Old 05-20-2012, 06:18 PM   #501
Divinito13
Member#: 318102
2010 OBS
Not very savvy ..... But it's a start. Thanks....I'll refine my technique.....as u can see its white....but not bright enough
Divinito13 is offline   Reply With Quote
Old 05-21-2012, 01:58 PM   #502
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
[IMG] then [/IMG] at the end. LOL.
Anyway - how do they look, from the driver seat?
BWX is offline   Reply With Quote
Old 05-21-2012, 05:27 PM   #503
Divinito13
Member#: 318102
2010 OBS
Not that bright I think I will need some auxilliary lamps...but the good thing is that I don't usually drive at night! So I'll keep the HID look until I can get true HID.
Was thinking on Laminix for the fogs.....yellow? Not sure yet
Old 05-21-2012, 05:59 PM   #504
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Hey my lights were adjusted WAY LOW from factory. Adjusting them up a little was the biggest upgrade.
Don't go too high and blind people with your low beams though.
It's very easy to adjust lights with a flat wall and tape.
Hint- mark starting point on screw in car with sharpie marker in-case you go to far so you can start over and do it with full tank of gas.
Old 06-16-2012, 04:08 PM   #505
PlanB
Member#: 175608
2006 Impreza
1998 Honda VFR 800FI
Can someone tell me what the exact OEM specification headlight replacement bulb part number is for the 06 Impreza 2.5 Wagon? I'm in the store right now, don't have my car here and am borrowing my buddy's phone to post this up quickly hoping to get a reply before I leave the store we're at and go to the automotive store? Yes, I did a quick search but found way too much info to sort through while I'm at a store. Thanks.
PlanB is offline   Reply With Quote
Old 07-28-2012, 06:36 PM   #506
05sti914
Member#: 143512
Default yup
those work well
05sti914 is offline   Reply With Quote
Old 07-28-2012, 07:13 PM   #507
jege41
Member#: 280754
If you don't mind replacing a bulb as often as every six months then get the HIR's as they are very bright and white.
Originally Posted by microsnook View Post
Some helpful information.
I want 9011 HIRs now for my high beams!
jege41 is offline   Reply With Quote
Old 08-29-2012, 10:11 PM   #508
cmiovino
Member#: 134005
2004 WRX Premium
Just an FYI, according to Osram's website, the lumen output from the Osram Silverstars are 1550.
http://www.osram.com/osram_com/produ...star/index.jsp
Old 10-16-2012, 12:38 PM   #509
surfsuright
Member#: 321307
05 rex
I have an 05 wrx and in my Right Headlight, the orange circular bulb in the corner which i think is the (Front Side Marker Light Bulb Size: 168) comes on only sometimes when i turn my lights on. If it doesn't come on, i can hit the headlight and itll come on. Should I replace the bulb or is it a fuse and how could i correct this problem?
surfsuright is offline   Reply With Quote
Old 10-16-2012, 06:15 PM   #510
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
It's a loose connection somewhere, pull the bulb out of the lens & check to see if it is seated properly into the socket. If so, you can try cleaning the contacts, if that doesn't work you have to check the wiring.
prochucker is offline   Reply With Quote
Old 10-23-2012, 11:40 PM   #511
ans2k
Member#: 315631
2012 Impreza Sport
this is going to sound like a beating a dead horse. I have read the first post but not the rest of the 21 pages. I have been doing a litte research. I am trying to my my foglights into off-road rally lights + other hella lights. But mainly focusing on the fog lights since it would seem like a waste of lights if i dont try to make them useful. I know HID kits are terrible to use on the road, hence why I am just using them off-road. I have read that HID at the same wattage of a halogen with produce less heat than a halogen? the problem is that i have a plastic housing and lens for the fog light. are the damages caused by the HID in fog lights do to the decreased distance from the bulb to the lens? assuming i keep the same wattage (35).
Old 10-24-2012, 07:50 AM   #512
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
I'm not sure about producing LESS heat, I always thought they produced more. Also, it's not just for the street that they are horrible, it's why they are horrible for the street. A halogen bulbs bright spot is in a different place than an HID, the reflector needs to be designed with that in mind. HIDs in the halogen reflector do not put light out in a useable pattern, you will see less. Not really worth the money for an HID kit.
Old 10-24-2012, 04:28 PM   #513
Tack762
Member#: 261845
Silver EFI logics stg 2
I'm currently running Osram night breakers in my lows and Narva contrast bulbs in my fog. And I have stock bulbs in my highs.Looking to do the H9 mod to my low beams and HIR 9011's in my highs. I found these for my lows http://store.candlepower.com/h-9.html I know they are Narva but not sure how good they perform. Any other suggestions for a good H9? Since I'm also looking to make my fogs as my DRL's and suggestions for my fogs? Thanks in advance for any info.
Tack762 is offline   Reply With Quote
Old 10-25-2012, 12:00 AM   #514
ans2k
Member#: 315631
2012 Impreza Sport
I have always thought they produce more heat too. but from the information that i have gathered. it is produces less heat. that thanks for the input.
Old 11-12-2012, 10:59 PM   #515
stoker68
Member#: 208185
2009 WRX 5-door
Dark Gray Metallic
Did the H9 bulb upgrade this past weekend with Sylvania "standard performance" H9 bulb (only option at my local Advance Auto). Used the thin polishing wheel on my Dremel to carefully remove the plastic tab. They plugged in both left and right no issues.
I love this upgrade. I have been irritated with the lack of light coming from my headlights from day one. The light is "whiter" than the Silverstar ultras they replaced. It is so much "fuller." When i drive through parking lots, or at dusk, or when oncoming cars are coming - where traditionally, my headlights would disappear, I have full coverage. i am very, very pleased with this upgrade - thanks all for doing the trials to figure this all out.
I was initially worried about the increased wattage, but have not had a problem. The headlights are made for this much heat (high beams=65 watt) and the cabling is almost surely the same grade for low and high beams merely for simplicity on Subaru's end.
stoker68 is offline   Reply With Quote
Old 11-13-2012, 06:32 AM   #516
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Yeah the H9 mod is perfectly safe and reliable. I've had mine in for over a year with no problems whatsoever.
Old 12-06-2012, 10:23 PM   #517
Chillryde
Member#: 260912
2011 WRX 5-door
White Pearl
I just put in PIAA Xtreem White's that I did the H9 Mod. WOW! I ripped out my 6000K HID's and put in the PIAA's. Huge difference. I have 5000K HID bulb's on order. We will see if there is a differences.
Chillryde is offline   Reply With Quote
Old 02-19-2013, 03:12 PM   #518
Turnyface
Member#: 330036
2014 WRX Hatch
Turnyface is offline   Reply With Quote
Old 02-25-2013, 05:53 PM   #519
paperdukie
Member#: 214796
2004 OBS
Edit: iPhone mix up, wrong thread lol
paperdukie is offline   Reply With Quote
Old 03-15-2013, 02:06 AM   #520
Zaridar
Member#: 305812
why are some HIR 9011s bulbous like on that info website and all the Phillips ones are not and look like a regular bulb? are they not the real deal? Im about to shell out $50 on the Phillips one at AutoZone... don't want to be wasting my $
Zaridar is offline   Reply With Quote
Old 03-16-2013, 09:22 PM   #521
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
have ya read this yet?
http://hirheadlights.com/
flimflamman is offline   Reply With Quote
Old 03-26-2013, 07:39 PM   #522
BWX
Member#: 236305
2009 2.5i 4dr 5spd
Newport Blue Pearl
Well my OSRAM H9 modded bulb on the passenger side just died yesterday, I saw it blow out as soon as I started the car last night.
I looked back in this thread and I bought it on 10-01-2010.. So it lasted about 2 years, 5 months or so.. I think I put on about 10,000 miles, not sure exactly how much was night driving.
I went to Auto Zone and picked up an OSRAM H9 for $15. Great deal considering all the H11 Silverstars, etc were $20 up to 30$+ per bulb, and they're 55 watt, not 65 watt like the H9.
All the wires and connections were fine, nothing looked melted or discolored or anything. I think the H11 to H9 mod is perfectly safe. You just have to make sure your beams are aimed correctly so as not to blind oncoming drivers, that is always the case, but more so with these high powered low beams.
Old 04-19-2013, 08:22 AM   #523
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
I think I'm going to start shooting out yellow foglights with an air rifle. The IIHS even says they're just distracting and are actually worse in rain and fog than white lights.
goregasm is offline   Reply With Quote
Old 04-19-2013, 10:57 PM   #524
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
No no you wont but nice try...
R-
labcoat is offline   Reply With Quote
Old 05-07-2013, 05:14 PM   #525
Schlanseay
Member#: 340978
2013 13 WRX Hatch
I've been searching and can anyone point me in the direction on how to change the rear turn signal and back up light on a 13 hatch?
Schlanseay is offline   Reply With Quote
The 'Everything You Ever Wanted to Know About Smog' Thread WagonMonster Southern California Impreza Club Forum -- SCIC 667 06-27-2016 02:18 AM
Everything you ever wanted to know about anything ever made......ever Hester Prynne Off-Topic 12 11-05-2008 05:57 PM
All you've ever wanted to know about farting TheRex Off-Topic 5 02-01-2005 03:48 PM
Everything you ever wanted to know about WRX exhauasts (old model) --> rao Normally Aspirated Powertrain 5 02-12-2001 08:56 PM
