Notices
Old 03-18-2013, 10:09 AM   #1
new_to_drift
Member#: 316071
15 WRX Limited
Default BC BR Squeak coming from rear
I just installed my BC BR coilovers on saturday and they feel great but when I hit bumps I hear a squeak coming from the rear. I believe its only on the passenger side but whatever I fix on that side, ill be sure to check on the other.
I'm 99% sure that everything is tightened down all the way and plan on rechecking it all once I get home today from work.
Any immediate thoughts as to what it could be if everything does happen to be tightened down? Theres no clunking and when i'm on smooth roads theres no sound and it feels great.
new_to_drift is offline   Reply With Quote
Old 03-18-2013, 10:12 AM   #2
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Are they brandy new or used? either way, a squeak can come from anywhere, unfortunately. Could be a piece of dirt/sand whatever stuck between the camber plate and the chassis - remove, clean, reinstall. Could be the strut shaft sliding in and out - grease it up. Could be the spring isn't 100% in place.
I'd go back through, loosen everything up, sock it all back down and take it for a ride. most likely it's something silly.
Loyale93 is offline   Reply With Quote
Old 03-18-2013, 10:36 AM   #3
new_to_drift
Member#: 316071
15 WRX Limited
They're used so it could definitely be that something isn't properly lubricated. The strut shaft could be the culprit.
What kind of grease should be used?
Old 03-18-2013, 10:51 AM   #4
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
Old 03-18-2013, 11:11 AM   #5
rztmartini
Member#: 334842
2005 WRX STi
Arctic White
I have some BC coilovers with over 15k miles, the rear ones clunk and squeak all the time. I got them without the spanner wrench so I cannot loosen/tighten everything back up.
rztmartini is offline   Reply With Quote
Old 03-18-2013, 11:35 AM   #6
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You could be describing the noise that is normal for that kind of shock.
What dampening setting are you running at? What about spring preload?
Old 03-18-2013, 11:43 AM   #7
new_to_drift
Member#: 316071
15 WRX Limited
I don't think it's normal at all because its happening only on the rear. The dampening setting is set to 6 and the preload is set to 4mm (stock from factory). I am going to redo the preload on the back as a safety precaution when I get a chance.
Old 03-18-2013, 11:47 AM   #8
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Is it like a squishy sound? Or a high pitched squeak?
Old 03-18-2013, 11:53 AM   #9
new_to_drift
Member#: 316071
15 WRX Limited
Higher pitched. It sounds like the spring is making the noise. Could that have to do with preload?
Old 03-18-2013, 11:55 AM   #10
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Im trying to remember if the BCs come with a plastic washer between the springs and the seats. Sounds like the spring is moving on the seat when its compressing (Which is normal..when you compress a spring the ends will want to rotate in relation with each other)
Old 03-18-2013, 12:01 PM   #11
new_to_drift
Member#: 316071
15 WRX Limited
I dont believe they do, at least when I initially set the preload I didnt notice a washer. So maybe when i set the preload again, I should put some lithium grease in between the seat and the spring both on the top and bottom.
Old 03-18-2013, 12:03 PM   #12
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Lithium grease isnt going to last in there. Itll wash right out.
Old 03-18-2013, 12:14 PM   #13
new_to_drift
Member#: 316071
15 WRX Limited
What should I use then?
Old 03-18-2013, 12:18 PM   #14
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Contact BC see if they can send you the washers.
Old 03-18-2013, 12:25 PM   #15
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Old 03-18-2013, 01:25 PM   #16
new_to_drift
Member#: 316071
15 WRX Limited
Hm three no bearings on the front so I'm not too sure that's the problem.
Old 03-18-2013, 01:31 PM   #17
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You have a spherical bearing at the top up front. You don't at the rear.
<I've installed about 100 sets of coilovers. I'm not talking out of my ass.
Old 03-18-2013, 01:42 PM   #18
new_to_drift
Member#: 316071
15 WRX Limited
Oh no I believe you. I just responded back to BC inquiring about the bearings.it would just surprise me if they were just straight up gone, but they are used so who knows what the previous owners did.
Thanks for all ur help
Old 03-18-2013, 01:44 PM   #19
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
There's a good chance they don't come with them period.
When the spherical bearing in your front camber plates start to go, you'll have the same noise up there too.
Old 03-18-2013, 01:53 PM   #20
new_to_drift
Member#: 316071
15 WRX Limited
So if they didn't come with any period, is it something that can be added or no? Would a poorly set preload allow the spring to move more freely than it should therefor causing noise on bumps?
Old 03-18-2013, 02:01 PM   #21
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Yes, they can be added to setups that don't have them. It's just a giant washer essentially.
Preload won't effect it. The spring rotates as its being compressed, no way around that.
Old 03-18-2013, 03:46 PM   #22
new_to_drift
Member#: 316071
15 WRX Limited
Ok, well thanks a lot for your help. I'll be consulting BC and most likely getting some bearings.
Old 03-18-2013, 04:42 PM   #23
new_to_drift
Member#: 316071
15 WRX Limited
I just drove home and it was wet out, and theres no squeak. So that leads me to believe it's a lubrication issue. Is there anything you can recommend to remedy this?
