Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 01-22-2013, 02:53 PM   #451
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
I would absolutely LOVE to be able to have access to a full scale wind tunnel for testing. But on avg you spend a few thousand dollars an hour on a wind tunnel to rent, and that is just not feasible to be honest.
This image I found on line should give you a better visualization of what happens.
And on a automotive application...yes I know its a EVO, but this is a very good visualization of what is going on.
And the fact that air foils work based on air flow differences, the more flow you pass under the lower surface of a wing vs the upper surface on a car the more downforce it generates.
Would love to go into more detail about air foils, fluid dymanics, aerodynamics and so forth. It would get quite nerdy quickly and actually stray away from automotive application and require mathematics and physics background.
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 01-30-2013, 03:34 PM   #452
jlitchkowski
Member#: 288316
2011 STI
Just noticed, when it is installed is there a gap between it and the roof rails? Will you still be able to see the color of the car in that space?
jlitchkowski is offline   Reply With Quote
Old 01-30-2013, 04:06 PM   #453
RallySport Direct
Member#: 33174
We are Open Late!
They do not sit 100% even with the back, so there is a space to move it a little more left or right along with forward and back.
Kirill
Old 02-06-2013, 05:02 PM   #454
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
i flipped through this, and didnt see a mention of this. but what is with the rear training arms from cusco? why do the parts from the stock photo look so beefy and the parts on the car look so dinky?
this:
vs. this:
Old 02-06-2013, 05:46 PM   #455
RallySport Direct
Member#: 33174
We are Open Late!
The first image that you posted is for the GD unit, and that is the 2002-2007 WRX/STi trailing arm.
http://www.rallysportdirect.com/Cusc...7&src=vr7oueah
The 2008-2013 STi trailing arms are different.
http://www.rallysportdirect.com/Cusc...m&src=vr7oueah
Unless you are asking about the lateral links, in that case they are also different between the GD and GR chassis
http://www.rallysportdirect.com/Cusc...k&src=vr7oueah
Vs
(GD WRX and STi Lateral Links are different, and you buy the front and rear trailing arms separate for the rear suspension)
Hope this helps
Kirill
Old 02-06-2013, 05:49 PM   #456
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
The first image I posted was taken from earlier in this thread. You posted it.
Still, the new arms look rather weak IMO.
Also the GR does not have lateral links. They are lower control arms
Old 02-06-2013, 05:57 PM   #457
RallySport Direct
Member#: 33174
We are Open Late!
Let me know and I will be glad to fix the link/image, but I just looked through the entire thread and could not see it
"looks" can be deceiving. There are plenty stout for the job that they are designed to do. We have never seen or heard of a single failure of this component in all the years that it has been available
Some people are more familiar with the term lateral link, some prefer the name LCA. End of the day its a lower suspension arm that is the link between the subframes pick up point and the outer hub/knuckle. As the saying goes "Some say Tomato, some say Toma'to" end of the day it has the same function and that is to control the suspensions vertical movement and lateral load that is induced under cornering
Kirill
Old 02-06-2013, 06:22 PM   #458
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Originally Posted by RallySport Direct View Post
Here. Follow the linkback
Old 02-06-2013, 06:39 PM   #459
RallySport Direct
Member#: 33174
We are Open Late!
thank you for catching that
Got that fixed, much appreciated.
Kirill
Old 02-07-2013, 10:30 AM   #460
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
i guess i dont really understand the design. adjustability is fine, but this arm looks a good bit shorter than stock. id be worried about running out of threads on a lifted setup.
also the stock arm is clearly bent for clearance around the toe arm, with the cusco straight.
just disappointed with the design i guess :/. i do like the rear LCAs though. ive been keeping my eye out for a reasonably priced set.
Old 02-07-2013, 10:57 AM   #461
RallySport Direct
Member#: 33174
We are Open Late!
The base length of the arm is 377mm, with adjustment of +/- 12 mm. Below is a picture of the stock arm next to the Cusco arm in the shortest position.
Yes the stock arm is bent, but as you can see in the above image its also a stamped steel piece that gets its rigidity by being a box construction. This method of manufacturing cuts costs and increases production rate at the factory, however as you can tell also has a larger overall size as a result. The Cusco unit is able to get away with being straight due to its compact design which gains its strength from the wall thickness of the bar. Its been years from when I installed them on the shop STI, but I do recall that these Cusco units were heavier and "beefier" construction.
As you can see in the below image, there is plenty of clearance to the toe arm with the Cusco unit.
We have ran the STi at a drop height of -2.5" lower then stock with no issues, and currently have the Whiteline toe adjustable arms that are larger then the stock toe arms. With about 1" of clearance between the toe arm and the Cusco arm. And that clearance between the 2 arms will not change at ride height changes any significant amount.
Kirill
Old 02-19-2013, 02:50 PM   #462
RallySport Direct
Member#: 33174
We are Open Late!
Another pic of it staying nice and warm in our showroom. Only a few more weeks left until we bring it out. Stupid winter and salt
Kirill
Old 02-21-2013, 02:36 PM   #463
ubmbass
Member#: 326307
Hey, nice chair, I think I am going to take a seat and watch Rick on the TV!
ubmbass is offline   Reply With Quote
Old 03-16-2013, 06:44 PM   #464
RallySport Direct
Member#: 33174
We are Open Late!
We took the STi and the Rhino out for some laps around Miller Motorsports Park yesturday evening .
Good times! Both cars need set up, but gave us a chance to get a good idea where to start
(we will have some non cell phone pics up shortly)
Kirill
Old 03-16-2013, 10:05 PM   #465
RallySport Direct
Member#: 33174
We are Open Late!
We have also been busy with some other cars as well
Here is the lineup of our Current shop cars.
We dont hate here, and appreciate! All of these cars are a blast, and have their own unique personality and advantages
Old 03-16-2013, 10:53 PM   #466
Iownasubaru
Member#: 349243
2011 Wrx
Which one made the fastest lap time?
Iownasubaru is offline   Reply With Quote
Old 03-16-2013, 10:57 PM   #467
RallySport Direct
Member#: 33174
We are Open Late!
We did not not do any timing, and didnt go all out with the cars around the track. Its quite apparent work is needed to set them up to improve handling so there is no point in pushing it when you know the set up is not optimal.
Kirill
Old 03-16-2013, 11:39 PM   #468
firesword777
Member#: 237852
13 WRX
What's with picking up 3 new shop cars in the last what month though? Isn't that going to take time away from dialing each in?
firesword777 is offline   Reply With Quote
Old 03-17-2013, 12:05 AM   #469
RallySport Direct
Member#: 33174
We are Open Late!
We have project managers who are in charge of each build, so the progress of each build will not be hindered by the number of builds we are doing
We are super excited to be able to get some of these other platforms in and get the ball rolling on them to see what each one is capable off and better understand each one
Kirill
Old 03-18-2013, 08:02 PM   #470
RallySport Direct
Member#: 33174
We are Open Late!
Pic from Friday's track session
Old 03-18-2013, 08:49 PM   #471
Bigearl3
Member#: 350631
this thread is unreal, keep the posts coming
Bigearl3 is offline   Reply With Quote
Old 03-18-2013, 09:24 PM   #472
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
I love seeing that some research has actually been done here to substantiate the theory of VGs. I'm scratching my head a bit though (and this is just curiosity, not criticism), because in order for vortex generators to do what they're supposed to, shouldn't they be oriented at an angle to the relative airflow, as they are on airplane wings? If the vanes are mostly aligned with the airflow, where does the vortex come from? I would really like to see a car driven with a fully tufted rear windshield to see the airflow with and without VGs attached. The theory is sound, but I don't know if it's being applied correctly in most of these aftermarket parts.
Crazy_pilot is offline   Reply With Quote
Old 03-19-2013, 11:20 AM   #473
RallySport Direct
Member#: 33174
We are Open Late!
The vortex is formed as the air flow separates from the tip of the vertical triangular. As the air travels over each triangular piece it has to not only change direction, but also changes in magnitude. This causes the turbulence to occur at the very ends of the tips and causes the entire flow to turn turbulent as a result of molecular interaction of air molecules. Similar to what you see at the tip of the airplane wing, but in a much smaller scale (also wings are perpendicular and not vertical but the results are the same).
As for testing, you and me both! Problem is that to have a wind tunnel large enough to test something like accurately would cost more then the manufacture could ever re-couple from selling the product. So most of this testing is done in CFD due to cost.
With that being said, I know that Mitsubishi did a large amount of testing with this(EVO images were actually from MHI) to make improvements to the EVO IX over the EVO VIII in terms of aerodynamics and was implemented in the MR models as well.
Hope this helps a bit.
Kirill
Old 03-19-2013, 12:33 PM   #474
easterbran
Member#: 307359
'05 STi Stage II
This is some very cool applied aerodynamics!
easterbran is online now   Reply With Quote
Old 03-19-2013, 01:35 PM   #475
mkvaron
Member#: 326317
2011 WRX hatch
SSM
Clearly there is a thing for white cars here...
mkvaron is offline   Reply With Quote
AVO's 2011 STI Sedan is here! AVOturboworld Member's Car Gallery 192 01-29-2011 04:55 PM
2011 STI sedan on the 'Ring BlueLGT General Community 5 06-09-2010 10:57 AM
2011 STi Sedan at NY Auto Show Interior Flair Texas Impreza Club Forum -- TXIC 54 04-05-2010 07:31 PM
2011 STi sedan remotehuman New England Impreza Club Forum -- NESIC 55 04-04-2010 10:48 PM
