Old 03-18-2013, 12:36 AM   #151
p951951951t
Member#: 276541
2008 STi
Snow
Great thread and great work. +1 on JPM being great guys. Hard workers and great CS. I'm local to them, so I decided to drop by and pick up my shifter boot in person. I was impressed with their passion for the work and their attitudes.
p951951951t is offline   Reply With Quote
Old 03-18-2013, 08:33 AM   #152
Overland04
Member#: 293311
2011 WRX Limited
Colorless?
I was able to find these from the install, they are a little bit closer. I didn't roll the edge, just cut it with a sharp razor. It's still holding strong which is why you NEED to use real contact cement for Alcantara.
The reason the edge stays so clean is because Alcantara doesn't fray along the edges and good adhesion from proper gluing techniques.
Cheers!
- Jason
Overland04 is offline   Reply With Quote
Old 03-21-2013, 03:07 PM   #153
Tyrial
Member#: 284392
2011 STI Limited
Blue Pearl
This made me want to order up similar colors for my '11 STI. Thanks for the inspiration, probably attempt this over spring break~
Tyrial is offline   Reply With Quote
Old 03-26-2013, 04:52 PM   #154
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Oh great another project this spring.. Haha
WRX-ERROR is offline   Reply With Quote
Old 04-17-2013, 01:41 PM   #155
ProJecTxPreLuDe
Member#: 268119
2002 WRX Wagon
Great Job! Can you point me in the direction of a good place to get alacantra by the yard ? I'm Doing my door cards and a couple other thing this summer. Please and Thank you.
ProJecTxPreLuDe is offline   Reply With Quote
Old 04-17-2013, 01:52 PM   #156
Overland04
Member#: 293311
2011 WRX Limited
Colorless?
Thanks man,
I would get the Alcantara directly from JPM Coachworks. You can also get it from Gulf Fabrics but I believe they are the ones supplying it to JPM so your getting the same material.
They'll charge you the same price so I vote for supporting JPM instead of the bigger guys. Plus having Alex's support at JPM is worth it's weight in gold.
Cheers!
- Jason
Old 04-19-2013, 05:42 PM   #157
JPM Coachworks
Member#: 190108
2008 WRX STI
LR
Thank you for your kind words, Jason. As for the Alcantara material, Gulf Fabrics is the only official importer of the material for the United States. Even Recaro NA in Michigan purchases from Gulf
Best Regards,
Alex
JPM Coachworks is offline   Reply With Quote
Old 04-20-2013, 02:36 PM   #158
zenizlev
Member#: 347700
2011 STi
Just what I needed to see. This is now on my to-do list.
zenizlev is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 06:41 AM.
