Old 01-25-2013, 02:19 PM   #576
sdocsubi
Member#: 327436
even tho this is 5 years old definitly still cleared some things up for me, thanks for the write up
sdocsubi is offline   Reply With Quote
Old 01-29-2013, 05:51 AM   #577
motorbreath16
Member#: 340385
07 STI
CMG
yeah thanks for this info. ive been looking for something like this to confirm my thoughts about where my boost leak is coming from. definitely going to check my bov
motorbreath16 is offline   Reply With Quote
Old 01-31-2013, 08:31 AM   #578
berto123wrx
Member#: 345510
2008 Impreza WRX
WRB (World Rally Blue)
Question Idk
Ive always been looking for just an aftermarket Bov or 50/50 but never knew if it was worth it just to have for minor upgrade in preformance if it really even matters. for the longest time ive been looking at synapse syncronic recirc. valves but have heard mixed things. Im currently stage two about to put headers and up pipe on and thinking about a TD05 turbo down the road so idk if a BOV is worth it?
berto123wrx is offline   Reply With Quote
Old 02-01-2013, 07:08 PM   #579
philvia
Member#: 335967
If I were you I would just stick with the stock bpv, you can always crush the top of it down to make it hold a few more psi. That's what the 1g dsm guys used to do.
philvia is offline   Reply With Quote
Old 02-01-2013, 07:23 PM   #580
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
you can't crush the 08+ plastic bpv's
edit: can't is a strong word...let me rephrase...the average person can't easily crush the 08+ plastic bpv
amalgrover is offline   Reply With Quote
Old 02-20-2013, 05:10 PM   #581
robert872
Member#: 320388
Great Help :ddd
robert872 is offline   Reply With Quote
Old 02-26-2013, 02:03 AM   #582
08_sti
Member#: 347911
Chapter/Region: HIIC
08 subaru wrx sti
aspen white
Say no to bov's.....
08_sti is offline   Reply With Quote
Old 02-26-2013, 02:45 PM   #583
amalgrover
Member#: 183480
2009 Forester XT
08_sti, you are well on your way to making the biggest newbie mistake of not reading. By what you posted, we all can tell that you didn't read a single thing in the original post.
Old 02-26-2013, 03:47 PM   #584
rosedaleny806
Member#: 202070
2012 WRX GR LSB/Gold
2002 WRX GDB PSM
just installed my GFB on my 12' WRX at 70% Recirc. it runs perfect.
rosedaleny806 is offline   Reply With Quote
Old 02-26-2013, 04:00 PM   #585
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
I disconnected my stock BPV from the recirc hose last weekend, plugged the hose with a 1" PVC plug (used in plumbing) and then went for a drive to hear the rice.
Upon starting, the car runs like crap, fluctuating idle and sometimes stalling if I let the RPM drop too far. I couldn't even let the car idle unassisted.
Now, why is it that I can go from a perfectly running car, to this, by simply disconnecting the recirc hose? I would understand it running poorly after a few vents to atmosphere, but immediately after starting? I don't even think the ECU can 'learn' that quickly.
Other than the idling problem, it popped a few flames and would be extemely shaky starting out in 1st and shifting into 2nd. It is not shaky for the most part with the BPV connected.
Reconnected the BPV and car instantly runs 100% better.
brett192 is offline   Reply With Quote
Old 02-26-2013, 06:11 PM   #586
Hasty180
Member#: 345751
2011 Subaru WRX
Obsidian Negroid
Question:
If you go aftermarket BOV (ex. TSI RFL BOV) on a 2011 WRX Limited IN ADDITION TO a cat-back exhaust....Would there be any requirement for a re-tune. im pretty sure not, but theres far more familiar folks here than I. LEMME KNOW-
Hasty180 is offline   Reply With Quote
Old 02-26-2013, 06:14 PM   #587
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Originally Posted by Hasty180 View Post
Question:
You do not need a tune for the catback.
You cannot tune to compensate for a BOV venting to atmostphere.
If you are talking about a full recirculating BOV, it will work the same as your stock BPV, no tune required.
Old 02-27-2013, 12:47 PM   #588
Trnapartpap3r
Member#: 348365
2003 WRX Impreza
WRB - "Dafini3"
Talking Newbie first post
As a newbie to the scoobie, I appreciate the time and effort put into the the original post, it helped me out a lot. Seems like it comes down to preference of liking the sound and taking the risk with leaks, as with any mod your going to have your pros and cons, this one being a fairly minor one. With that being said I made my choice and went ahead and got one, went with the turbo smart Subaru specific application.
Trnapartpap3r is offline   Reply With Quote
Old 02-27-2013, 06:31 PM   #589
Hasty180
Member#: 345751
2011 Subaru WRX
Obsidian Negroid
Ladies/Gents, thx you very much!
Old 03-05-2013, 06:45 AM   #590
Rescuer
Member#: 176692
this thread might be of interest
http://forums.nasioc.com/forums/showthread.php?t=454965
Rescuer is offline   Reply With Quote
Old 03-05-2013, 07:44 PM   #591
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
The stock bpv isn't entirely closed at idle, so air is being pulled in through the uncapped BPV and bypassing the MAF, which will throw everything else off.
ResidentR is offline   Reply With Quote
Old 03-06-2013, 01:43 AM   #592
mccadney
Member#: 343374
2009 WRX
World Rally Blue
disregard this
mccadney is offline   Reply With Quote
Old 03-14-2013, 04:07 AM   #593
Wrxtacy5150
Member#: 350151
2006 STi
Good write up, too many BOV threads that are too bias.
Wrxtacy5150 is offline   Reply With Quote
Old 03-17-2013, 12:13 PM   #594
20satinwhitebeast13
Member#: 350464
2013 wrx
satin wite
Default bov could cause my over boost
Hey fellas need some info first time wrx buyer and having alot of problems so far.
Car currently has
cobb bov
spt exhaust
invidia down pipe (catted with bracket to conform exhaust)
cobb intake and box
turbo heat shield
and cobb ap running acn91 stage 2 sf (super low waste gate)
im change map after map and im still overboosting i do the live data log and i overboost in 4th gear and 19.1 pounds and stay overboosting in 5th gear around 18.5 to 19.5 the whole time
i have all the parts that the guys have recommended and i know of people who have the exact same parts and running the ap map and not even close to overboosting the only difference is my bov (to my knowledge its installed correctly )
is it possible
20satinwhitebeast13 is offline   Reply With Quote
Old 03-28-2013, 01:57 AM   #595
dtl45
Member#: 331085
So while buying a Nameless Performance midpipe for my '11 WRX, the Synapse DV caught my attention, so I splurged and got that too. Any tips on push vs. pull mode? What will sound better and give me the greatest performance gains? I've done some research and watched some videos, but I wanna hear what the NASIOC folks gotta say.
dtl45 is offline   Reply With Quote
Old 03-28-2013, 12:03 PM   #596
patrickrobare
Member#: 324177
2012 impreza WRX
pearl blue
as far as "tuning" for a bov, would running speed density help reduce the negative effects?
patrickrobare is offline   Reply With Quote
Old 03-28-2013, 08:12 PM   #597
amalgrover
Member#: 183480
2009 Forester XT
Speed density completely removes the issues altogether because you are no longer using your maf sensor to calculate fueling.
Old 03-28-2013, 11:25 PM   #598
TURBObro10
Member#: 343901
2006 WRX STI
Awesome write up, have wondered about this since I got my Subie. Thanks alot.
TURBObro10 is offline   Reply With Quote
Old 03-31-2013, 09:37 PM   #599
patrickrobare
Member#: 324177
2012 impreza WRX
pearl blue
Would their be any negative effects to this? i wanted to try it because i have the option using the accessport race tuner but i didnt know if it required adjusting or if the maps were automatically calibrated.
Old 04-01-2013, 02:44 PM   #600
amalgrover
Member#: 183480
2009 Forester XT
no negative effects from going speed density, but your maps on the accessport are just base maps. To be accurate, you would want them adjusted.
General Subie Newbie FAQ. Lets answer a few common questions and dispell some myths. Defiant Autospeed Newbies & FAQs 59 08-18-2015 03:36 PM
2.0L or 2.5L what are the ups and downs thewannab2002 Newbies & FAQs 28 05-27-2010 12:18 AM
The ups and downs of life MGXsport Off-Topic 14 09-10-2007 10:03 PM
S-AFC ups and downs y2k02scoob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-16-2003 05:21 PM
What are the ups and downs of a dog box- any brand? GT2WRX Transmission (AT/MT) & Driveline 23 08-06-2002 08:30 PM
