
Member#: 262593
Actually he might be on to something. Go to the dealer, speak to the parts guy. Tell him about your air bag issue and see what sensor in the seat needs replacing. Then ask him if he know where on the seat the connector might be. You might be better removing the seat bolts and pulling it out.
Sent from my iPhone using NASIOC
AWD Freak is online now   Reply With Quote
Old 02-03-2015, 07:39 PM   #14
jkarcher
Member#: 412368
2011 Impreza
Default Figured it Out Via Further Researching
I discovered that the light is supposed to be on all the time, and changes depending on whether someone is sitting in the passenger's seat.
