Old 03-13-2013, 04:23 PM   #1
Sw20matt
Member#: 268770
2006 WRX TR
Default Flywheel Dowel pins, Where do I find them?
ok so I have a STi Pull type flywheel with a broken and a bent pin. I need to find a new set of the pins so that I can install a new clutch and get my motor back in. So far I have only seen threads (nasioc and google search) about people buying the pins but not where.
I have called Subaru and they told me they only come with a new flywheel. So I tryed the local machine shops and they cant get them either.
I have seen very mixed reviews on if you even need the pins or not but I would like to keep them.
If you have any I will buy them off of you or if you could please direct me to a place that dose sell them I would appreciate it.
Thanks in advance,
Matt
Sw20matt is offline   Reply With Quote
Old 03-14-2013, 05:49 PM   #2
Sw20matt
Member#: 268770
2006 WRX TR
bump anyone?
Old 03-16-2013, 03:49 PM   #3
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
Measure the diameter with a micrometer and go to Fastenal or a local good hardware store that sells ground straight pin stock, dowels pins. Cut to length and install. I would also recommend installing the new cut dowel pin with some Loctite 609 sleeve retaining compound. Read the instrustions on the bottle too. DO NOT USE KNOCK OFF SLEEVE RETAINER!!! Loctite all the way!!!
PSolbergfan is offline   Reply With Quote
Old 03-17-2013, 09:58 AM   #4
IBleedJDM
Member#: 349008
Fastenal will more than likely have what you need I replaced mine the same way and they had what I needed in stock
IBleedJDM is offline   Reply With Quote
Old 03-29-2013, 05:47 PM   #5
Sw20matt
Member#: 268770
2006 WRX TR
ok so after looking around and my clutch not fitting even after I removed the pins I noticed that the pins on this arent the same as the new flywheel I just bought. For some reason the new one has just a regular pin and the old one had a pin that had a wider bottom then the part that stuck out of the flywheel.
Old 03-30-2013, 08:24 AM   #6
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
I got mine from Competition Clutches...
Go to competitionclutches.com. give them a call and tell them what you need. they cost me like 1 or 2 bucks each...
rexworx is online now   Reply With Quote
