Old 03-12-2013, 02:30 PM   #51
Zaridar
Member#: 305812
Originally Posted by Cougar4 View Post
As far as the alternator action I previously described, yes. A new fully charged battery should be around 12.6 volts with no load on it. Make sure your fan belt isn't slipping, that will cause the alternator output to be less than it should be.
yeah good call I didn't think the belt was possibly slipping but it was... voltage is now 13.9 all accessories on at idle warmed up.. 13.2 is the lowest drop when fan kicks on
Zaridar is offline   Reply With Quote
Old 03-12-2013, 02:31 PM   #52
Zaridar
Member#: 305812
thanks to everyone for your help!!! I still have to try to figure out why the clock flickers with parking lights on
Old 03-14-2013, 12:20 AM   #53
Zaridar
Member#: 305812
So does anyone have any ideas on this clock issue... it only does it with headlights off and parking light switch on top of the column on... car running or not running..... could it be this loose piece in clock? its perfect all other times
Old 03-14-2013, 11:31 AM   #54
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The only thing I can think of that might cause that trouble may be due to problem with the power input to the clock. Check the voltage on the power an ground leads on the clock and see if it drops down a significant amount when the parking lights are turned on.
Cougar4 is offline   Reply With Quote
Old 03-16-2013, 02:02 PM   #55
Zaridar
Member#: 305812
Ok thanks ill try that! Not sure when I'll have time. It's still so cold out here damnit.. No motivation to work outside w out garage..
Old 03-16-2013, 02:08 PM   #56
Zaridar
Member#: 305812
Do you think it could have anything to do with factory security system being unplugged under the console.. I've tried hooking it back up but alarm goes off and I can't figure out how to get alarm to stop...
Old 03-16-2013, 04:26 PM   #57
Cougar4
Member#: 53443
Winestone
The alarm system most likely needs to be reprogrammed if hitting the key fob doesn't clear the alarm. I don't see how the alarm system could effect the the clock in any way.
Old 03-17-2013, 11:50 AM   #58
Zaridar
Member#: 305812
Ok thanks
