Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 03-09-2013, 10:11 PM   #226
cknowlen
Member#: 189077
02 WRX + 07 ZX6R
Originally Posted by Sshantz View Post
Anyone??
your hid kit should have come with multiple connectors. and most hid kits use the factory wiring to the ballast then two wires to the hid bulb itself.
if you are confused or can send pics of any problems just pm me
cknowlen is offline   Reply With Quote
Old 03-09-2013, 10:13 PM   #227
cknowlen
Member#: 189077
02 WRX + 07 ZX6R
i bought the regular halogen versions because they are the exact same as the hid versions. however i am running a hid kit on mine. its super easy, make sure the bulb fits. and yes def make sure you are running factory wiring to the ballasts then ballast wiring to the bulbs themselves.
Old 03-10-2013, 12:57 AM   #228
robn
Member#: 178450
2003 WRX Bugeye
Where did you get the HID kit from?
Is it cheaper to go this route rather than getting the HID Depot version?
robn is offline   Reply With Quote
Old 03-10-2013, 11:14 AM   #229
Sshantz
Member#: 323347
Cknowlen, the problem I'm having is I purchased an h1 hid kit for the headlights but the hid kit has a 9006 plug while the factory harness has a 9007 plug...hence the issue. I'm also interested in seeing what hid kit you got and how it wired up. I'll post a picture of my hid kit with wiring when I get home from work.
Sshantz is offline   Reply With Quote
Old 03-10-2013, 12:52 PM   #230
cknowlen
Member#: 189077
02 WRX + 07 ZX6R
I purchased my hid kit a long time ago from a local vendor, and have since then just replaced bulbs as necessary. Usually from eBay. I can take a picture of how mine is wired up today, but keep in mind that I am not using a factory connector. I spliced into the lighting wires for wiring my ballasts and high beams seperately.
Old 03-10-2013, 12:55 PM   #231
cknowlen
Member#: 189077
02 WRX + 07 ZX6R
And yes it was cheaper for me to go this route since I already essentially had an hid kit. All I needed was to buy the right size bulbs and I was all set.
Old 03-15-2013, 01:29 AM   #232
robn
Member#: 178450
2003 WRX Bugeye
Should I get the Depot HID replicas or a set of JDM chrome HIDs?
I like the idea of having OEM lights but they would be RHD and also ten years old.
The price isn't the issue it's the age and RHD...
Old 03-15-2013, 10:07 AM   #233
WRX_02_227
Member#: 12434
2002 WRX, 2015 WRX
2011 BMW 135i
Just ordered my set of Depos!
WRX_02_227 is offline   Reply With Quote
Old 03-15-2013, 12:38 PM   #234
satrya
Member#: 5887
2002 GDAA
797
The RHD projector in the JDMs will need to be modified.
Either buy a LHD shield or get a good oem projector (e.g. from RX330, RX350, TSX, S2000) to retrofit.
You may also need to polish the outside lens of the headlight, as they may haze with age.
satrya is offline   Reply With Quote
Old 03-17-2013, 01:55 AM   #235
robn
Member#: 178450
2003 WRX Bugeye
Yeah-all that extra work & $ to fix up already pricey JDM's doesn't seem worth it.
Depots it is!
Old 03-17-2013, 02:08 AM   #236
fidrat
Member#: 138414
WR blue
ummm...what happened? I can't seem to find them anymore.
fidrat is offline   Reply With Quote
Old 03-17-2013, 02:22 AM   #237
amazonparrot
Member#: 57070
2003 Impreza WRX
Hybrid 2.5 / Aspen White
I can't either...I really hope its a fluke...
amazonparrot is offline   Reply With Quote
Old 03-17-2013, 02:46 AM   #238
WRX_02_227
Member#: 12434
2002 WRX, 2015 WRX
2011 BMW 135i
I'm sure they will put more of them up.
Old 03-17-2013, 09:34 AM   #239
Gamble_WRX
Member#: 234783
2004 STi
So i was acctually very impressed that depo started making aftermarket JDMs.
DEPO is NOT an Ebay brand, as some of you have refferred earlier in the thread.
DEPO has been making lights for a long time. If your car has been in an accident, the body shop will ask you, "do you want OEM or aftermarket?" fact is, OEM is perfect fitment every time, Aftermarket, is cheaper, but may require a bit of work to fit right. a sacrifice you make with EVERY Aftermarket part.
fact of the matter is, if you say you want aftermarket parts on your wrecked car, and you have smashed headlights, your getting DEPO. because they are widely reguarded in the autobody world to be the best aftermarket headlights. 9/10 times the bolt right in, and from 10 feet, you wont be able to tell the difference. i had to replace one headlight on a 10 WRX a while back, the DEPO, looked just like the factory one, and after aiming, you couldnt tell it was an aftermarket light.
At some point in my build, im sure ill be buying these.
Gamble_WRX is offline   Reply With Quote
Old 03-17-2013, 12:13 PM   #240
fidrat
Member#: 138414
WR blue
Me too. Sometime this summer. where? A link would be nice. Looking....looking....Still not finding....starting to panic here! I don't wanna' be stuck with my crappy Spec-D's All I can find says, "This listing was ended by the seller because the item is no longer available." Noooooooo!!!
Old 03-17-2013, 07:02 PM   #241
WRX_02_227
Member#: 12434
2002 WRX, 2015 WRX
2011 BMW 135i
PDF on Depos website: http://www.depo.com.tw/asp/pdf/R_SB_IMPREZA.PDF
Depo part number for these lights: 220-1106-RD-E2
Old 03-17-2013, 09:16 PM   #242
fidrat
Member#: 138414
WR blue
Great! Now all we need is a way to actually order them.
Old 03-17-2013, 10:10 PM   #243
tomofo
Member#: 230978
2002 VF43 Stg III
Yes, I've been following this post and they are no where to be found on eBay. I would bet that they just sold all they had and are waiting for more. Glad I ordered mine very early on.
tomofo is offline   Reply With Quote
Old 03-17-2013, 10:20 PM   #244
tomofo
Member#: 230978
2002 VF43 Stg III
I guess you could look up neondials (seller) on eBay and shoot them an email to inquire about the headlights and if they will be available again.
Old 03-18-2013, 12:22 AM   #245
WRX_02_227
Member#: 12434
2002 WRX, 2015 WRX
2011 BMW 135i
Here is what I am thinking. Technically these lights aren't really replicas, they are replacement parts for OEM at a cheaper cost for insurance companies. I think they are NOT USDM lights but either Euro or JDM. Maybe the seller on eBay has been importing them similar to what people do with factory JDM parts.
Maybe try going to a collision center and inquire about Depo replacements and if they can get them.
I just found this: http://jdmautolights.com/subaru-head...217641c71b6d99 but there isn't pictures for all the items.
Old 03-21-2013, 12:35 AM   #246
subiedante
Member#: 287588
so glad i ordered mine earlier, i had a feeling they might sell out
subiedante is offline   Reply With Quote
Old 03-21-2013, 03:36 AM   #247
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
So glad I got my "eagle eye" USDM replicas, retrofitted them with clear-lens E55 bi xenon projectors, run 50 watt ballasts and get far more output and(gasp!) proper beam pattern for pennies by comparison.
Old 03-21-2013, 05:48 AM   #248
fidrat
Member#: 138414
WR blue
What the heck does that have to do with what we were talking about?
Old 03-21-2013, 09:40 AM   #249
WRX_02_227
Member#: 12434
2002 WRX, 2015 WRX
2011 BMW 135i
And this info is relevant how?
Old 03-21-2013, 02:10 PM   #250
amazonparrot
Member#: 57070
2003 Impreza WRX
Couldn't pass up the op to gloat, haha
