Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 03-13-2013, 04:24 PM   #126
jxlee
Member#: 309652
2013 WRX Sedan SWP
Originally Posted by DavinRL View Post
Is there an estimated release date yet for quad 4" tips for 11+ WRX? These were due before February I had thought
You guys are probably better off contacting them directly with your question seeing as how they haven't been on the forums for a while now. I emailed them about a month ago regarding the 4 inch tips and last I heard they said they needed to get their test car back in so they can start production....I'm sure the release date shouldn't be too far off at this point, but then again it seems like nameless has been pretty busy these days. I've been patiently waiting as well
jxlee is offline   Reply With Quote
Old 03-13-2013, 09:35 PM   #127
RexHunter
Member#: 349557
2013 WRX STi
For anyone that has the front plate delete, that requires the dealer-drilled plate mount holes correct? Just want to make sure I don't tell them to not drill them if the delete doesn't fit the square holes.
Also, since it's been a bit, anyone know if there's an update on the plate relocation kit?
Thanks.
RexHunter is offline   Reply With Quote
Old 03-13-2013, 09:45 PM   #128
swpshgnwgn
Member Sales Rating: (6)
Member#: 150494
11 WRX
SWP Torqued Stg II
Originally Posted by RexHunter View Post
For anyone that has the front plate delete, that requires the dealer-drilled plate mount holes correct? Just want to make sure I don't tell them to bot drill them if the delete doesn't fit the square holes.
It's been a while since I've put mine on but I'm pretty sure you don't need the dealer to drill for the front plate delete.
swpshgnwgn is offline   Reply With Quote
Old 03-13-2013, 11:27 PM   #129
lovemyscoob06
Member Sales Rating: (2)
Member#: 301748
2013 wrx
Scratch that!
Just talked to jason on the phone. Sounds like a cool guy
Anxious to come check out the shop once my axle back is done!
lovemyscoob06 is offline   Reply With Quote
Old 03-15-2013, 01:25 AM   #130
Capt_Hindsight
Member#: 350049
Default PB blaster needed?
To the people that have installed the Nameless Axleback; in your experience was PB blaster needed for those 4 bolts?
My car is a 2012 with about 6K miles on it - completely stock.
Thanks.
Capt_Hindsight is offline   Reply With Quote
Old 03-15-2013, 10:17 AM   #131
swpshgnwgn
Member#: 150494
11 WRX
SWP Torqued Stg II
Thanks.
No, you should be fine. I didn't use anything to loosen mine up.
Old 03-15-2013, 11:03 AM   #132
Capt_Hindsight
Member#: 350049
Old 03-16-2013, 11:49 AM   #133
Zer0cool42
Member#: 349457
2013 WRX HatchBack
Default What exhaust is best for me?
Im looking for the low deep sounding exhaust? also what are the benefits of cat back vs axle back? and doe that change the sound?
Zer0cool42 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 02:01 AM.
