Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 10-24-2010, 12:33 PM   #1
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
Default tinywrex lc patch
this is what im having problems with. in the instuctions it says that if there are values other than "0" in these tables then to not use it. i have the a4sgd10c rom and thats the one i downloaded from chRom tinywrex. did i do something wrong?
josh
jrrevo1 is offline   Reply With Quote
Old 10-24-2010, 05:38 PM   #2
quazimoto
Member#: 70395
Yes,you did something wrong.
Old 10-24-2010, 11:29 PM   #3
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
i understand that because i know thats not what its supposed to be, how do i fix it?
Old 10-24-2010, 11:43 PM   #4
quazimoto
Member#: 70395
The obvious answer is to reread the instructions again and try it one more time.............
Old 10-25-2010, 01:19 AM   #5
jrrevo1
Member#: 242735
99 Dodge Ram 2500
WRX totaled 6/25/12
ive done tht and still the same result even with running the unpatching bat. plus re downloading it with the same result and the correct download for my rom...
Old 10-25-2010, 06:49 PM   #6
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
ok dude, i know why its coming up with numbers. When you use EcuFLash to open the rom...you have the find the rom you patched! You know how it says "make a copy of the rom and place it into the folder with the tinypatch.exe".
So now, you have to go to that specific "patch" folder where you placed your rom and open the rom from there.
I just patched my rom and the same thing happened and then i realized i was trying to open the "original" rom from my "roms folder"...since it has the same name, it will have the tinywrex patch but with weird numbers in it. you have to go to that new folder thats labeled by your ecu LCAXXXX....and using ecuflash, open that one.
hope you understand what i'm saying.
scoobystas is offline   Reply With Quote
Old 03-16-2013, 11:42 PM   #7
unkachabull
Member#: 241491
2005 wrx
v7 ej207- stimikey tuned
did anyone else have this problem? i am trying to do it and am experiencing the same exact issue. iv also tried what scoobystas explained and still same issue.
unkachabull is offline   Reply With Quote
Old 03-16-2013, 11:48 PM   #8
the suicidal eggroll
Member#: 51961
2005 STi
Simple answer:
Download a stock tune. This means a completely OEM tune from somewhere like here:
http://www.scoobypedia.co.uk/index.p...patibilityList
Do not alter this tune in any way, just download the OEM tune and leave it alone.
Now, follow the tinywrex instructions to patch this vanilla, unaltered, OEM ROM.
Once it's been patched, open it up in ECUFlash to make sure everything looks good.
Once you verify that the ROM is in good shape and has been patched well, then open up your current tuned ROM and copy over the necessary tables.
I have patched many ROMs with varying degrees of success. Whenever things fail, going back to a vanilla OEM ROM, patching that, and then copying the tuned tables over has ALWAYS fixed the problem.
It may seem like a hassle, but honestly it only takes 10 minutes or so to copy over all of the tuned tables. It takes much less time to copy over the necessary tables than trying to debug why your tuned ROM won't accept the patch.
Old 03-21-2013, 01:31 PM   #9
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^This guy knows his ****!!!!!!!!!
Listen
Old 03-21-2013, 01:36 PM   #10
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
lots of little things that can go wrong man. Are you getting any kind of an error when you patch your rom?
medamullet is offline   Reply With Quote
launch control removal for 02-03...FIGURED IT OUT..But need a good tiny LC patch 2ez4me Open Source Reflashes 4 06-05-2010 08:25 PM
LC patch for AP map Cards2323 Tri-State Area Forum 1 04-26-2010 07:28 PM
Tinywrex ecu Launch and FFS control subiesoho Transmission (AT/MT) & Driveline 0 02-01-2009 03:07 AM
Help with the LC patch Mr.Krinkle Open Source Reflashes 6 01-17-2009 06:06 PM
Patched my map with tinywrex Launch Control. 4 extra options?? RSXiMUS Open Source Reflashes 10 12-12-2008 05:23 PM
