Old 12-28-2012, 12:28 AM   #201
ZURCALED12
Member#: 309754
2012 Impreza Sport L
Ice Silver Metallic
yes, I am sorry about the repetitive posting on your thread JDMSTA. I will start another thread under the Impreza forums for the SMD halo questions and install if I go that route. I am leaning towards the SMD's around the round part of the headlight, instead of around the projector itself, more like the E55 BMW, or some E46 have them installed the same way. Thank you for your help and input advise, well appreciated.
ZURCALED12 is offline   Reply With Quote
Old 12-28-2012, 04:27 PM   #202
JDMSTA
Member#: 310615
1213 12'Sport+13'STi
No worries bro! I started the thread but it doesn't mean I own it. LOL! More questions are welcome, just hope people including myselp can help thats all.
JDMSTA is offline   Reply With Quote
Old 01-11-2013, 04:43 PM   #203
tenaciousZ
Member#: 342279
2012 Impreza
Originally Posted by JDMSTA View Post
I just used some cheap 9006 LED bulbs from ebay and use it as DRLs. I didn't even care if its bright since I'm only using it as DRLs and the projector's high beam is brighter than stock halogens anyways.
As for the color I used? I used the "flat black" color for my housing.
u mentioned that u used the highbeam splitter.. how have the cheap-o LEDs handled the higher voltage when u turn ur high beams on? Any burnout issues?
tenaciousZ is online now   Reply With Quote
Old 01-11-2013, 06:08 PM   #204
JDMSTA
Member#: 310615
Nope, no issues so far.
Old 01-11-2013, 08:29 PM   #205
tenaciousZ
Member#: 342279
2012 Impreza
^ happy to hear that! Did u need the "decoder" that is offered to go with some of the bulbs out there? I'm considering getting some similar LEDs to make my DRLs yellow. I never use my high beams anyways..
Old 01-12-2013, 01:06 PM   #206
JDMSTA
Member#: 310615
nah, no decoder of some sort needed. the only thing I needed was some in line spliced resistors for the blinkers since I've upgraded those to some cree leds as well.
Old 02-04-2013, 07:28 PM   #207
tspunk
Member#: 345444
2013 Impreza 5-door
Hello,
Can you please tell me what you used for the eyebrow light? I don't know what to buy to change it.
tspunk is offline   Reply With Quote
Old 02-05-2013, 09:53 AM   #208
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Blackmamba24kb
did you retrofit yours too? Any pictures of the finish fogs?
You see the leveling screws, I do not want to loose those, that would be the only way to adjust the fog lights, and the mounting points/brackets need to be retained as well.
hey, didnt get a chance to retrofit the fogs with HID if that is what you are asking. All I've done was add the fogs to the car....getting the car back from the shop soon since the accident, so I'll be able to work on it more. However, I am afraid I won't be adding HIDs to the fogs because I don't want the housing to melt and catch fire like an STI that was posted previously. The front bumper caught fire bc of HIDs in the fogs.
Old 02-09-2013, 07:58 PM   #209
webster354
Member#: 343343
2013 2.0i 5dr Ltd
Excellent thread, I just finished reading it all. Subscribed! I'm also interested in retrofitting my fogs so keep us up to date.
webster354 is offline   Reply With Quote
Old 03-15-2013, 07:35 PM   #210
gnanni
Member#: 350309
2012 Impreza
I love this are you still doing the retrofit for other subaru owners?
gnanni is offline   Reply With Quote
Old 03-16-2013, 09:26 PM   #211
JDMSTA
Member#: 310615
I just do it as a side job right now. whenever something comes up that is.
Old 03-17-2013, 08:50 PM   #212
JDMSTA
Member#: 310615
Alright guys, I've decided to put my fogs back to factory and just use LEDs on it and mod it to use as DRL. Reason being, I only use my fogs in bad weather like rain and especially snowy nights. Well after a couple of snowy nights driving. My retrofitted fogs are pretty much useless. All the snow and slush just piles up against the fogs which pretty much makes it useless. That's why now I've decided to do a quad setup instead using the tiny Morimoto Matchbox projectors in place of the high beam area and use that as my fogs instead. Well enough talking, now onto pictures. Sorry for the daytime pictures being kinda crappy because I took it with my camera phone.
How ya'll like my "switchback" LED strips?
Close up of the cutoff lines
Old 03-17-2013, 09:19 PM   #213
tenaciousZ
Member#: 342279
2012 Impreza
Those led strips look glorious! do u have both amber and white strips installed? I'm not sure what I'm looking at... it almost looks like ur turn signals are on too.
Old 03-18-2013, 06:22 AM   #214
JDMSTA
Member#: 310615
yeah I kept the original blinker since its more brighter in the daytime. The strips I used are these http://www.exledshop.com/universal-l...ver2-copy.html and they're not that bight in the daytime. Its more of an aesthetic than anything. I also wired leds inside the Matchbox projectors as amber blinkers as well. I hardly use the fogs like I said, only in bad weather so I figured I go that route.
Old 03-18-2013, 08:16 AM   #215
alt14
Member#: 271928
2007 Impreza 2.5i SE
I'd wait for Trs to start carrying the x.strip, they're the same leds as the xbaleds which are very bright
alt14 is offline   Reply With Quote
Old 03-18-2013, 10:13 AM   #216
JDMSTA
Member#: 310615
I dunno, the way the XBALED rings voltage regulators failing like crazy. I'd wait even longer for them to release a fix for that.
Old 03-18-2013, 10:21 AM   #217
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
JDMSTA,
did you do wire your fogs to run independent of the headlights? how did you do that?
Old 03-18-2013, 10:47 AM   #218
JDMSTA
Member#: 310615
Originally Posted by flyboy1100 View Post
JDMSTA,
Oh its not wired to be independant. I just did quick mod to run it as DRL instead of the high beam. That pic there with the fogs and inner projectors on is just with the e-brake down to activate the DRL.
Old 03-18-2013, 11:46 AM   #219
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Darn, thanks
Old 03-18-2013, 02:43 PM   #220
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Can you please post how you did this mod? Can you do this to make any light a DRL instead of the high beams??
I would like to get some bright LEDs for the "eye brow" lights and make them my DRLs.
Old 03-18-2013, 03:20 PM   #221
JDMSTA
Member#: 310615
This was the mod that I did even though the walk through is for the WRX but its the same. I don't see why it won't work for they "eye brow" light as DRL. http://forums.nasioc.com/forums/show....php?t=2383843
Old 03-18-2013, 04:22 PM   #222
tenaciousZ
Member#: 342279
2012 Impreza
Will this wiring mod keep whatever u wire as DRLs on when the low beams are on?
Old 03-18-2013, 04:28 PM   #223
jr0bb5
Member#: 315353
5MT OBP/DGM
Good point... didn't even think about that.
Edit: After quickly checking out that thread, it appears as though the answer is yes.
Old 03-18-2013, 04:29 PM   #224
JDMSTA
Member#: 310615
This wiring acts like how it will act from OEM. DRL on when either on drive or e-brake is down. When you turn your low beam on, then DRL is off.
Old 03-18-2013, 04:38 PM   #225
jr0bb5
Member#: 315353
5MT OBP/DGM
He has his low beams and fogs on at the same time in his pics tho... is that because the fog switch will override the DRLs?
[Mini Review] Traded 2011 Impreza Outback Sport for 2012 Impreza Sport Premium tornado542 General Community 15 05-04-2012 07:07 AM
Help with JBL MS-8 install on 2012 impreza sport premium gobells12785 Car Audio, Video & Security 9 03-23-2012 09:56 PM
I finally got a chance to drive a Sprinter. upnygimp Off-Topic 49 03-02-2008 01:32 AM
Finally got a chance to snap some pics ElDuderino Member's Car Gallery 19 08-04-2002 03:30 PM
('93-'01) Finally I got the chance to max out my car. Chode_boy Impreza Forum 11 05-22-2002 03:41 PM
Message Board Statistics All times are GMT -4. The time now is 09:37 AM.
