Old 03-13-2013, 11:04 PM   #101
vwgti123
Member#: 335945
2013 Sport Limited
Originally Posted by Guzzi 1 View Post
Mine does what it is supposed to do. I have said it over and over. It also fits all the requirements to be in this thread.
Believe me, it is my money. If I was pi$$ed about fuel economy, I would not be afraid to say so!
John
I know you would. Your a good guy and I am glad you are happy with your MPG's. Mine does not do what it is supposed to, wish it did, oh man I wish it did.
vwgti123 is offline   Reply With Quote
Old 03-14-2013, 12:50 AM   #102
lymphomaniac
Member#: 334451
2013 Impreza2.0i CVT
DGM (sedan)
Originally Posted by stevehnm View Post
Yeah but when the gas pedal is down it shifts back to auto in 1 or 2 seconds on mine. Does yours not do that?
I can't remember which thread it was, but someone mentioned something about first using the downshift paddle, and then upshifting. This should keep it in the higher gear for ~1-2 minutes or something like that.
Let's see if I can locate that post...
EDIT: I can't sem to find it. However, you'll just have to take my word (or, even better yet, try it for yourself). I've done it before where (just using the paddles in "D" mode) I downshifted, then upshifted, and the CVT kept it "in gear" for about a minute or two before popping back into "D" mode.
I'm not sure if that'll hold for the commute up (and down) La Bajada that you do, but it's probably worth a try.
lymphomaniac is offline   Reply With Quote
Old 03-14-2013, 06:17 AM   #103
Caocao
Member#: 330507
2015 Jetta TDI
Pure White
Non pzev and happy with mpg
Caocao is offline   Reply With Quote
Old 03-14-2013, 06:34 AM   #104
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
It would be vice if they could change the start/warm-up sequence for the pzev cars, because I really don't like it, especially since I live in a non pzev state
Old 03-14-2013, 07:48 AM   #105
stevehnm
Member#: 329526
2013 Impreza Spt cvt
I tried that - t doesn't work with mine.
stevehnm is offline   Reply With Quote
Old 03-14-2013, 10:00 AM   #106
lymphomaniac
Member#: 334451
DGM (sedan)
Bummer. Oh well.
Old 03-14-2013, 11:48 AM   #107
John451
Member#: 321966
2012 Impreza + XV 14
Black Pearl + White XV
Mine to though I'd like to know if it can be tuned for 15 > 20 seconds.
John451 is offline   Reply With Quote
Old 03-14-2013, 04:47 PM   #108
stevehnm
Member#: 329526
Well I think it pretty much stays in manual while compression braking - I've never had it go back the "D" then. If it was tied to positive torque as well as negative torque that would work I think.
Old 03-14-2013, 07:49 PM   #109
webster354
Member#: 343343
2014 Impreza 5dr Ltd
7-20 Starting and operating
For models with manual mode, if one of
the shift paddles behind the steering
wheel is operated while driving in the “D”
position, the transmission will temporarily
switch to the manual mode.
In this mode,
you can shift into any gear position using
the shift paddles. For details about the
manual mode, refer to “Selection of
manual mode” F7-20. Once the vehicle
speed stabilizes, the transmission will
switch from the manual mode back to
the “D” position for normal driving.
webster354 is offline   Reply With Quote
Old 03-15-2013, 01:07 AM   #110
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
On longer trips in hilly terrain I like to switch to manual mode and use cruise. I can stick it in 6th and there's enough grunt to lug me up the rolling hills around here. Then the mpg gauge doesn't go nearly as far left as when in automatic mode.
hemophilic is offline   Reply With Quote
Old 03-15-2013, 10:04 AM   #111
John451
Member#: 321966
Actually this is the first 4 Cylinder automatic car I don't bother switching into Manual mode. Found the CVT does a very good job up steep mountain switchbacks though sometimes go into manual mode down them for more control.
Old 03-15-2013, 08:05 PM   #112
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Ok so I filled up today and here are the results......
417 miles
13.935 gallons
29.9 MPG
Avg MPH was 46
about 1/3 of those miles were on I-95 at about 80 mph....obviously there's slower highway and some city mixed in there as well.
jsteg is offline   Reply With Quote
Old 03-15-2013, 08:38 PM   #113
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
28mpg for me. 85% city. 27 mph avg.
Old 03-15-2013, 11:55 PM   #114
vwgti123
Member#: 335945
2013 Sport Limited
Just Sharing... 2013 CVT PZEV filled up tonight.. 364 miles - 13.265 = 27.44 This was 85% / 15% Hghy/city. Always reset AVG trip display which showed 30.03 when I pulled in to get gas. Can honestly say car never went above 3500 rpm. You guys are okay with this? I am not. Best part is as usual after refilling drove about 16miles home and bye the time I pulled into garage the AVG MPG shows 38+, but by my next refill, will prob be at an abismal 27 again. And I have to stae my driving habbits are very consistent. That is why firstly I dont bother with the AVG MPG display, and secondly why I am sooo pissed!!! Oh man
Old 03-16-2013, 01:11 AM   #115
nubsub
Member#: 313575
2012 Impreza 2.0i HB
this, i would say is about roughly what i see although slightly less on the average MPH.
nubsub is offline   Reply With Quote
Old 03-16-2013, 01:11 AM   #116
nubsub
Member#: 313575
deleted...reread original post.
duh...
Old 03-16-2013, 06:40 AM   #117
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
How much of your commute is spent idling, and how many times do you need to accelerate? What is the car reporting as average speed?
Old 03-16-2013, 02:55 PM   #118
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
I have 13 stop lights/signs on my 7 mile commute. About 1/3 35mph and 2/3 45mph roads and normally go about 5 over.
Old 03-16-2013, 05:04 PM   #119
jsteg
Member#: 329271
Ice Silver Metallic
I would say that's a recipe for low MPG's
Old 03-16-2013, 05:13 PM   #120
vwgti123
Member#: 335945
2013 Sport Limited
Not Much idling at all, AVG speed I think is somwhere like 41 or 40, rarely look at that part of the display.. and have a few stop signs to get to highway... than sometimes a mile or so in stop go traffic.. then a few stop signs again and 2 or 3 traffic lights total.. That is how I come up with about 85% highway.. out of the 20 miles on cummute maybe 3 or 4 are not highway...
Old 03-16-2013, 09:13 PM   #121
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
Not really. Last tank was 28mpg on the nose with 85% coming from that commute.
For the record, I rarely get it above 2500rpm.
Old 03-16-2013, 11:00 PM   #122
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
next time you fill up, let us know your avg mph, I'm curious
Old 03-16-2013, 11:38 PM   #123
stevehnm
Member#: 329526
In this mode,
Definitely not how mine works. I went down two fairly large hills, one steep enough to hold speed in 5th with no gas or brake pedal use, and one of over a mile with variable grades and steep enough to maintain a constant speed. In both cases, even when the "speed stabilized" it stayed in 5th while compression braking. It is not until I give it some gas or the engine speed slows to basically idle in the gear, which is the same thing, that it goes back to drive. When depressing the gas pedal, it will go back to drive under any conditions after only a couple of seconds (even when downshifting and then upshifting).
Is that not how everyone's works?
Old 03-16-2013, 11:49 PM   #124
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
Just got 39mpg on a 48 mile round trip. Speed limit ftw.
Old 03-17-2013, 03:28 AM   #125
lymphomaniac
Member#: 334451
DGM (sedan)
Hmmm... I'm almost certain that that's not how mine works. If I'm in D mode, and then I do a down-up in quick succession (ie. upshift within 5 seconds of downshifting), it'll hold it in that "gear" until about a half minute later, regardless of whether I step on the gas or not. The only time I've come across where it auto-resets to D in less than about half a minute of "shifting" is when I reach a full stop.
Not sure if that answers your question...?
